Old 07-14-2016, 11:31 AM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Also look for loose bolts
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 07-14-2016, 06:34 PM   #16
lee1rbc
lee1rbc's Avatar
OK, so your running wheels with a 38mm offset plus, 20mm spacers. So you have basically added 30mm or 1.1 inches of positive scrub. The car orig. has 19mm or .75 inches of scrub. So now you are running 2 inches of positive scrub. (your tires are 2 inches outside there pivot point).
So when you are giving it gas or driving at a high speed that requires more gas, your extra scrub is pulling (toeing in) causing your car to only want to go straight.
Now, when you hit the brakes, it does the opposite and pulls back (toes out) causing your car to show you its best dance moves (dangerous!).
As for turning better to the left then the right is probably an alignment issue.
Do you have camber plates and camber bolts? I would set the camber plates 1 inch in (- camber) on each side, and then adjust the camber bolts out +camber. Then get it aligned. That should reduce your scrub from 2.00 inches to about 1.5. If it was me I would also change your front spacer from 20 to 10mm. Then you would be at 1.1inches stable and quick steering.
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
lee1rbc is offline   Reply With Quote
NY WTB; Plethora of parts mulekr1 Want-To-Buy Requests 1 12-21-2015 04:52 PM
K&N CAI issues. All help welcome Matty B Engine, Exhaust, Transmission 6 11-01-2015 05:22 PM
Anybody Have Zero Issues? Don Ivey Scion FR-S / Toyota 86 GT86 General Forum 129 03-25-2013 02:14 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 09:15 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
