#43 | |
Drives: Scion FR-S, Scion tC
"One thing we noticed is that the car has a fairly low roll center and if the car is lowered much at all the lower control arms will point upward with the roll center quickly ending up below ground. This will do two things that are not so great; the car will have a large roll couple and a strong tendency to roll which must be countered with stiff springs and/or swaybar. However the FR-S does have a very low center of gravity due to the low slung boxer engine so perhaps this may still be tolerable. Next due to the angularity of the lower arm when lowered, the front suspension will lose negative camber under roll which will reduce grip and even lead to understeer in a low car unless a lot of static negative camber is dialed in or roll is greatly reduced with stiff suspension. Big negative camber hurts braking traction and causes the car to be road crown sensitive and tramline on cracks and grooves. Being too stiff hurts mechanical grip. Whiteline if you are reading this, this car really needs your long shank ball joints and tie rod ends to correct the roll center. Make some right away please. Maybe your Subaru kit might fit. The best solution before the aftermarket responds might be to not lower the car more than 1.5” or so." -Mike Kojima http://www.motoiq.com/magazine_artic...cion-fr-s.aspx What's a roll center? Fairly good reference article http://www.onedirt.com/tech-stories/...r-roll-center/ |
#44 | |
Drives: 2013 Whiteout Scion FRS
#45 |
1.5 inches is a lot and I would recommend the whiteline roll center kit at that point.
It's much easier to deal with things if you stick with a medium/milder drop. - Andrew
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Adam_L (12-06-2016) |
#46 | |
http://www.whiteline.com.au/product_..._number=KCA326 |
#47 | |
Drives: 2013 Scion FR-S Whiteout-M
#48 |
Drives: Wish I had one.
How do you address bump stop engagement with certain coilovers, as bump stops do tend to increase spring rates as they engage?
#49 |
Drives: V12
#50 | |
Thanks for your quality of insight though. Appreciate the red font .
#51 |
Drives: V12
You dont engage the bump stops...Theyre there as a last line before coil binding. There is no tech wizardry in them, just a harsh stop before that point. You're doing it wrong if you have to hit them or sit on them for some reason.
| The Following User Says Thank You to kiks For This Useful Post: | Surok (09-24-2012) |
#52 |
Drives: Scion FRS Raven
Hey Moto what brand would you recommend if you just want a lowering springs?
#53 |
| The Following User Says Thank You to BRZranger For This Useful Post: | Racecomp Engineering (08-30-2012) |
#54 | |
And we're near Baltimore.
![]() Quote:
- drew
Website
#55 |
making a car look good and handle good are two different things
Moto-p has my attention, man knows what he is doing subscribed |
#56 | |
Look up "bump stop tuning." I'm not saying you HAVE to ride them the whole time, but if/when they engage, they act as a secondary spring, which actually has a benefit to the suspension's handling. From Modified: "As for bumpstop use on race cars, according to Peter, Often they are used truly as just a bumpstop, but the progressive spring rates can be used to help cars when they are riding the curbs or jumping them (as is often seen). In a controlled racing formula like a spec or one-make series where every car must use the same shocks and springs, the bumpstop becomes the one tunable spring on the car. It could even be in contact at ride height if a long enough bumpstop is used or the main springs are short enough. Bear in mind that the rate will be rising steeply into compression but will be dropping off into rebound, so the car is likely to roll up a lot on the inside rather than just down on the outside." As you told me, "read and read some more," I strongly urge you to do the same. I used to think that bump stops just prevented the shock from totally bottoming out and destroying itself, but I learned later that it serve an underlying purpose. It really does factor in a perfect suspension equation. Last edited by WestZ; 08-30-2012 at 12:08 PM. |
| The Following 2 Users Say Thank You to WestZ For This Useful Post: | 20valvewynn83 (09-26-2012), fatoni (09-25-2012) |
| Remotely lower windows with key fob? | Kido1986 | BRZ First-Gen (2012+) -- General Topics | 25 | 07-16-2012 11:11 PM |
| Lower car 1.5 - 2.0 inches | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-23-2012 10:30 PM |
| BRZ spotted in lower mainland! | kidgogeta | CANADA | 21 | 04-29-2012 03:20 PM |
| Stock ride height or lower? | StevenDavisPhoto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 168 | 01-31-2012 11:58 AM |
| Lower ride height in NYC? | blur | NY / NJ / CT / PA | 9 | 01-19-2012 07:31 PM |
