#15 | |
Drives: 2015 Ultramarine FR-S
#16 |
Drives: 2014 BRZ Limited SWP 6MT
noone is butthurt child, throwing accusations and making a title "cracked header" without checking shit just to get views? lol..you'll sure get great replies and advices with that attitude Thumbsup
#17 |
sorry mr. canada, you didnt have to comment on it if you didnt want to. it obviously says "CRACKED HEADER?"
THERES A DAMN ??????????????? if you couldnt see. you read my post, my comments and obviously didnt take note listening to what i said |
#18 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
You know what would of solved this?
going outside after work, jacking your car up. seeing whats wrong fixing it If not fixable make post about cracked header If fixable fix drive _______________ No hard feelings pj :P
797Performance.com
| The Following 4 Users Say Thank You to nickmerronesucks For This Useful Post: |
#19 |
later murica
| The Following User Says Thank You to tdotBRZ For This Useful Post: | SlammedSilly (05-13-2016) |
#20 |
love ya nick, im just to lazy to put it on jackstands when i have access to a lift, haha
#21 | |
Drives: 15 BRZ LTD, 05 FXT
I don't run any Tomei parts, though I like them and have installed plenty. When people search and see "cracked header" then see Tomei everywhere, we don't want them to have V1 Borla flashbacks before we know if you just botched an install, (it happens to the best of us.) I don't think anyone was butthurt, just letting you know how to be the best possible member in this community. Also, your day has nothing to do with ours. Check your PMS at the keyboard
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#22 |
Drives: 2005 Toyota Camry
clickbait title
to lazy to check for actual leak wants to keyboard diagnose a header leak when not enough information is provided I think this would've been easier if a thread started with more relevant information or pictures. -alex |
| The Following 7 Users Say Thank You to mav1178 For This Useful Post: | 86geek (05-14-2016), ATL BRZ (04-20-2018), Cole (05-13-2016), CSG Mike (05-13-2016), JazzleSAURUS (05-13-2016), nickmerronesucks (05-13-2016), tdotBRZ (05-13-2016) |
#23 |
the thread couldve had pictures if i checked it out before posting... stated earlier i have not checked it out. not enough info provided? what else would you like?
#24 | |
and yea, its gonna show up everywhere if it was a common issue like borla and ofh.... simply asked if anyone has had a tomei uel problem bc i know its leaking from somewhere, just havent had the time to put it on a lift yet, like ive stated countless times
#25 | |
So... you had a Buddy Club exhaust that sounds like it has a leak (when you are 100% certain it doesn't), yet you think your Tomei UEL has a leak. How do you know it is a weld that has failed? You're just posting up a bunch of speculations without facts. It's very simple, you have what seems to be a leak and there's really only 5 things that can leak: 1) head/manifold gaskets, either from improper torque spec or reusing old gaskets, or bad seal from gasket surface being contaminated 2) header leak from weld or slip-joint failure 3) overpipe gasket leak, same as #1 4) thin walled header making you think there's a leak 5) O2 sensors not properly torqued down Figure it out yourself. A clickbait title just invites a bunch of noise and not actual answers to your question. If I install a header and it's leaking, I do not assume it is cracked, especially if it's new. -alex |
| The Following 3 Users Say Thank You to mav1178 For This Useful Post: |
#26 |
Drives: frs
Leak was solved?
#27 |
#28 |
Ned flanders
maybe rocco is sabotaging you..
797Performance.com
| The Following User Says Thank You to nickmerronesucks For This Useful Post: | SlammedSilly (05-13-2016) |
| OpenFlash Header (OFH) Cracked--Worth Fixing? | gonzo | Engine, Exhaust, Transmission | 9 | 12-27-2015 06:55 PM |
| Cracked block? | seant2h | Engine, Exhaust, Transmission | 18 | 09-03-2015 02:24 PM |
| cracked header | Jonesy86 | Northwest | 21 | 02-09-2015 10:13 PM |
| Cracked Oil Pan?! | Jolaessss | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 11-21-2013 03:28 PM |
| Cracked Rim | SmsAlSuwaidi | Issues | Warranty | Recalls / TSB | 29 | 04-02-2013 02:30 PM |
