#15 |
Drives: 2JZ FRS
agreed. unless you have way more than normal coolant pressure, that'll probably hold forever. if you have high coolant pressures, you have much larger problems lol
| The Following 2 Users Say Thank You to spitfire481 For This Useful Post: | themadscientist (06-03-2016), Ultramaroon (06-05-2016) |
#16 |
Hotlink Terrorist
Drives: 2015 WRB BRZ Spec S
That's what I'm thinking. Since my new turbo is not water cooled I have a free threaded hole into the water jacket where I could stick a pressure sensor. I have plenty of extra gauges so I could use an oil or fuel pressure meter and relabel it OH SHIT!
#17 |
Drives: whiteout, dark tint
I mean, you have a replacement block coming. I'd cross my fingers, keep it on stock psi and keep the AAA card handy
#18 |
Hotlink Terrorist
That could be a problem since I'm going to be bolting one of these on it.
| The Following User Says Thank You to themadscientist For This Useful Post: | 86kahl (06-04-2016) |
#19 | |
From my experience your "Oh shit" gauge may as well be labeled "too late anyway" since if the repair fails bad enough to register on a gauge there will be no going back. You said a new block right now is not an option anyway so throw it in, drive it and wait for the cloud of steam and oil that may or may not show up.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (06-05-2016) |
#20 |
Hotlink Terrorist
I don't care about the block. I just want to catch it before the rotating assembly gets hurt. I can always reuse it in the new block.
#21 |
Drives: BRZ + Ducati M796
Is that an area under lots of pressure? I can't tell.
Don't underestimate JB weld. In the welding industry, epoxies are supplying labor-cheap welds over conventional mig/arc/tig welds, and are actually stronger, last longer and have less of an error/fail rate. |
#22 |
Hotlink Terrorist
It's part of a larger, um "scheme" if you will. There is epoxy smeared inside the water jacket and there are cracks running across the deck. It's really bad.
#23 |
fabulous
JB Weld is some amazing shit. Surface prep is key. If done right, I wouldn't be surprised if something else let go before that repair.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (06-05-2016) |
| Hlep. I failed. | Shaisters | Northwest | 14 | 06-02-2016 11:56 PM |
| Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 07:27 PM |
| Failed login notification | griffinnn | Site Announcements / Questions / Issues | 6 | 02-18-2015 09:21 PM |
| WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 02:26 AM |
| WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 06:21 PM |
