#15 |
Drives: 2015 Firestorm Scion FRS
is your car lowered? Mine's lowered by an inch and I have a beatrush underpanel too but I don't believe I have ever scraped the underpanel enough that it actually hit the valve.
#16 |
Boost Creep
Drives: 2016 HyperBlue BRZ
Around an inch lower. I still have a finger gap from tire to fender all around.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#17 |
ya for a lowered car, the drain valve might not be a good option. I have the shorty and it doesn't extend past the skid plate. I am also only about .8" lowered and I don't really worry about it since I will be scraping my front bumper first before anything touches the valve.
however, always expect the unexpected and not everything is under your control
#18 |
hey you, yeah you <3
Drives: 2014 37J FR-S
| The Following 3 Users Say Thank You to Packofcrows For This Useful Post: |
#19 |
Boost Creep
![]() ![]() Pretty sure the pan is dented. Took lock pliers to remove it. Seems to hold oil though, which is weird.
| The Following User Says Thank You to Luftwaffel For This Useful Post: | Mr.Impreza (06-28-2016) |
#20 |
Drives: 2014 BRZ Limited 6MT
that looks like it could leak pretty easily the way the dent is actually under that crush washer and drain plug. time for a new pan IMO. A few people recommended this to me when i joined the forums and this is just another reason i choose not to run it. Just adds more room for errors like this.
#21 |
Boost Creep
Eh, it holds oil fine and it was running for four days with no issue after it happened, so I'm not really freaking out, but a new pan will be on the way soon.
| The Following User Says Thank You to Luftwaffel For This Useful Post: | Ultramaroon (06-28-2016) |
#22 | |
Yep, that drain plug looks to be sitting sort of wonky ..... ![]() humfrz |
#23 |
Drives: 2015 BRZ CWP
Just replaced mine with a magnetic drain plug cause I was always worried about that happening...
#24 |
Drives: 2014 Scion FRS monogram series
Mine's more than an inch lower. I track the car once or twice a year and several canyon runs and never had a single problem with the fumoto short nipple scraping. Either get the short nipple one or put the stock one back.
#25 | |
I will say on my other car (VW GTI), I must have come close to nicking the valve on the street because I usually leave the plastic nipple on it and this past oil change it was gone. No visible damage to the valve. The Fumoto placement on the GTI makes it hang lower, but in any event it's definitely good be careful with the valve on the street.
2022 BRZ Build 2013 FR-S Build |
#26 |
Just another BRZ owner
Drives: 2014 Subaru BRZ Limited MT
I have the no nipple one and the whole underside of my car is scraped up (lowered ect) without it ever hitting the valve. I've been paranoid about it for a while but I still love it though. Makes my oil changes real quick @ home.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz |
| The Following 2 Users Say Thank You to Romanov For This Useful Post: | Simply_the_best (06-28-2016), Ultramaroon (06-29-2016) |
#27 |
Drives: 2016 Oceanic, "base" model
Sigh. When the Fumoto first came out 30+years ago, I liked the concept but the oil pan on my Celica was way too low and the valve stuck out even lower. So I didn't get one.
I am amazed they are still around since I am sure there have been quite a few of these kinds of hits. When I got my FRS, I noticed how recessed the oil drain plug was due to the flat four engine. So, I thought I could get one now and I did. Now, I have to re-think about installing it because I am paranoid... |
| FS: Fumoto Valve | jvenetto | Engine, Exhaust, Bolt-Ons | 6 | 10-01-2015 08:16 AM |
| EZ oil drain same as Fumoto? | wbradley | CANADA | 18 | 06-15-2015 04:40 PM |
| Fumoto valve in the winter? | Muskokan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 02-25-2014 01:06 PM |
| Question about Fumoto valve | Bleevin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 04-18-2013 10:27 AM |
