#15 |
Drives: BRZ Limited
Look at what kind of rear wheel is on this crashed BRZ a few years ago.
http://www.newsday.com/long-island/s...?firstfree=yes |
#16 | |
not a twin owner
Drives: 2016 Veloster Turbo DCT
Yeah, but even if the donut contrubuted to the crash (we don't know this, right?), that's a different reason for not putting the donut on the drive axle, than "your diff will overheat and die" |
#17 |
Just another BRZ owner
Drives: 2014 Subaru BRZ Limited MT
If you drive with a spare tire on your rear wheels..
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz |
#18 |
Mr Cool Guy
Drives: 2013 Scion FR-S (Raven)
Really? Didn't know this... My car didn't come with manual 😢
Sent from my Nexus 6P using Tapatalk
- RAVEN 86 -
#19 | |
Drives: Not an FRS, but same initials.
-your friendly snotty lazy ass who creates jobs for AAA men. But seriously folks, tip the driver when you call AAA. |
#20 | |
Huge E85 fan!
Drives: 2016 Scion FRS
I've seen it before, but I can't remember what car it was. Maybe an SI? But some FWD cars do recommend doing the switch. But a lot of high end cars with LSD don't have this requirement (non-square wheels) so I don't think it's a big thing esp. if you use the donut for what it's meant for- short distance slow drive to get the tire taken care of. |
| The Following User Says Thank You to guybo For This Useful Post: | mdm (07-20-2016) |
#21 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
EDIT: using this: https://tiresize.com/calculator/ There is a 60.4% difference in width and .4% difference in circumference |
#22 | |
not a twin owner
No I am not, difference in the contact patch size should not cause any additional strain on the differential (in normal driving, I am not talking launching or attempting donuts), difference in diameter theoretically could, but I am not sure how if it's only 0.5% or 0.4%. |
#23 | |
I'm curious myself, but I personally do not plan on ever testing it out myself. |
#24 |
[insert cool phrase here]
Drives: BRZ Premium
You "can" drive with the spare on the rear with zero problems, if you're smart about it.
Toyota just wants to cover their as$ because people are retarded. They assume retards will drive 80mph with all the nannies off and then complain the rear end is making funny sounds after a flat. Or worse case some retard will get the rear end lose and plow into (insert verb) and kill damage. If I get a flat in the rear, in town and a tire shop is only 10 minutes away, and I'll never go over 40 mph. I'll do it. Now if I'm the middle of bumfuck vill, and I'm 2-3 hours to the nearest city, I'll swap out the good front tire put it in the rear and drive under 60mph.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | mdm (07-21-2016) |
#25 |
Drives: 13 BRZ, 16 FiST, 05 WRX
My guess is so the car will understeer instead of oversteer.
#26 |
Drives: 2013 FR-S 10 series [755]
I think a spare tire mean get you to some place safe ASAP or closest place you can replace your tire. I dont think it meant for more than 10-20 miles.
It depends on how flat the tire is. If it still has 15-20 PSI,,i would just drive to a gas station within 1-5 miles radius. If the sidewall got damaged and i cant put air, then i will follow what the manual said and call road side. If the car manual said u need a swap,, i think the road side would have to do it for you. |
#27 | |
Drives: BRZ Premium
You can drive on a spare for more than 100+ miles, as long as you don't go over 60 mph. I have when I was in the middle of the of a road trip. Perfectly safe. But the sooner you fix a normal tire the better. I would not advise you to drive on low psi tire. I have killed a tire that way. You know how? The rim rolled over the edge of the side wall just inside the tire. Made a gash that no tire shop would repair. It looked like some one took an ice scream scoop and cut out a 2" gash. It didn't cut through but there was little protection. There was only one turn I made that did that damage. The local tire shop was only 2 miles away in town.
#28 | |
I mean up to you if you continue to drive more than 50 miles with your spare or so. Its your choice. I cant force you Last time i had a flat tire, it was 20 psi left. I went to America tires just 2.5 miles away and had it fix right away. Nothing was damage. I mean thats up to you too, if you like to wait for the tow or rotate the spare yourself. Mine was a flat rear tire. |
| Mishimoto Compact Baffled Oil Catch Can Build Thread! | Mishimoto | Engine, Exhaust, Transmission | 81 | 08-21-2019 09:05 PM |
| Anyone Have Spare Stock Taillights/Rear Fog I Can Borrow? | AdamBomb518 | Mid-Atlantic | 5 | 02-25-2014 05:07 PM |
| Buschur Sport Compact Shootout (May 26th) | CaptainSlow | Great Lakes | 0 | 05-21-2013 02:24 PM |
| My FR-S is so compact.... | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 12-03-2012 04:54 PM |
| Found a recent 3 door RWD compact... | Allch Chcar | Other Vehicles & General Automotive Discussions | 50 | 05-30-2012 04:22 PM |
