#71 | |
Rambling Man
Drives: 2013 FR-S 6MT - In Heaven Now
Sent from my SM-G935V using Tapatalk |
#72 |
Drives: 2015 CWP BRZ Limited
Realistically speaking, you'd like more negative camber in the front than in the rear. How much depends on your tire wear patterns, but you can go up to -2.5 to -3 without a real effect on tire wear. With 1 set of camber bolts, you should see around -1 to -1.5 degrees of camber.
| The Following User Says Thank You to jawn For This Useful Post: | FNCrazy (06-30-2016) |
#74 |
*Some really cool title*
As I said before, the car is a lot more planted on the road. I don't feel any swaying on the turn-in like I did before, and I find myself staying on the throttle during moments where before I would've feathered it.
You can only go so far with springs, though. My primary goal with them was to reduce the wheel gap which was accomplished, the improved handling was an extra perk. If you really want better handling you would need to go into further suspension mods like sway bars and strut braces, and wider wheels are a must. |
#75 |
I really don't see the point in doing anything to the stock wheels. Imo new wheels are pretty much a required mod for this car so you would probably wait to adjust camber until after you replace them. And get coilovers too.
#76 |
Rambling Man
Definitely going for lowering that gap. If I ever decide to put it on the track, then I'll be getting some coilovers!
#77 | |
Drives: FRS
a sticky 225 width tire will outperform a less-sticky 245 width tire.
#78 |
Drives: 2015 BRZ
If you want safe springs that work well with stock struts/shocks just go with Hotchkis, RCE Yellow, TRD, Swift Sport springs or Eibach pro-kits.
| The Following User Says Thank You to Vital For This Useful Post: | choiboie (06-30-2016) |
#79 |
Drives: 2013 Fr-S UltraMarine
#80 | |
#81 |
| Lowering, with lip kit? | YamahaR86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 11-17-2015 08:09 PM |
| Lowering my frs | mikltov | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-14-2014 02:30 AM |
| Lowering my 86 | slord93 | AUSTRALIA | 13 | 10-14-2014 01:54 AM |
| I'm lowering my car soon.. | USN.Spence | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-18-2014 02:38 AM |
| lowering the car | jarviz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 11-02-2012 04:49 PM |
