Old 07-08-2012, 12:37 PM   #29
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I will add the spring compressor method to the DIY as an alternative, but in my opinion I don't think that my method was unsafe at all. There is not very much load on these springs and by damping the end load (with the wheel) and the outside load (with the plywood on top) there is just nowhere for the spring to go.
I have used spring compressors before and it seems like a 50/50 safety effect. I have had the fingers slip from springs before, and also get jammed between coils. I have an Autozone literally one block away from my house that loans tools for free, but I don't feel safe using those crappy compressors.
If someone does not feel comfortable with my methods then they should not attempt them, and I will modify my DIY to reflect that.
Old 07-08-2012, 12:46 PM   #30
DarrenDriven
NW Region Moderator
Updated...
22: Here is my shadetree system for removing a spring safely from a strut. The spring is under pressure and if you just unbolt the top then it will likely shoot off. With a wheel pinning the strut against an immoveable object, and a 2nd person using their foot to push against the wheel, you don't have to worry about any violent action. Additionally, I use an additional piece of plywood over the spring that I stand on just in case it wants to move up. (see plywood being held at top of photo) These springs did not have much potential force and unbolting the top bolt with a deep (14mm?) socket was very anticlimactic. This method ONLY works with an air impact wrench.
If you do not have an impact wrench then the only correct way is by using spring compressors. They are available at pretty much any auto parts store, and I think they are free loaners at Autozone. If you have ANY doubts about this step you should take your struts to an auto repair shop and have them remove your springs.
The Following 2 Users Say Thank You to DarrenDriven For This Useful Post:
blu_ (07-08-2012), Kwaziekeller (07-08-2012)
Old 07-08-2012, 01:37 PM   #31
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Great write up, swapping springs/coilovers isn't rocket science but it's a formidable task if you've never done it before. Excellent use of photos to create a step by step writeup!
My .02 on the spring compressors... often you'll have a car friend who has a set collecting dust that you can borrow for free as well. They take more time to install/remove, and your method would probably work ok, but if you have access to them then it's best to use them.
PS... I'm one of those guys that have a set collecting dust and will continue to collect dust because I plan to put coilovers on my FR-S.
Kwaziekeller is offline   Reply With Quote
Old 07-08-2012, 01:38 PM   #32
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
DarrenDriven, you crack me up! What's next?, Super charger? Turbo, airplane mode? Submarine add on package? I just want to say thank you for doing all these things and showing us. The pictures and the how to classes are great. I think all of us can't wait for your next project.
Roadstercycle is offline   Reply With Quote
The Following User Says Thank You to Roadstercycle For This Useful Post:
blu_ (07-08-2012)
Old 07-08-2012, 01:55 PM   #33
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
You get an alignment yet? Of so have a recommendation for places to go?
blu_ is offline   Reply With Quote
Old 07-08-2012, 01:57 PM   #34
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Who did you buy from?
tonystewart is offline   Reply With Quote
Old 07-08-2012, 02:33 PM   #35
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Thanks for adding the new excerpt about using spring compressors.. makes me feel better.
BTW.. You can get spring compressors at harbor freight for $14.99.
Darren.. I'm not trying to rain on your parade.. it's a fantastic how to thread.. you did a great job. I've just been around the car forum world a long time and I've seen and heard too many stories of people cutting corners and getting hurt. Spring replacements are one of the more common places that people cut corners and make mistake and wind up hurting themselves. The worst issue has always been methods of lifting a car off the ground to work underneath it. It never ceases to amaze me the methods some people will use to lift a car.. and how they sometimes fail and sometimes kill people..
Anyhow, I'm just a stickler for being "proper" or "politically correct" when writing a how-to thread. We should always describe the proper way of doing something and make sure you say what the proper way is. Then if you've got a shortcut or creative method of your own.. go ahead and list that as well.. but always with a disclaimer saying that it's not the "proper" way.
Anyhow.. sorry for the digression.. back to the topic at hand.
eikond is offline   Reply With Quote
The Following User Says Thank You to eikond For This Useful Post:
WolfSongX (05-08-2013)
Old 07-08-2012, 03:29 PM   #36
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It's usually a good idea to idea to load the rear suspension before torquing the bolts on a setup like this.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-09-2012, 02:50 AM   #37
DarrenDriven
NW Region Moderator
Kwaziekeller, I agree that anyone with access to cheap or free compressors should take advantage of them. I'll repeat again that I think that it is too easy to use the compressors improperly and anyone that has doubts should take the struts to a professional. My method, which really only works well with air tools, has worked for me in situations where the spring is lightly loaded, such as the FR-S.
Roadstercycle, thanks for the props! Maybe I need to add smokescreen, oil slick and other Spy Hunter mods, hehe... hmm.....
blu_, I haven't aligned yet because I am waiting for my D2 coilovers to arrive. I can recommend The Lineup Shop near 102nd & Glisan, though. They are very crusty, but they are reasonably priced and have done good work for me on my last couple of lowered cars (350Z and S2000).
tonystewart, I have a friend that can get parts wholesale, so I ordered directly from the manufacturer through his account. I'm not doing it to make money, just to help get the scene started in the Portland area.
eikond, I get it. I hope that my disclaimer helps.
Jeff Lange, thank you for this tidbit. I am going to edit the DIY to reflect this.
Old 07-10-2012, 01:42 AM   #38
DarrenDriven
NW Region Moderator
Jeff
I changed the DIY back to torquing the rear suspension in the air because I crawled under the car today to check something out and I realized that it is virtually impossible to torque those suckers while it is on the ground. It is a good idea in theory, but in application not really gonna happen.
Also, I added torque specs to the DIY, that should make things easier for people. Added the torque spec sheets at the very end of the DIY as well... I am pretty tired and I think that I got everything right, but if someone wants to double-check for me that would be great.
Old 07-10-2012, 02:06 AM   #39
Jeff Lange
Jeff Lange's Avatar
You don't need to do it on the ground. Either jack up the suspension while it is in the air to load the suspension, or use a drive-on hoist, such as many alignment shops use.
I always load the bushings before torquing the bolts. It's a mistake not to, IMO.
Jeff
The Following User Says Thank You to Jeff Lange For This Useful Post:
IBill4You (06-17-2015)
Old 07-10-2012, 03:32 AM   #40
DarrenDriven
NW Region Moderator
Ah, jacking the control arm up seems like the right way to do that. I edited the DIY to reflect that. Good idea.
Old 07-10-2012, 08:38 AM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Jeff
It's a good idea to put load anywhere you tighten a bolt going through a suspension bushing
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-10-2012, 08:40 AM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Jeff
Or lower it on ramps, etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 01:41 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 11:07 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
