#15 |
Drives: Strawberry Pie
Good post Moto-P, I'm glad to see there are other people that really stay true to keeping proper suspension geometry and ride dynamics. I have been, and still am, thinking long and hard about what I want to do to the suspension since for most of us our FR-S wont be a track only car, we still have to get to work without a stiff back all day
#16 |
Drives: 2015 Mustang GT (on order)
I fail to see how installing stiffer suspension with the stock tires will induce understeer. Sure, if you mess with the F/R spring rate ratio, increasing the front drastically more than the rear, then I could see this happening. But if you increase the rates such that the F/R balance stays the same, or even makes the rear more aggressive than it is now, than why would it understeer more?
#17 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
#18 | |
Random Internet dad
Drives: 2013 FRS and 2010 Mini Cooper
I'm trying to explain how the rsr coils work to him, but he doesn't seem to understand that they aren't ever off of the shelf unless a shop buys them that way. You talk to RSR and choose the spring rates, 6k-9k for front and back, and then they ship them to you in that configuration. Moto and I both have 6k F 7k R and it feels extremely close to stock, but better. The balance is still there, the. At really eats away at the curves still. |
| The Following User Says Thank You to denkigrve For This Useful Post: | 20valvewynn83 (09-26-2012) |
#19 |
What's the advice on tire setup. If aesthetically pleasing springs aren't available for appropriate balance, would increasing tire width be advisable. Would a 245 tire fit well with stock suspension and maintain balance?
#20 | |
Drives: Many types of cars in R&D.
This is just an example in ONE vector and direction, but this holds true for all axis of the motion, and the car needs to transfer weight back and forth, and side to side to make this happen. The FRS/BRZ is a very light and centered car with low center of gravity, thus making this very difficult since there isn't a huge overhanging weight like most cars. While this is a trait that allows physically, a very acute and responsive car, it is also very sensitive to changes like this. This is why, overly stiff suspension on the FRS/BRZ tends to create less ability to motion the car correctly when changing vector of travel, and also the direction of the car, and wheels, if the tires can't hold the G-forces necessary to do it efficiently and readily. Tada's design of equipping it in such way and balancing the car, with mild grip tires is exactly this, to challenge the driver to develop the skills to do this, and to give gratifications to those who can drive it well, and be rewarded the speed that comes along with it. That is what a true sports car should provide.
Moto Miwa
www.club4ag.com R&D Driving Engineer, Product Planning Consultant Consulting Member at Cusco, OEM+, RS-R. www.club4ag.com |
| The Following 14 Users Say Thank You to Moto-P For This Useful Post: | BadCompany235 (07-05-2012), Black Tire (01-01-2015), dattran86 (12-13-2016), Fett4Real (07-25-2013), FRSGeek (11-24-2013), FT_86_SM_GP (07-11-2015), gonzo (01-04-2013), krayzie (06-16-2016), liquidsky44 (09-10-2012), Nasty Sausage (05-29-2014), raul (09-25-2012), sirus (08-07-2012), Vic4uf (06-13-2016), whataboutbob (08-27-2012) |
#21 | |
Poor driving skills is a whole different matter as this is simply the inability for the driver to feel and maintain the contact patch at nice, gradual, stable level of grip at any given speed and abrupt and violent inputs and rebound forces, creating a havoc on the dynamics of the vehicle. This is also why I recommend a long-stroked (taller) suspension with soft, compliant, and slow moving parts on the suspension for novice drivers, so all of the dynamics of the car are accentuated, and things happen slowly and more predictably. Fast, stiff, grippy setup requires the driver to be much more sensitive, quick, and extremely accurate, and feed-backs happen a lightning speeds where they might not understand at all, what is happening with the vehicle as controls are lost.
Moto Miwa
#22 | |
I think to keep the inherent balance of power and handling of the FRS/BRZ, the tire size change should be minimal, regardless of going with 16", 17" or 18" to keep the same diameter, and relatively small widths. 225's and 235 width should be plenty for a light FRS, to be fun and agile as universal car. Going beyond this only if there is a specific purpose in various field of REAL racing.
Moto Miwa
#23 | |
Anyway, back to topic, that FRS should have a compliant balance of suspension, that is closely matched to the tires, and no more. For this car, we just need to find that balance where the driver skills are up to the task, before making anything "higher performance" as this car is so demanding of the driver, that if the car is overbuilt for the driver, he will simply be going slower in a higher tuned setup.
Moto Miwa
| The Following 7 Users Say Thank You to Moto-P For This Useful Post: | ill86 (07-05-2012), krayzie (06-16-2016), meeks (07-30-2012), Nasty Sausage (05-29-2014), RaceR (08-06-2012), samsam5886 (07-05-2012), Vic4uf (06-13-2016) |
#24 |
#TrackAddicts
Drives: The Dipped Car
totally agree. my last track day all i worked on was braking and loading for cornering. this car is faster using weight transfer and tire slip without a doubt. the oe setup is very good at accomplishing this and when you do it right you know it because you get the tires singing but not screaming. i also learned this car is really good at letting you know when you do it right. if you over brake and have to unload the front a little early it totally messes up the cornering rotation and exit speed. blindly, i'll agree that 20-25 mm of drop would be ok if you're doing it for further cog reduction or aesthetic reason. i really like the stock setup, it's fun and educating. they only thing about changing to a stickier tire is if you don't have a well developed sense of weight shift, a sticky tire will stunt development of it as you'll stay closer to the grip side of things instead of walking that grip slip line. getting the car loose tells you alot about what you are doing. i spun twice on track this wknd working on my trail braking and front loading.
for my purposed the stock tires are good. when i go to a different compound i will either stay at 215 or only go up to 225. but that wont be until i get more consistent with this car. and i hope my coilover choice doesn't affect my learning pace.
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance Chadbee Photography / Passion Moves Photography |
#25 |
Saving them pennies...
I really liked progress coilovers on my B13. They are only height adjustable. Progress took the time to tune the shock and spring combo so the customer couldn't mess up the handling of the car.
#26 |
Drives: Honda S2000
To me it's not about the wheel gap... it's about the wheel being concentric with the fender! And the FR-S/BRZ does that quite well, so IMO the FR-S/BRZ isn't too high at all. The ride height is perfect. In fact, lowering the car will ruin the already concentric wheel/fender look from the side. Who else agrees with me on this? There's no need to worry about scraping your car either as a bonus! And besides, the car's center of gravity is already low enough.
| The Following 5 Users Say Thank You to samsam5886 For This Useful Post: | atledreier (07-30-2012), Jose_Timberlake (06-20-2014), Mikepage (11-29-2012), raul (09-25-2012), soconfoozed (07-30-2012) |
#27 | |
#28 | |
Drives: iG FR-S
I enjoy reading your posts as they are on point and educational. I believe that suspension tuning is an art, not always a science.
| The Following 2 Users Say Thank You to ill86 For This Useful Post: | meeks (07-30-2012), Nasty Sausage (06-02-2014) |
| Remotely lower windows with key fob? | Kido1986 | BRZ First-Gen (2012+) -- General Topics | 25 | 07-16-2012 11:11 PM |
| Lower car 1.5 - 2.0 inches | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-23-2012 10:30 PM |
| BRZ spotted in lower mainland! | kidgogeta | CANADA | 21 | 04-29-2012 03:20 PM |
| Stock ride height or lower? | StevenDavisPhoto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 168 | 01-31-2012 11:58 AM |
| Lower ride height in NYC? | blur | NY / NJ / CT / PA | 9 | 01-19-2012 07:31 PM |
