#253 | ||
Drives: '14 981CS, '99 NB1
By how much? We don't know. There aren't enough people modifying this setup yet to have that data. But it will definitely make a difference. I have extensive experience on Honda K20 motors with pull through blowers and have seen dramatic differences in power/efficiency on blowers when swapping to a large TB and intake. Attention should also be paid to the flange area where the TB mounts, to make sure that the larger TB's inner diameter isn't wider than the inner diameter of the inlet flange. If it is, you'll need to bore it out. I'm pretty sure Harrop bored it out a bit already so a larger TB (within reason) will likely work without modification. If I cared about making more power on this car, I would source a larger TB and have a custom 3.5" or 4" intake made for it. This would make the blower as efficient as possible. But, I don't find myself wanting for power at ~300bhp on this chassis, so I doubt I'll invest any more money in the setup. She's already too fast for the streets and is more than entertaining enough on the track. Quote:
| The Following User Says Thank You to johan For This Useful Post: | CxG (06-21-2017) |
#254 | |
Drives: Q5 + BRZ + M796
On E85, right? Sent from my iPhone using Tapatalk
#255 |
Drives: GT86 Harrop S/C
Yeh on e85. I don't know what this kit is capable of on 93, because (in my opinion) it would need slight drop in compression, then the throttle body work, and maybe WMI. I haven't heard of anyone doing that. With either this kit or the edelbrock.
| The Following User Says Thank You to Bfranklyn86 For This Useful Post: | Irace86.2.0 (06-19-2017) |
#256 |
Yeah there is a reason the TRD one went with removing the AC and a larger snout and TB (apart from not caring about retaining the AC).
#257 | |
#258 | |
How did you modify it? Sent from my iPhone using Tapatalk
#259 |
#260 |
Drives: UK GT86
It's unlikely to be sufficient. It just about copes with NA use.
.: Stealth 86 :.
#261 | |
What do you run with your sprintex set up? |
#262 | |
Drives: UK GT86
https://www.merlinmotorsport.co.uk/s...-water-coolers I don't run an oil cooler but will eventually custom make the same as Ade.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Bfranklyn86 (06-23-2017) |
#263 |
Drives: GBS BRZ Harrop SC/PTuning Header
The Jackson racing dual radiator is petty spot on for cooking needs. I've been using it for a few months now without issue.
| The Following User Says Thank You to Trefoil For This Useful Post: | CxG (07-06-2017) |
#264 | |
Also, could you envisage any issues fitting it with a Harrop kit already installed? The way things are going I'll be getting this fitted just in time for winter! |
#265 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Has anyone weighed the components in the kit as well as the weight of the parts that it replaces like the stock intake pipe, engine cover plate, etc?
Interested to know how much weight the whole kit would add to the car. |
#266 |
Works sell a forester Oil to water cooler kit that fits on 86 applications see link below:
http://store.worksmotorsports.com/WO..._p/139.211.htm To comment on it not being enough, with a stock radiator I would agree as your cooling system will be taxed with the upgrade in power. However with an updated radiator and this cooler you should be good, even for track as long as you lower your oil change intervals. |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 09:03 PM |
| JDL turbo kit owners thread | yomny | Forced Induction | 1346 | 08-30-2023 12:07 AM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 03:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
