#15 | |
Like suggested above, I reckon it's time to take it into the dealer and have them take a listen to that noise. While you're there, might as well have them fix the idle situation. If they try to tell you that both are "normal" ....... just tell then to contact either @Ultramaroon or humfrz and we will beat cyber knots on their head till they understand ........ ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Cole (06-19-2016), Ultramaroon (06-19-2016) |
#16 | |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Tcoat (06-19-2016), Ultramaroon (06-19-2016) |
#17 |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
#18 |
fabulous
That opens a can of worms. If one is comfortable with learning how to tinker with their ECU, great, but it's a steep learning curve with some potentially catastrophic pitfalls. Check out the links in Steve's sig.
#19 |
Yeah, not planning on going that route until I have more mods on the engine/exhaust/etc, just wasn't sure if there was an easy way to tell the calid of the ECU. I know Subaru messes with the flashes from year to year, and that's why the 08-11 STI's blew motors left and right but the 12-14s didn't.
#20 | |
Torque app (free) on android with a $5 blutooth adapter will do it just conect and select adapter status in torque app |
| The Following 3 Users Say Thank You to steve99 For This Useful Post: |
#21 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Ironically, my bluetooth OBD2 wont pair with my new phone for some reason. I need to buy another one so I can run my torque.
Im pretty sure my stock map is B01C |
| The Following User Says Thank You to Kostamojen For This Useful Post: | Ultramaroon (06-19-2016) |
#22 | |
fabulous
As always, many thanks, Steve. You are exceedingly patient and generous.
#23 | |
Drives: '15 BRZ RA
I saw that you have the TRD intake. There were people saying that it gives a leaner afr and if you install it is a good measure to adjust the ecu. Is this part covered by your guarantee or is your guarantee already over? Do you have other changes? |
#24 |
Ive had the TRD intake on the car for almost 3 years.
#25 |
Drives: '15 BRZ RA
Go to your dealer and let us know the result. Good luck!
#26 | |
Waited 5 years for this
Drives: '18 MX-5 Club
Another thing I learned from this forums is this noise gets louder after a transmission oil change. I had throw out bearing and pressure plate replaced a little less than a year ago. I was expecting the noise to get louder because the transmission oil would be changed also. As I expected, it got louder. But I didn't worry about it since I knew that would happen. Kostamojen mentioned he got throw out bearing and clutch disc replaced a couple months ago. That means the transmission oil was changed a couple months ago. This might be why he didn't notice the noise before, but only noticed it recently. I hope Kostamojen's issue is nothing, because mine makes the same noise doing the same thing. |
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | chaoskaze (06-21-2016) |
#27 |
Drives: 2013 FRS
Interesting. I just changed my clutch assembly (including throw out bearing) and resurfaced my flywheel and added a new pilot bearing, along with new motul gear oil and I am having this same issue now.. following. I am bringing it to the dealer tomorrow to get the new ecu flash to see if it smooth's things down a bit. Also the noise in my car gets quieter when I turn of the A/C.
#28 | |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Knocking Noise Near Driver Seat | N1rve | Issues | Warranty | Recalls / TSB | 21 | 09-21-2016 11:36 AM |
| Knocking noise from LSD after FD swap | Toyota86.ir | Engine, Exhaust, Transmission | 15 | 11-08-2015 04:02 AM |
| Noise when idle (not Crickets) | hanabie | Issues | Warranty | Recalls / TSB | 8 | 10-18-2013 09:58 PM |
| Idle Sound Click/Noise | FRS_Jack | Issues | Warranty | Recalls / TSB | 4 | 10-13-2013 10:26 PM |
