| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Drives: 14 BRZ Red premium
This is the newer board. If the board look the same follow the instruction. If the board look different, you might have to dig through the original Valenti alternate wiring post I dont think there are any of the old version on sale right now anymore. |
#16 |
Drives: 2013 Firestorm FRS
just did this mod again today!
#17 |
bump-Need your help!
So, it seems that if you have switchback turn signals up front and the flasher relay, it MIGHT cause an issue with the 4th brake light/blinking. This is a current/load issue-I'm sending pm's to people who might have done this mod according to my video to confirm! |
#18 |
good news! I found an "older" valenti rear light, with slightly different wiring when you open it up. Its the same as some of the other ones I've seen floating around.
Got the wiring figured out, will have photos and video shortly! |
#19 | |
Last Starfighter
Drives: 2016 FR-S Series 2.0
#20 |
Drives: 2015 Series.Blue
I have one of the older lights with a different wiring from the videos. It sounds like the wiring described in the original thread but those pictures have gone dead and I wanted to be sure. @continuecrushing, were you able to get a video or pictures with the old light you found?
#21 |
Last Starfighter
I'll let @continuecrushing confirm but I'd say you just do the same thing with the blue and red wires. Disconnect them and wire them directly to each other to isolate the V. Then move orange wire over for blink and solid red assuming it works the same as the new version. Just some guesswork though.
Sent from my SM-G930T using Tapatalk |
| The Following User Says Thank You to djwishbone For This Useful Post: | qitorr (09-06-2016) |
#22 | ||
| The Following User Says Thank You to continuecrushing For This Useful Post: | qitorr (09-06-2016) |
#23 |
Last Starfighter
Thanks again for the video. I wired up mine this weekend and this post let me do exactly what I wanted. I have switchbacks inbound so I can test that out. Not sure why that would have anything to do with this circuit. I know some people were having some odd unrelated issues with cheaper led switchbacks.
#24 |
@continuecrushing any updates on this?
#25 |
@continuecrushing you had mentioned possibly getting to this over the holidays. Any luck?
#26 |
Drives: 2015 Ultramarine Scion FR-S (MT)
Mine works how it should once re-wired when off, v turns on with lights, triangle flashes. But once the car is on, everything still works, except the triangle. The triangle turns on dimly and doesn't flash. What exactly am I looking at here as the issue? Would it be the ground?
#27 |
Drives: Hot Lava GT86
Hi,
Is there a way to wire it so the middle triangle doesn't blink but still lights up when I turn on the rear fog light ? Thanks |
#28 | ||
Sure, set it up like wiring 3. BUT, the red wire that comes from the 4th brake light needs to go to the (+) of your rear fog lights. I don't have a rear fog, so I don't know where that wiring is/which wire it is. |
| Tags |
| valenti, valenti mods, valenti wiring |
| DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) | BirdTRD | DIY (Do-It-Yourself) Guides | 17 | 11-06-2017 09:42 PM |
| WTB: Valenti 4th Brake Light | thecarfilmer | Want-To-Buy Requests | 1 | 05-22-2016 08:50 PM |
| Valenti 4th brake light vs Valenti Style brake light? | JGalp | Electronics | Audio | NAV | Infotainment | 9 | 03-24-2016 06:48 PM |
| SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light | AtlasMick | Exterior Parts (Aero, Lighting, Etc.) | 8 | 03-07-2015 07:51 PM |
| how to turn that rear triangle reflector into working brake light | chris's fr-s | DIY (Do-It-Yourself) Guides | 29 | 06-10-2013 08:25 AM |
