Northern California NorCal
Old 05-27-2016, 08:41 PM   #15
jcygts6
jcygts6's Avatar
Drives: 13 SWP BRZ
http://lathewerks.com/shop/popup_ima...ID=264&image=3
jcygts6 is offline   Reply With Quote
Old 05-27-2016, 10:37 PM   #16
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
Shifter, not shift knob.
Old 05-28-2016, 07:41 AM   #17
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Best shifter
Get the metal STI knob. That knob is like stock but gets rid of all the minus feel about stock knob & STI short shifter (-5mm).. Both are amazing product.
JDM TRD short shifter is even shorter then STI one if you want that. (-10mm? I forget)
They do cost more since it's the whole assembly, but you pay for the quality & prefect fit like its suppose to come with them from factory. Judging from the way you said it, you should give them a try. You will not regret getting them.
Old 05-28-2016, 12:46 PM   #18
Irace86
Drives: BRZ + Ducati M796
I have the perrin rear bushing and that tightens things up. so do my MTEC springs, but they also help with some pop in the throws. the whiteline transmission bushing also gives some good stiffness on acceleration for less chances of missed shifts from less torque twist of the knob, and it gives a (IMO) nice feel and sound. The shift knob is slightly lower than stock.
Short shift kits can be finicky and aren't really needed because the stock shifter doesn't have a long throw to begin with (IMO), especially compared to many cars.
Irace86 is offline   Reply With Quote
Old 05-28-2016, 01:27 PM   #19
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
So your opinion is the stock one by itself is the best? I'm for stock look but function is #1. I drive very fast in the hills.
Watch out! This guy drives very fast in the hills! He needs real shifting people...
I vote stock. Works great for me.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
justint5387 (05-31-2016)
Old 05-28-2016, 01:36 PM   #20
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Stock is 40mm throw (this is like Honda Type-R kinda throw). Remember this is a Japanese car made for Asian physique in mind imo (shorter throws and shorter clutch pedal travel than your avg German sports car).
STI is -4mm throw (10% shorter), JDM TRD is -8mm throw (20% shorter). Factory height and construction for both the difference in the pivot point at the bottom.
If the throws get overly short I suspect it won't be that great for daily driving.
I have the weighty STI alu knob to go with the STI shifter and I find sometimes when the gearbox doesn't want to engage, I've managed to jam it into gear and grind without effort.
I'm thinking if I should go with the lighter Duracon one instead to be safe, but I know the plastic will wear down and melt with time like a ThinkPad keyboard.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
chaoskaze (05-28-2016)
Old 05-28-2016, 10:11 PM   #21
Sapphireho
Connection issues
Sapphireho's Avatar
FINALLY! I thought that would bring lots of jabs. I guess I sell it too good, or you guys are too nice!
On the serious side, lots of good info, thanks guys!
BlaineWasHere (05-29-2016), justint5387 (05-31-2016)
Old 05-30-2016, 11:43 AM   #22
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Stay away from Kartboy unless you want notch notch notch!
tigermack is offline   Reply With Quote
The Following User Says Thank You to tigermack For This Useful Post:
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 09:20 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-23-2014 12:49 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 02:24 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 03:27 PM
