86WORX
Old 05-23-2016, 05:45 PM   #15
dp1
driving smoother faster
Drives: Sold
After exchanging quite a few thoughts with @CSG Mike on my needs and opportunities for improvements, some SPL and Cusco bits will be added. Swaybars will remain stock, there will be less rubber in the suspension, and it should all play nicely with new JRZ doubles.
dp1 is offline   Reply With Quote
Old 05-24-2016, 09:08 AM   #16
troek
troek's Avatar
Drives: 2012 Toyota 86
Good thread!
The Following User Says Thank You to troek For This Useful Post:
dp1 (05-24-2016)
Old 05-24-2016, 09:12 AM   #17
dp1
Drives: Sold
Here is what's getting added soon, courtesy of CSG via SPL and Cusco:
SPL Adjustable Rear Toe Arm
SPL Bumpsteer Adjustable Front Tie Rod Ends
SPL TITANIUM - Rear Traction Arm
956 464 AV - Front lower control arm front spherical bearing
692 464 BV - Front lower control arm rear bushing
965 464 LV - Rear upper control arm front bushing
965 464 IV - Rear upper control arm rear bushing
965 928 A - Differential mount collar
965 927 A - Rear subframe collars
Looking forward to trying these out with JRZ DA on 500lb/600lb (9k/11k) springs and Toyo RRs...with a little luck, may be ready for 3 days at NJMP with NASANE 6/17-19.
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (05-24-2016)
Old 05-24-2016, 09:59 AM   #18
jvincent
jvincent's Avatar
If you winter drive your FRS be prepared for a workout getting the OEM toe arms off.
The Following User Says Thank You to jvincent For This Useful Post:
dp1 (05-24-2016)
Old 05-24-2016, 10:48 AM   #19
dp1
Drives: Sold
I did during the 2014/2015 winter but it's been tucked away off season since. I'm sure that EFI Logics has seen their fair share of baked in parts. Thx for the heads up
Old 05-24-2016, 05:38 PM   #20
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I was very surprised how nice the car is for daily driving even with all the mounts and bushings. Our cars are great at having the frame take it all and not have stuff vibrating all over the place like some cars. I would recommend doing all the stuff I've done even for non-track canyon carving enthusiasts. I barely feel any vibrations. I do feel what the car is doing much more and things are more responsive and solid feeling.
I have my eye on the "Whiteline KCA 435 front roll center bump steer correction kit" but haven't bought it yet as I'm undecided if I need it.
Here's a list of what I have so you don't need to visit my build thread, even though you should.
Whiteline KCA416 Front Camber adjusting bolt 16mm
Whiteline Rear Control arm - upper inner bushing (camber correction) KCA326
Whiteline Front Control arm - lower inner front Anti-Dive / Caster Correction Kit KCA434
Whiteline Front Control arm - lower inner rear bushing W0509
WhiteLine Rear Crossmember Mount Bushings KDT922 Positive Traction Kit
Whiteline Front Sway Bar with bushings Front 20mm Fixed BSF45
Whiteline Rear Sway Bar with bushings 16mm Adjustable BSR53Z
Whiteline Front Steering - rack & pinion mount bushing KSR210
Whiteline Rear Trailing arm - lower front bushing W63414
Perrin Poly Rear End Links
Front strut tower bar
Perrin front control arm brace
Subaru Impreza OEM Conical Washers (Subaru P.N # 20326AA000)
RCE TARMAC 2 COILOVERS
Whiteline Gearbox Positive Shift Kit KDT926
Perrin Rear Shifter Bushing
Whiteline KDT925 Rear Diff - mount in cradle & support outrigger insert bushing
MTEC Shift Spring Kit
Chase Bays stainless steel clutch line
Autozone slave cylinder (smaller than stock)
stockysnail is offline   Reply With Quote
The Following 3 Users Say Thank You to stockysnail For This Useful Post:
DocWalt (05-24-2016), dp1 (05-24-2016), ottoyu34 (07-08-2016)
Old 05-24-2016, 06:43 PM   #21
OkieSnuffBox
Drives: '23 BRZ Limited
Your roads must be nice up there (actually a friend from OR here this weekend commented how terrible our roads are).
I'm Ground Controls, solid mounts front and rear and 255/35 Star Specs. The ride is atrocious and loud. And I'm about to put SPL LCAs on the car to get some travel back and be able to adjust the camber.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
dp1 (05-24-2016)
Old 05-25-2016, 12:10 AM   #22
stockysnail
Just the tip
They are usually good.
Old 05-25-2016, 03:25 AM   #23
The less flex/play your bushings have, the more load/work gets passed on to your dampers. It'll really reveal the quality of your dampers...
dp1 (05-25-2016)
Old 05-25-2016, 09:43 AM   #24
OkieSnuffBox
You seriously have to see the quality of our roads. It's atrocious.
I'm visiting Portland in about 8 weeks to see if I want to get out of this corrupt, underfunded conservative hell hole!
CSG Mike (05-25-2016)
Old 07-07-2016, 10:12 PM   #25
dp1
Drives: Sold
Love the suspension upgrades on track, very tight and precise between JRZs and metal-on-metal joints instead of rubber bushings but not snappy
MaximeT (07-08-2016)
Old 07-08-2016, 08:45 AM   #26
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
It would be helpful if these individual pieces were bundled into packages where each component compliments the other and represents the most logical progression order.
I hate to use an over used term but in effect Stage I Stage II etc.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
dp1 (07-08-2016)
Old 07-08-2016, 09:28 AM   #27
dp1
Drives: Sold
That's exactly what I wanted to do with this thread after more feedback. Having gone though a major change, I do see it more as Stock/Stage1/AllOut - you either leave it close to stock and change dampers and a few items that give you camber, eliminate larger movement, and similar...or go all out to chase the razor sharp handling that this platform can be after a large enough investment.
Would be very happy to get votes on options that belong to Stage 1/2/3 and compile into the top post.
Old 07-08-2016, 09:47 AM   #28
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by dp1 View Post
I've seen videos of (sway bar) end links failing in high G corners, though not on a twin yet. Two of my Whiteline end links weakened from track use and were replaced before failure. I will use them throughout this season but would like to replace with sturdier parts - what brand/model do you recommend?
It is happening also on our cars. Reason is not the high G corners, but the height difference in the car. When you change the suspension, you usually decrease also the wheel fender gap. Factory end links were designed for the OEM height and if you keep the same links, then the stress on them is much bigger. It is just likely to happen failing in high G corners.
Too bad that most of the aftermarket coilover brands (even big names) don't provide updated end links. They just take your money and leave you alone to think about all these details.
The Following User Says Thank You to nikitopo For This Useful Post:
dp1 (07-08-2016)
Search this Thread:
Advanced Search
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? themajesticone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 80 11-14-2014 07:01 AM
Coilover spring diameter vs OEM ahaghshenas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 11-25-2013 01:26 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
Kronos Coilover/Spring MEGA THREAD! Special Prices inside! KronosPerformance Brakes, Suspension, Chassis 46 09-09-2012 09:22 PM
