| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Now de-solder just the orange wire from the "stop" terminal and re-solder it to the "fog" terminal. Now both the orange wire to "fog" and the black wire to "stop" become the Red wire on the outside which gets tapped into your brake circuit. (Green wire on the factory tail light harness) This will give 12V to the "Triangle" and F1 blinking circuit when you step on the brakes. 12V is required at the "fog" terminal to power the triangle LED's and 12V at the "stop" terminal drives the F1 blinking circuit which interrupts the ground side of the triangle several times, giving you the blinking effect during braking. If this is how you have it, triple check you connections, make sure you have them right and everything is making good contact. I think there was another post where someone had a similar issue and it turned out to be a loose connection at the tail light. |
| The Following User Says Thank You to BirdTRD For This Useful Post: | WolF_RS (05-10-2017) |
#16 | |
Drives: 2015 Ultramarine Scion FR-S (MT)
Got it, I'll double check my connections and get back to the post, thank you!
#17 | |
Drives: Subaru BRZ MY2016
Hi tato.valverde so does your setup separates v from triangle and triangle serves as and is on when fog light is on right? I need to do the same setup as i am from Europe and need to have a separate fog light. Any other wiring needed to be run from Fuse box as you were mentioning previously? What about wires setup in trunk? Still need to connect the red and blue to the tail lights? Thanks. |
#18 | |
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
On my case, my U.S. spec FRS didn't come with any wiring for the fog lights, or no switch or anything, so I bought a switch and ran a wire all the way to the Valenti light, which you can see on the picture. On your case, since the wiring is already there, you can just run that wire into the Valenti (presumably the middle wire of the 3 wires on the connector under the trunk lip) and have it working with the stock fog light switch and wiring =) |
| Valenti 4th brake light vs Valenti Style brake light? | JGalp | Electronics | Audio | NAV | Infotainment | 9 | 03-24-2016 06:48 PM |
| SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light | AtlasMick | Exterior Parts (Aero, Lighting, Etc.) | 8 | 03-07-2015 07:51 PM |
| Valenti 3rd brake light wiring | SPCorBUST | Southern California | 4 | 09-24-2013 12:57 PM |
| how to turn that rear triangle reflector into working brake light | chris's fr-s | DIY (Do-It-Yourself) Guides | 29 | 06-10-2013 08:25 AM |
