| Member's Car Journals Car journals by our members. |
Drives: Man
Slyphen's BRZ - Luna - STX Build
Vehicle Purchase 5/10/14 from Carter Subaru
Lighting Exterior Interior SuspensionPerformance Miscellaneous [/LIST][/INDENT]
Drives: Man
Activity and Maintenance Log:
03/23/15 - Oil Change: Royal Purple 0W20 and filter @ 4252 Miles 05/08/15 - Rear left tire replaced (unfillable puncture) - Discount Tires @ 4844 Miles 07/16/15 - Oil Change: Royal Purple 0W20 and filter @ 7300 Miles 07/16/15 - Cabin Air Filter change: FRAM cabin filter 08/20/15 - Shark-fin Antenna and frameless rear view mirror installed 10/09/15 - New front left strut (Warranty) - Carter Subaru (did not fix issue) 10/09/15 - Wheel Alignment - Carter Subaru @7800 Miles 10/09/15 - New DRL LED module swap (Warranty) - Carter Subaru 10/09/15 - Roof Dented 10/28/15 - Roof panel and windshield replaced by Special Interest Auto Collision 11/20/15 - Oil Change: Royal Purple 0W20 and filter @ 11700 Miles 11/20/15 - Transmission and Differential: Motul Gear 300 75W90 @ 11700 Miles 11/20/15 - Tire Rotation 11/20/15 - K&N Drop-in Filter Change 12/04/15 - NAV Unit Replaced - Carter Subaru (Warranty) 12/04/15 - *Shifter Collar, Bushing, Clamp Snap Boot Dust, Plate Washer replaced - Carter Subaru (Warranty) (did not fix rattle issue) 12/04/15 - Shifter Knob replaced - Carter Subaru (Warranty) 12/04/15 - Rear deck brake light module replaced - Carter Subaru (Warranty) 12/11/15 - Front Strut Mount, Coil Spring Replaced - Carter Subaru (Warranty) 12/11/15 - Wheel Alignment - Carter Subaru @ 12207 Miles 12/11/15 - Gear Shift Lever Assy. Replaced - Carter Subaru (Warranty) (did not fix rattle issue) 01/11/16 - Shifter bushing and O-Ring changed - Carter Subaru (Warranty) (issue relatively fixed) 02/27/16 - Fortune Auto 500 Coilover Installed @ 13940 Miles 02/27/16 - SPL Titanium Rear Lower Camber Arms Installed @ 13940 Miles 03/02/16 - Autocross Custom Alignment (Cam 2.4f/1.5r, Cas 6.5, Toe 0.0f/0.15r) - Chase Race @ 14005 Miles 05/02/16 - Oil Change: Royal Purple 0W20 and filter @ 16650 Miles 07/05/16 - Clutch Assist Spring removed. 07/08/16 - Lady backs into Luna in parking lot. Bumper cover damaged, headlight scratched, driver side fender deformed with paint cracked, driver side side marker damaged. 07/22/16 - New bumper installed(paint/clearcoat), driver side fender reformed(paint/clearcoat), headlight polished. New clear sidemarkers installed. 07/22/16 - Raceseng Slammer Shift Knob installed. 08/17/16 - Front bumper cover clearbra installed Xpel Ultimate - Accutint 08/17/16 - 20% ceramic window tint installed - Accutint 08/20/16 - Oil Change: Royal Purple 0W20 and filter @ 21400 Miles 08/20/16 - Wedssports TC105N w/Bridgestone RE71R mounted for SCCA #7 08/20/16 - raised suspension on all corners by .15" 10/12/16 - Mount and balance Continental Extreme Contact DWS 225/45R17 @ 24360 Miles 10/29/16 - Gruppe-S Unequal length header installed (Drift Office) 10/29/16 - Drift Office Tune (Bob Watanabe) 10/30/16 - Oil Change: Royal Purple 0W20 and filter @ 26380 Miles 10/30/16 - OEM style rear diffuser installed. 01/29/17 - Fortune Auto 500 Coilover Removed. 02/18/17 - KW V3 with 400lbs./in springs installed @ 29930 Miles 02/22/17 - Race Alignment (Cam -3.0f/-2.0r, Cas 7.5, Toe 0.0f/0.15r) - Chase Race @ 30075 Miles 04/08/17 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 31539 Miles 04/08/17 - Transmission and Differential: Motul Gear 300 75W90 @ 31539 Miles 06/30/17 - Race Alignment & Corner Balance (Cam -3.6f/-2.5r, Cas 6.6, Toe 0.0f/0.10r) - Joey Sim @ 38500 Miles 07/06/17 - BFGoodrich G-Force Rival S 1.5 Mounted and Balanced (race setup) 07/23/17 - RX7 crashed into luna. suffered front driver side damage. No frame damage. Damage to driver side fender, bumper cover, bumper, front wheels/tires, front suspension, driver side headlight, side markers. 08/07/17 - Towed to Mark 2 Collision for repair. 08/28/17 - Repair Complete by Mark 2, Installed new KW V3 Suspension, New Front Continental DWS 06 225/45/17. 09/07/17 - Autocross Custom Alignment (Cam 3.4f/2.5r, Cas 6.5, Toe 0.0f/0.15r), Corner Balanced - Chase Race 40755 Miles 09/11/17 - Full Front End Clearbra by Polished Image @ 40800 Miles 09/30/17 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 41037 Miles. 12/09/17 - Hydraulic Hood Strut - SJ part out 12/09/17 - Perrin 2.5" resonated catback exhaust - SJ part out 12/09/17 - Perrin Intake Tube - SJ part out 02/10/18 - Front/Rear Stop Tech Slotted Rotor + Stainless Lines Installed - 44603 Miles 02/10/18 - Front / Rear Ferrodo DS2500 Brake Pads + Motul RBF 600 DOT4 Brake Fluid (Brake and Clutch Fluid Flush) - 44603 Miles 02/10/18 - Motiv High Flow Cat + Perrin Over Pipe Installed - 44603 Miles 02/11/18 - Driver Side Rear Axle CV Joint broke @ 44850 Miles 02/14/18 - Rear Axle Partout x2 (14k Miles) replaced both rear axles - In-Tune Auto (Jason Merritt) @ 44850 Miles 03/15/18 - Autocross Custom Alignment (Cam 3.4f/2.5r, Cas 6.5, Toe 0.0f/0.15r) - Chase Race 44930 Miles 04/29/18 - Replica tS Aero Package (front lip, side skirts, rear side diffuser) Installed @ 46033 Miles 05/27/18 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 47806 Miles 09/19/18 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 53424 Miles 09/21/18 - Endlink Bushing replacement, Front Sway Bar Bushing Lubrication @ 53460 Miles 10/13/18 - Spark Plug and Coil Pack Replacement @ 54634 Miles - Drift Office 11/19/18 - Timing Cover Seal Repair (TSB) @ 57420 Miles - Michael's Subaru of Bellevue 11/19/18 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 57420 Miles - Michael's Subaru of Bellevue 11/26/18 - Exedy OEM Clutch Replacement @ 57539 Miles - Chase Race 11/26/18 - OEM Revised TOB and Bearing Retainer Replacement @ 57539 Miles - Chase Race 11/26/18 - Varus Billet Aluminum Shift Fork and Pivot Installed @ 57539 Miles - Chase Race 11/26/18 - TS Billet Aluminum Cam Plate Installed @ 57539 Miles - Chase Race 03/21/19 - Autocross Custom Alignment (Cam -3.5f/2.7r, Cas 6.5, Toe-in 0.0f/0.15r) @ 60440 Miles - Diftech 04/22/19 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 62710 Miles 08/30/19 - Throwout Bearing Change (OEM Revised) @ 67001 Miles - Diftech 08/31/19 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 67030 Miles 09/14/19 - Transmission Oil Change Motul 300 @ 67120 Miles 02/01/20 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 71034 Miles 08/23/20 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 75034 Miles 08/23/20 - New Battery Installed 08/23/20 - Returned suspension/exhaust/wheels to stock 09/04/20 - Luna has found a new home, ending this epic chapter and my journey with her. hope to see her again one day. Last edited by slyphen; 02-19-2024 at 01:41 AM. |
Drives: Man
Trophy Case (Podium Only)
SCCA 2018 Event #7 - NS4 STX - 2nd Place - 68.825/67.536) 2017 SCCA 2017 Event #1 - IST Class - 2nd Place - 58.869/58.505 SCCA 2017 Event #2 - IST Class - 3rd Place - 64.776/62.282 SCCA 2017 Event #3 - IST Class - 2nd Place - 60.911/60.679 SCCA 2017 Event #4 - IST Class - 2nd Place - 69.791/69.642 SCCA 2017 Event #5 - IST Class - 1st Place - 50.878/50.878 SCCA 2017 Event #6 - IST Class - 1st Place - 50.969/50.969 (STR Miata) SCCA 2017 Event #7 - IST Class - 1st Place - 58.676/58.676 (STX BRZ Scott Engler) SCCA 2017 Event #8 - IST Class - 2nd Place - 50.735/49.425 ![]() ![]() SCCA 2017 IST Class Champion![]() ![]() ![]() 2016 BSCC 2016 Event #3 - Nov Class - 3rd place - 65.626/63.473 BSCC 2016 Event #5 - Nov Class - 2nd place - 59.051/58.103 (AM) BSCC 2016 Event #5 - Nov Class - 3rd place - 59.493/56.615 (PM) BSCC 2016 Event #8 - Nov Class - 1st place - 54.942/54.942 (AM) BSCC 2016 Event #8 - Nov Class - 1st place - 54.526/54.526 (PM) http://www.conechaser.com/driver/QingRui.(Jim).Zhu ![]()
Drives: 2016 Scion FR-S
Did you modify the SPL rear lower control arms to be STX legal? They have solid bushings.
| The Following User Says Thank You to Infinity For This Useful Post: | whataboutbob (02-02-2017) |
Drives: Man
Not yet, i'm still running Novice and IST class for the next year or 2. but when the time comes for me to enter STX and compete at National Tour, i will certainly get legal bushings put in.
#12 |
Drives: Man
FA500 has served me well for the novice season. time to step up the game.
| The Following User Says Thank You to slyphen For This Useful Post: | FujiwaraTofu86 (02-02-2017) |
#13 |
Drives: 2014 BRZ Limited
#14 | |
Drives: Man
These are 2 way adjustable, and a much better damp range than the 1 way adjustable FA. Half of these also have custom swift springs, while i'm getting the spec and the front swift springs ordered(annie took the front springs and used them on her MCS). On top of all that, i'm also getting setup notes from a multiple time national champion. FA served me well for novice autocross and daily, but i'm ready to move on to a bit more serious competition. |
| The Following User Says Thank You to slyphen For This Useful Post: | Carlos_M (02-02-2017) |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| [B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 09:41 AM |
| Slyphen's BRZ - Luna | slyphen | Member's Car Journals | 14 | 06-27-2016 02:58 PM |
| Slyphen's Phantom | slyphen | Member's Car Journals | 1 | 06-25-2015 08:32 PM |
| No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 10:14 PM |
