Old 05-28-2016, 01:10 PM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Passener side window clunk
Noticed when my girlfriend shuts the door sometimes or opens it the window makes a clunk noise. I figured i should look into it. Open that side door and the window is pretty damn loose, going to pull the panel off and look into it. anyone else come across this?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 05-28-2016, 02:24 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yes. Great patience is required to get it right. Good luck.
File Type: pdf BRZ_door_window_adjustment_procedures.pdf (127.6 KB, 420 views)
Old 05-28-2016, 02:59 PM   #3
nickmerronesucks
Ned flanders
What needs paitence
797Performance.com
Old 05-28-2016, 04:53 PM   #4
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
I had this issue years ago. They didn't put lock tite on the bolts that secure the window tracks and regulators, just hope you still have the bolts in there and can reinstall without much problem. With blue lock tite this time.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Respect BRZ is offline   Reply With Quote
The Following User Says Thank You to Respect BRZ For This Useful Post:
nickmerronesucks (05-28-2016)
Old 05-28-2016, 04:54 PM   #5
nickmerronesucks
Ned flanders
Awesome i did have the windows greased or whatever about two years ago. Wonder if for some reason they unbolted them and dodnt tighten them
797Performance.com
Old 05-28-2016, 04:54 PM   #6
Respect BRZ
Old Mechanic
Also when you get done there pull apart the drivers door and do all bolts you find there too.
Old 05-28-2016, 04:55 PM   #7
nickmerronesucks
Ned flanders
Drivers door was just replaced from an accident so that side should be good for a bit lol
797Performance.com
Old 05-28-2016, 04:58 PM   #8
Respect BRZ
Old Mechanic
If you wait to hear a clunk like we did. You might loose a bolt. Not fun finding the right replacement. Spend an hour for the piece of mind.
Old 05-28-2016, 04:59 PM   #9
nickmerronesucks
Ned flanders
Door panel hard to take off? Im afraid it will end up like an e36 door panel,and never fit again haha
797Performance.com
Old 05-28-2016, 07:01 PM   #10
Respect BRZ
Old Mechanic
Look in diy section, pretty sure it's in there
Side Window Deflectors TimmyC Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 62 02-02-2016 11:33 AM
Driver side window OEM Lorico Canada Classifieds 2 01-05-2016 08:30 PM
Side Window Deflectors? xFury Cosmetic Modification (Interior/Exterior/Lighting) 3 11-02-2015 05:37 PM
stock front drivers side suspension clunk. dkstylezz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-24-2015 02:19 PM
Side Window Louvers hypercarfanatic Cosmetic Modification (Interior/Exterior/Lighting) 8 07-16-2014 03:34 PM
