86WORX
Old 07-01-2016, 05:04 PM   #15
stevesnj
stevesnj's Avatar
Here are the install instructions, You'll need to have all the proper tools.
My 2016 Build thread
Old 07-01-2016, 05:49 PM   #16
MJones_RB
MJones_RB's Avatar
Here's a long discussion of the pros & cons of TRD's short throw shifter adapter. The pros are that it's relatively cheap and easier to install than a true replacement shifter, such as the Kartboy. Cons are that it's really a temporary solution, the main bolt can loosen over time, and some people complain that it negatively affects the shifter's feel.
MJones_RB is offline   Reply With Quote
Old 07-01-2016, 05:59 PM   #17
Originally Posted by FNCrazy View Post
I've never used any kind of short throw shifter. Is it worth it? What are the cons?
Thanks!
Sent from my SM-G935V using Tapatalk
Again???
MJ found it easy enough.
In other words not an "upgrade" and a change just to change in FN's case.
MJones_RB (07-02-2016)
Old 07-01-2016, 06:06 PM   #18
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by FX86 View Post
if you get a short throw shifter make sure to get a short throw dipstick...man that thing does wonders
What is that? Googled... sent to Civic forums. My browser and PC said no no and turned off.
Packofcrows is offline   Reply With Quote
The Following User Says Thank You to Packofcrows For This Useful Post:
Old 07-01-2016, 07:20 PM   #19
White64Goat
Name:  short throw.jpg
Old 07-02-2016, 03:06 AM   #20
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Again???
How does the JDM TRD short shifter compare to the TRD USA shifter? It wouldn't have that loose bolt issue that the TRD USA one had would it
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 07-02-2016, 07:00 AM   #21
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
No it won't, cuz Japan one is the entire shifter assembly. Obviously cost quite a bit more, but quality is much better.
Old 07-02-2016, 01:02 PM   #22
stevesnj
stevesnj's Avatar
[URL="http://www.ft86club.com/forums/showthread.php?t=68866&highlight=short+throw"]the main bolt can loosen over time, and some people complain that it negatively affects the shifter's feel.
That's pretty much been resolved by using high strength loctite and using the proper torque on that bolt. I've had mine a year and no loosening whatsoever
The Following User Says Thank You to stevesnj For This Useful Post:
Old 07-02-2016, 01:58 PM   #23
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Red loctite will get the job done to keep the bolt from coming loose. Of course sometimes I think I should have just got the JDM short shifter instead.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
stevesnj (07-02-2016)
cae ultra shifter vs short shifter jdmblood Engine, Exhaust, Transmission 22 01-14-2016 12:19 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
TWM short shifter HyperTech Scion FR-S / Toyota 86 GT86 General Forum 13 09-22-2014 10:12 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 02:24 AM
wtb: short shifter natesparxxx Transmission and Driveline 2 03-20-2014 10:03 AM
