#15 |
Panda Trueno
Drives: No twin now.
There is no real way to make power unless you go with forced induction.
When you start making power there is a huge increase in likelihood of bending rods. So, yeah..... |
| The Following User Says Thank You to Summerwolf For This Useful Post: | Tcoat (09-01-2016) |
#16 |
No exhaust? No E85? Nothing? Not doubting at all but geez that is quite the increase for just a SC. Maybe I will revisit my original SC plans.
#17 | |
Drives: Neptune GR86
| The Following User Says Thank You to Andrew025 For This Useful Post: | Tcoat (09-01-2016) |
#18 |
JERK This could cost me money. Car is now out of warranty so the gloves can come off.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (09-01-2016) |
#19 | |
#noregrats
#20 |
Drives: 15 BRZ LTD, 05 FXT
I think the two main questions are the following:
Will my car still be reliable after I go S/C? Will my car be as fast as I think I want it to be? Reliability: Get a good reputable kit from a good reputable manufacture installed by a good reputable shop tuned by a good reputable tuner and keep up on maintenance and you should be in decent shape. Keep in mind it WILL NOT last as long as a stock motor, it adds inherit complexity and risk because you're making more power from the same components. Based on my research and learnings, the stock FA20 is up to the task of a nice bump in power, (The JRSC C30 and Edelbrock kits in stock trim seem to be quite reliable, and make great power.) Will it be fast enough: These kits will push you back into the seat nicely through the power band. They will be less violent than a turbocharged car like the ST you drove recently. I think if you go to a local autox and try to get a ride along in a few basic supercharged cars you'll get a good idea of what you're getting into. They will make similar power and be lighter than a 2015 WRX, so you'll be in good shape there if we're using it as a power benchmark. That said, those cars are making some pretty insane power with exhausts and a tune. EDIT: I double checked, I was thinking of the 'all the killer b parts' 2015 WRX. It still drives nicely with a tune, but killer b is what's up on those cars.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tcoat (09-01-2016) |
#21 |
Thupercharged
My 05 wrx has a surge of torque when the turbo spools at 2500rpm, you do not get that with a supercharger. Down shifting is a must for the FRS with a centrifugal, you do have more torque than stock down low but its nothing like the (very fun) surge of torque a small factory turbo will give you.
If you wind the engine out at every shift you will be greeted with power that only continues to climb as you near redline. Very different driving characteristics IMO, I switch between the two when I get bored of whichever I am driving. Completely different experiences. The SC will be as reliable as you can install/pay attention to details. Correct belt length/quality belt, alignment of pulleys, checking SC oil/engine oil at regular intervals.... if you are OCD like me, reliability stays the same. I had a belt failure on my system with a smaller pulley and incorrectly sized belt. This was my fault for running a belt that was the incorrect length. It walked off a pulley and shredded itself. I now check my oil/belt weekly and have not seen any loss of fluids/belt wear beyond normal. If you decide to track the car and go with a vortech unit, look for the competition kit that has an engine oil fed supercharger. It is possible to overheat the "street" kit due to the low volume of self-contained SC oil. No issue on the street, and some people have tracked successfully.... but better safe than sorry. Engine oil cooler would be nice as well. As far as turbocharger "violence" in acceleration/torque.... I had the stock turbo at factory pressure, tuned it to 20psi across the rev range, and finally went with a larger turbo that comfortably gives you around 300whp and a forged higher compression motor build. Even when this thing finally spools by 3500-3700 and gives you a surge of torque in first that will almost break the tires loose, its not "violent". Also, the gas pedal is not an on-off switch With a turbocharger and boost by gear/electronic boost control, you can control the amount/rate of power increase to not be so sudden.TL;DR It will be as reliable as you want it to be, there will always be something faster than you. Also turbochargers can tune their pressures with the proper control solenoids/tune, which gives you expanded possibilities. Supercharger boost is regulated by engine RPM/pulley size.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#22 | |
#23 |
That was enough of a callout to make me double check. I was thinking about the "add Killer B everything" kit.
I love Killer B products ![]()
#24 | |
1st86 Driver!
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (09-01-2016) |
#25 |
Drives: '15 BRZ RA
#26 | |
Drives: '15 BRZ RA
![]() Additionally, it is an expensive direction. Value for money is to go FI. |
| The Following User Says Thank You to nikitopo For This Useful Post: | the_one_mike (09-01-2016) |
#27 |
#28 |
| Need some input LOOK!! | skavengers412 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-21-2016 01:50 PM |
| Clutch Input | dabocx | Forced Induction | 221 | 01-19-2016 07:20 PM |
| 2015 FRS AUX input? | rushofmusic | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 12-13-2014 12:01 PM |
| Looking for SUV Input | ap5512 | Other Vehicles & General Automotive Discussions | 16 | 09-23-2014 03:48 PM |
| Going Supercharged - Need Input! | mothespaceman | Forced Induction | 46 | 09-15-2014 10:25 AM |
