Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 07-25-2016, 03:03 AM   #1
Xplicit
Looking for 15 mm Spacers (1 set/rear pair)
Looking for a set (2) of 15 mm spacers to install on my rear wheels
Xplicit is offline   Reply With Quote
Old 07-25-2016, 07:36 AM   #2
BRZ'13
BRZ'13's Avatar
Drives: subaru
Dont forget you will needed extended studs as well
BRZ'13 is offline   Reply With Quote
Old 07-25-2016, 09:50 AM   #3
wparsons
wparsons's Avatar
try http://novustech.ca/
flickr
Old 07-25-2016, 12:17 PM   #4
Xplicit
Extended studs?
Old 07-25-2016, 01:49 PM   #5
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Nah just get the bolt on type. It's fine as long as your wheels have the spaces on the hub for them and most aftermarket and our OEM wheels do.
I ordered a full set (4) 15mm hubcentric bolt on spacers off Ebay for ~$200 CAD all said and done. I also see some Toronto Kijiji ads advertising the same thing so maybe look there too. I don't think linking Kijiji ads is allowed so I won't but just search spacers in Toronto and they will show up, might save you the aggravation of buying from a US seller on Ebay.
Lynxis is offline   Reply With Quote
Old 07-25-2016, 03:05 PM   #6
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
J-Spec Performance in Scarborough has them I believe. Check their Kijiji ads.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 07-25-2016, 03:39 PM   #7
86Tony
Drives: 2015 AOZORA EDITION
i have a 20mm if your intrested
86Tony is offline   Reply With Quote
Old 07-25-2016, 04:24 PM   #8
BRZ'13
BRZ'13's Avatar
Drives: subaru
that's true. forgot bolt on ones existed
Old 07-25-2016, 07:17 PM   #9
Xplicit
Well I am running the alloy 5 axis limited edition set of rims - do you know if the bolt ins would be fine for that?
Old 07-25-2016, 11:34 PM   #10
Lynxis
Lynxis's Avatar
Offset wise they'll be good with a bit of negative camber but no idea if they have provisions for running spacers. If they're on the car, you'll need to take one off and see if there are pits between each of the stud holes that look like so:
If so, they'll work with the spacers but if not, they won't.
pair of 10mm spacers OMJM Want-To-Buy Requests 0 09-11-2015 11:32 AM
FS: MD. Pair of 20mm H&R bolt on spacers frslee Wheels and Tires 4 09-02-2015 09:26 AM
FS: 25mm Spacers (pair) *KID* Wheels and Tires 0 10-26-2013 10:22 AM
Effect of using of spacers for rear-only mit_peid Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-05-2013 01:06 AM
Square Setup w/ Rear Spacers thejevans Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-11-2013 04:53 PM
