#1261 | |
Sent from my SM-G781B using Tapatalk |
#1262 |
Drives: 2020 BRZ Sport Tech RS
I very much hope that is the case, since the Harrop kit is one of my top picks if I do go FI, but we'll see!
#1263 |
Drives: 2015 BRZ Limited
After years of researching and planning my build around this kit, learning they were put on hold the moment I was ready to purchase one, and then a year of anticipation as I waited for the new kit to be released, I finally have my hands on a lightly used kit!
![]() The plan is to run the 90mm pulley with E52 on a flex kit, ID 1050X injectors, and an ACE A350 header. Stock fuel pump. Tuned by Zach from CSG. Goal is ~320whp. I'd love to run a larger throttle body, but I don't think I've found a reasonable solution that uses the same OEM throttle body form factor as to not run into clearance issues with the AC compressor. I will definitely be posting if I have any trouble, and then a post when I finally get it all tuned and good to go. I'm very excited to get this kit on and finally complete a major piece of my build.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| The Following 3 Users Say Thank You to FunnyGopher For This Useful Post: |
#1264 | |
Very cool, glad you found a kit to install. Congrats. |
#1265 | |
Drives: JRSC BRZ
Maxbore.com can overbore the OEM 2mm for $170. I had mine done by him. Turn around time is about 2.5 weeks however. |
#1266 | |
Drives: None
You really don't need the larger throttle body though, what are you trying to achieve by doing it? It might be another added complication with respect to what I PM'd you. edit: just realized you're local
#1267 | |
And yes! We seem to be in the same area. DM'd.
#1268 |
So I have the grams right now, unit is physically too big. I found a company called Blox that makes a unit that is 70mm, and it looks to be the same form factor as the OEM one, although I don't know how, so they're providing me measurements of the unit so that I can compare.
#1269 | |
Just ordered a 90mm pulley from Harrop USA. Looks like the going rate for a pulley right now is $145 USD + shipping.
I also asked about the recommended coolant, since the installation only references what I believe is a part number, but upon searching that part number, I find nothing. Harrop told me it's just Dexcool coolant. If anyone has any additional insight, I'd like to know if it's a specific concentration of the coolant, or if I can just use a 50/50. I can also just ask Harrop since I have them in an email thread. Quote:
If someone with a kit who is running an OEM throttle body and has retained their AC compressor could take a better picture of the clearance between the throttle body motor housing and the AC compressor, you'd make my day. I can't find any decent pictures online of the clearance up close.
#1270 | |
#1271 | |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | FunnyGopher (05-19-2022) |
#1272 |
You get a medal sir, thank you so much.
I highly appreciate the rough measurements as well. You're a legend.
| The Following User Says Thank You to FunnyGopher For This Useful Post: | grumpysnapper (05-19-2022) |
#1273 | |
Seņor Member
https://www.toda-racing.co.jp/en/pro...-throttle.html
1974 TA22 Celica
2013 86 GT |
#1274 | |
The Blox TB is showing up tomorrow. I'll be installing the kit over the weekend. I'll be able to confirm fitment or not in the next few days. After some quick measurements, the supercharger TB port is 70mm, which is also the size of the Blox TB. My guess is they'll line up very nicely. The TB also doesn't have the same coolant jackets that the OEM unit does, so there should be some more clearance there in case the unit itself is actually a bit bigger than measured.
| HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 09:03 PM |
| JDL turbo kit owners thread | yomny | Forced Induction | 1346 | 08-30-2023 12:07 AM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 03:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
