Old 09-12-2017, 09:21 AM   #351
Bfranklyn86
Drives: GT86 Harrop S/C
Originally Posted by G-Unit86 View Post
Thats my plan next year. Probably going with HKS Stroker kit, swaping out the Rods for forged Rods, and larger valves, with some light head work to allow for better flow at the top end.
I was thinking that kit, but not replacing their rods, just running quite low boost through it.
Maybe an 80mm pulley, with good header, HFC front pipe and stock exhaust, aiming for 300whp on 93.
I think those non-forged rods should be ok with that. Harrop have this 2.1l kit in there car running 420whp.
Bfranklyn86 is offline   Reply With Quote
Old 09-15-2017, 12:26 PM   #352
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
For info, I ran the harrop with a full decat exhaust (ace anaconda large size, fujitsubo, hks catback); and with a 80 mm pulley I was churning out 270whp on AKI93 - however i think that 20whp could be taken from a better tune.
I just mounted the 75mm pulley with upgraded fuel pump and injectors - still on stock internals. Tune is being done these days, we'll see how much whp i can get from this.
vgarcin is offline   Reply With Quote
Old 09-15-2017, 07:54 PM   #353
frsq5
Drives: 2014 Scion FR-S Monogram
You can add me to the owner's list!
Ordered mine from Neal @ The Racer's Line two weeks ago!
Still waiting for the kit to clear the darn customs....
Can't wait till I get the kit installed on my car and drive it!
frsq5 is offline   Reply With Quote
The Following User Says Thank You to frsq5 For This Useful Post:
kuczynskika (09-16-2017)
Old 09-16-2017, 12:30 AM   #354
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Im in Santa Rosa. Looks like you might be near. Id love to check it out when you get it installed, if you don't mind.
Old 09-16-2017, 02:16 AM   #355
frsq5
Don't mind at all!
I'll be updating the thread with pics after mine gets installed!
Irace86.2.0 (09-16-2017)
Old 09-16-2017, 03:22 AM   #356
Bfranklyn86
Thanks for that info.
270whp does sound a little low for an 80mm pulley and full exhaust, but I bet it is still fun to drive.
Keep us posted how you go with the new tune and 75mm pulley.
Old 09-16-2017, 04:47 PM   #357
Irace86.2.0
Don't mind at all!
Im curious to see it in person. I have a plan for rerouting the coolant lines. Wouldn't mind a ride too Never been in a boosted 86. Im hoping to pay off a few things and get my wife in a ride before I pull the trigger. Hopefully the kit is CARB approved by then or itll be either Edelbrock or Jackson Racing.
Old 09-16-2017, 09:13 PM   #358
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
For those of you who may be interested, the STi flexible strut tower bar does fit! But only barely... I also installed it with some washers, just to be safe. Check it out.
kuczynskika is offline   Reply With Quote
The Following 4 Users Say Thank You to kuczynskika For This Useful Post:
Bfranklyn86 (09-17-2017), CxG (09-24-2017), Irace86.2.0 (09-17-2017), PhyrraM (09-16-2017)
Old 10-02-2017, 02:52 PM   #359
frsq5
How many people are daily driving with this supercharger?
If you are dailying, how many miles on the car since installing the supercharger?
My car will be a daily after I install the supercharger but I have about 90 mile each way commute.
So I'm curious if the car can take the drive with the supercharger added on.
Old 10-02-2017, 03:04 PM   #360
kuczynskika
I daily my car. Had 25000 at install a year ago and I’m at 33000 now. Zero problems. Exceptionally reliable.
The Following 3 Users Say Thank You to kuczynskika For This Useful Post:
CxG (04-26-2019), frsq5 (10-02-2017), weederr33 (10-02-2017)
Old 10-02-2017, 04:11 PM   #361
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Could you mark the bar and do some pulls from various RPM ranges? Curious to see how close the bar and supercharger may get. Unless it hits really violently I couldn't imagine is causing any significant damage, but it's always worth checking clearances through a full range of motion!
Love your car btw. You've made awesome component selections.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 10-02-2017, 04:19 PM   #362
kuczynskika
I regularly do freeway on ramp pulls and drive like a goon and I’ve been checking to see if there are any rubbing/clearance issues. No problems so far. I do suggest running with the washers as spacers tho since it’s really close. There’s a lot of adjusting you can do with the bar too, but you want the tension set just so per the STi instructions.
Thanks! It was my goal to build a car that improved on all of the deficiencies from the factory but retained as much OEM as possible. I think I’ve nailed it so far haha. Premium components like the Harrop SC are really the key. Can’t compromise on quality.
Old 10-02-2017, 04:30 PM   #363
JazzleSAURUS
Fully agree. I built my Forester XT with the intent to build what Subaru would of done if they were building an OEM Forester STi S204 type of a build, and not limited by nanny states like california or bean counters. It's a really exciting package of parts to see in action together when every single component has been upgraded or replaced, and somehow it still drives like it could be a factory car. It used to drive flawlessly, but there is a point where it does get a little rough and a little uncomfortable. When I got the BRZ to daily I let myself do a few more things I wanted to do outside of the scope of an S204 style build and I'm glad I did.
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
kuczynskika (10-02-2017)
Old 10-03-2017, 07:05 AM   #364
Bfranklyn86
I daily mine. 4 mile commute on country back roads. Some occasional track work too. Probably done around 8k miles supercharged in 1yr.
No significant issues.
The Following User Says Thank You to Bfranklyn86 For This Useful Post:
frsq5 (10-03-2017)
Search this Thread:
Advanced Search
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
JDL turbo kit owners thread yomny Forced Induction 1346 08-30-2023 12:07 AM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
