| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#85 |
Interesting conversation / thread.
FWIW. I'm running a 245/40 tire set-up. I drive aggressively. Think daily redline, smell of burnt rubber when I pull into the driveway at work or home. I also have over 25 years behind the wheel, 20 of those years with cars like BMWs and Miatas. My alignment is set with a mild negative camber (-1 f and -2 r) with a slight toe-in front and back (1/32). The tires WILL NOT break loose - which is how I like to drive. With this set-up, I *have to* set the setting to sport. If I drive will all controls on, the car constantly is trying to intervene. Sport mode with my settings lets me aggressively take corners, go in HOT, etc. Personally with the stock tires and alignment, the ONLY time I ever gone all controls off, was with a LOT of room to lose traction. Breaking loose with a 4 cylinder car takes a little practice and more room. With a higher torque car (like an M3 or a V8), it's easier to modulate the throttle to put the car into a drift. With the BRZ... you have to carry some speed and momentum too. |
#86 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Whats the difference between the vsc sport button and the left one?
Sent from my E6653 using Tapatalk
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#87 | |
Drives: 2016 Scion FR-S RS 2.0
Discussed more in posts #64 and #66.
2016 Scion FR-S Release Series 2.0 #170/1000
#88 |
Drives: 2015 Subaru BRZ WRB
I turn off VSC and Traction every day. I have a steering angle kit and it flips out if I don't.
#89 |
Drives: 2013 WRB BRZ 6MT
In general, it's always on. In the summer, the only time I go full off is at autocross where there is nothing to hit. At the track, I usually drive in VSC Sport mode so I can induce a bit of oversteer without killing my speed but still have the car save me if things get really out of hand.
I turn it off pretty frequently in the winter depending on the situation. When I need to spin wheels a bit to get out of a rut or when driving on slippery roads where the TC starts going nuts, then it's better to disable it. |
| The Following User Says Thank You to Lynxis For This Useful Post: | justatroll (08-18-2016) |
#90 |
Lowly Cartuber
got it...so it sounds like VSC sport is for when i want to take a spirited drive on some backroads without killing myself. And the left is for if i'm at a track and i really want to kick out the backend for some donuts.
#91 |
Drives: car
In Autox on stock tires I was faster in Sport mode than with TCS off.
#92 |
fabulous
No offense but that just means you are still learning how to drive it.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | chaoskaze (08-23-2016) |
#93 |
Drives: 2017 BRZ LMT w/ performance Pkg
On the track all off, but usual daily drive with both on. Sometimes when I go for a drive that i can enjoy I turn both off. On highways, i go for track mode.
#94 |
Drives: 2014 BRZ
All off, thanks Beastronix. Never had, wanted or needed on another car.
| Turn signals don't always automatically turn off | one2onejackpot | Issues | Warranty | Recalls / TSB | 6 | 04-18-2016 08:35 AM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 11:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 07:47 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 11:11 AM |
