86WORX
Old 06-05-2016, 07:54 PM   #57
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Originally Posted by JFunk View Post
Got the supplies but I've read the paint in the front is very thin and delicate
I don't think it's any thinner or more delicate than on the rest of the car. It's just that the front takes more road-borne projectiles (rocks, grit, stray cardboard boxes that you can't avoid) than the rest of the car. Take your time and if you use heat keep it moving and you should be fine.
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
Old 06-05-2016, 08:25 PM   #58
Originally Posted by mdm View Post
ib4 @Tcoat rants that twin paint is just paint and does not disintegrate from looking at it
That one is on a thee month rotation so good for a while yet.
Ultramaroon (06-06-2016)
Old 06-06-2016, 12:36 AM   #59
humfrz
Even when I'm not in school I'm getting tested. Il be ready
OK, @JFunk here is the promised test. Good luck!
humfrz
This is a timed test, you have till midnight tonight PST to complete it.
NOTE: Change 1 ... to midnight PST.
Yes, this is an open book test.
1. If your remote button nor your inside release lever will unlock the trunk, what is going on and how do you rectify that situation .. ??
2. If your engine sounds like a bunch of crickets, especially when you are going through a drive through, what is making that sound and what (if anything) can you do about it .. ??
3. What is the correct tire pressure for the OEM tires .. ??
4. How often/how many miles, should the engine oil be changed .. ??
5. Can the engine overrun the rev limiter, if so, under what conditions ..??
6. About how many gallons of gas are left in the tank when the low fuel light goes on .. ??
7. There are only two substances which should be added to the coolant tank .. what are they .. ??
8. When you pull up to the gas pump, which button do you punch .. ??
9. What is the first thing to check if you have an electrical problem (other than a dead battery) .. ??
10. There are four fluid levels that should be checked (from under the hood), what are they .. ??
Get set ....... GO!
The Following 4 Users Say Thank You to humfrz For This Useful Post:
DarkSunrise (06-07-2016), Impureclient (06-06-2016), mdm (06-06-2016), Tcoat (06-06-2016)
Old 06-06-2016, 01:03 AM   #60
JFunk
JFunk's Avatar
Drives: 2013 Scion Frs
Picking up my FRS tomorrow
1.
JFunk is offline   Reply With Quote
Old 06-06-2016, 01:04 AM   #61
JFunk
JFunk's Avatar
humfrz
2.If your engine sounds like a bunch of crickets, especially when you are going through a drive through, what is making that sound and what (if anything) can you do about it .. ??
3.What is the correct tire pressure for the OEM tires .. ??
4.How often/how many miles, should the engine oil be changed .. ??
5.Can the engine overrun the rev limiter, if so, under what conditions ..??
6.About how many gallons of gas are left in the tank when the low fuel light goes on .. ??
7.There are only two substances which should be added to the coolant tank .. what are they .. ??
8.When you pull up to the gas pump, which button do you punch .. ??
9.What is the first thing to check if you have an electrical problem (other than a dead battery) .. ??
10.There are four fluid levels that should be checked (from under the hood), what are they .. ??
Get set ....... GO!
1. The trunk deactivation button is active and to fix it I just have to deactivate it by pressing it
2. Fuel pump, and nothing
3. 32
4.7500
5. You can't
6.
7.
8.93 or if there is no 93 91
9.
10.
Did my best couldn't at this hopefully the ones I did answer are good or even close.
The Following User Says Thank You to JFunk For This Useful Post:
Tcoat (06-06-2016)
Old 06-06-2016, 01:31 AM   #62
humfrz
Not bad, so far, there @JFunk ......
1. Correct
2. Correct.
3. Close (if you check the decal in the door sill you will see that it is 35psi (60 psi for the spare).
4. Correct. (or 7.5 months, which ever comes first)
5. NOT correct. True the engine cannot exceed the rev limiter ..... going up ... but, it can ....coming down. For example if you are all revved up in 5th gear and are trying to downshift to 4th and mistakenly get it into 2nd, the engine will over rev. That's called a "money shift".
6. No Credit. How about 2 gallons (give or take some).
7. No Credit. The answer is either the blue coolant from Subaru or distilled (or demineralized) water.
8. Correct. The highest octane they have on the standard pump.
9. No Credit. The first thing to check is whether the fuse (or other type breaker) for that circuit is fried.
10. No Credit .. Coolant level, crankcase oil level, clutch/brake fluid level and battery electrolyte level.
You did pretty darn good .......
The mid-term exam will not be as easy .......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
JFunk (06-06-2016), Tcoat (06-06-2016), Ultramaroon (06-06-2016)
Old 06-06-2016, 01:39 AM   #63
Ultramaroon
fabulous
Ultramaroon's Avatar
This quiz is great! Everyone should take it.
humfrz (06-06-2016), JFunk (06-06-2016), Tcoat (06-06-2016)
Old 06-06-2016, 01:42 AM   #64
JFunk
JFunk's Avatar
Lol hopefully I get to know the car better, really want to be a frs/brz expert seeing as I expect to be with this car for a long time
Old 06-06-2016, 02:17 AM   #65
WryGuy
Drives: 2014 FR-S Argento, 2003 Celica GT
Love the quiz. @JFunk did better than I would have.
#10 extra credit - window washer fluid
Note on #7... Minimize (or none) the use of water (distilled or otherwise) as it promotes rust particularly with sustained high temps.
WryGuy is offline   Reply With Quote
The Following User Says Thank You to WryGuy For This Useful Post:
JFunk (06-06-2016)
Old 06-06-2016, 02:54 AM   #66
humfrz
Well, you're on your way ....
Hang around here and you will learn lots about your car.
humfrz
Old 06-06-2016, 03:07 AM   #67
humfrz
Good point about also checking the windshield washer fluid level .....
About topping off the coolant level.
Yes, I agree, 100% straight tap, demineralized, distilled or deionized water is not good for modern automobile cooling systems.
However, since the concentrated Subaru blue stuff is about 5% water and the premixed blue stuff is about 50% water, I maintain that if you're just "topping off" the system occasionally, it's OK to use distilled/demineralized or deionized water.
humfrz
Old 06-06-2016, 03:09 AM   #68
Ultramaroon
fabulous
humfrz
agreed
humfrz (06-06-2016)
Old 06-06-2016, 05:04 AM   #69
WryGuy
humfrz
humfrz (06-06-2016)
Old 06-06-2016, 09:48 AM   #70
raven1231
Well guess il just do it and not put thing in my head lol
It's fine just take it easy and don't pry too hard.
JFunk (06-06-2016)
manual, newbie
Search this Thread:
Advanced Search
Picking up a Scion FRS tomorrow! Olivervaldez Scion FR-S / Toyota 86 GT86 General Forum 46 12-23-2013 11:43 PM
Picking up BRZ tomorrow... sub_stance CANADA 17 03-25-2013 01:48 AM
Picking up my FRS Tomorrow! Tips please! peachsnow Scion FR-S / Toyota 86 GT86 General Forum 35 12-15-2012 12:47 AM
Picking up my Asphalt AT tomorrow! pixel67 Scion FR-S / Toyota 86 GT86 General Forum 21 09-19-2012 02:58 PM
Picking up my Asphalt FR-S tomorrow! markmatley Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2012 10:34 PM
