#127 |
Drives: 17 BRZ ,21 GR Yaris, 23 GR86
Do you know what sized pistons are used in GT rears ? Just wondering if GT fronts can be used with PP/STI rears since disc sizes are the same for both GT/PP rears.
#128 | |
Wheels for Brains
Some forum posts say 40mm for PP rears, but I don't have any definitive info like a spec sheet or image of measurement |
#129 | |
#130 |
Drives: 2020 Toyota 86 GT 6M
does someone have measurements for the width of the PP caliper as well as the width of the 1P-.8002A- GT calipers? just curious how much thicker the GT is in comparison since the FTSpeed video mentioned the GT was thicker than the PP calipers
#131 | |
Wheels for Brains
Don't know how width compares, but the mounting method is different too There are templates available for the kit |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | saltywetman (03-17-2021) |
#132 |
Thanks! will try out template once i remove my winter wheels so i can measure the inside with it. I know the ptr2018160bk wheels are confirmed to fit PP brembos but not sure if the clearance is so tight that the added thickness of the GT calipers would make it not fit.
#133 | |
Wheels for Brains
I also put the GT template on a PP spare wheel, and it also needs a 3mm spacer to work |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | saltywetman (03-21-2021) |
#134 |
#135 |
Drives: 2022 GR86
Just found this old thread. Interesting read!
For a more focused thread that doesn't (yet? ) have an off-topic holy war between AP Racing and CSG about which non-PP kit is better, check out https://www.ft86club.com/forums/showthread.php?t=144662. Has most part numbers in the first post, and should be better for quick look-ups.
| The Following User Says Thank You to timurrrr For This Useful Post: | Tokay444 (12-30-2021) |
#136 |
Do you know if the shims of the pads are adesive or clipped? Thanks!
#137 | |||
Wheels for Brains
It's been a while, but I did order and install the ducts from Subaru and they were the correct ones Quote:
Clip, sort of? At least for the fronts. However they don't grip tightly. There is only a c-shaped hanger that holds it to the top. The fit is loose and they flop off the pad pretty easily if they aren't installed in the caliper I don't have any experience with the rears |
#138 |
Drives: It has 4 wheels
Here is a full list of the parts.
Note the front shield change is not needed and you can just cut the rear shield, which saves disassembling other things too. It seems like the calipers are either far more expensive or just not available outside the US, even in Japan. I think I'll have to get the calipers, Posi-Quiet pads and centric front hardware kit from the US, get Brembo rotors locally and buy everything else from Japan. Subaru seems cheaper than Toyota for all parts. For you lucky people in the USA, you can easily buy Centric Parts stuff so if you want a cheaper alternative, buying the following items means you don't need to buy the genuine pins, clips or springs: Posi-Quiet ceramic front pads 105.10010 Centric Parts front hardware kit 117.47018 Posi-Quiet ceramic rear pads with hardware 105.09610 |
#139 |
Drives: 2022 GR86
Have you seen this thread?
Follow the build thread for my GR86!
#140 | |
I thought the Toyota, Brembo and DBA PNs might come in handy as well as clarification of the shields and Centric hardware for those that don't know which pieces that the Centric hardware kits replace and that rear pads can be purchased including hardware. Also I left the repair kits out of my list. |
| CSG Brembo Brakes | LenA | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 09-28-2022 05:09 PM |
| Real STI BREMBO package upgrade - DIY | Trap63 | DIY (Do-It-Yourself) Guides | 40 | 06-15-2022 10:25 PM |
| EVO 7 BREMBO FRONT BRAKES ON BRZ? | NOTORIOUS.BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-26-2016 01:24 AM |
| Evo X brembo brakes | Justkiz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-12-2013 03:00 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 11:08 AM |
