#29 | |
Drives: White BRZ
The point of my rhetorical questions was that differential behavior affects chassis balance. I think the oil you run in your diff will affect the way it reacts, and therefore the car's balance. I used Amsoil GL-5 in my transmission, and it sucked. My bad, switching to Redline GL-3 made a huge difference. I used Amsoil in my diff .... and I have oversteer. |
#30 | |
Drives: 2005 Toyota Camry
[ame="https://www.youtube.com/watch?v=JEiSTzK-A2A"]Torsen Differential, How it works ? - YouTube[/ame] |
| The Following 3 Users Say Thank You to mav1178 For This Useful Post: |
#31 | |
Drives: White BRZ
If you're not contributing to the discussion, go troll another thread. |
#32 |
Drives: White BRZ
That video is awesome! Thank you. This is just the response I needed. I guess as long as the diff fluid 'lubricates', I'm good. I wonder why there are different specs for transmission and Diff oil. Must be materials ...
#33 |
Junior
Drives: a car
Im sorry if what you dont want to hear is critism and you assume its trolling. Welcome to the internet.
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | FRSBRZGT86FAN (05-11-2016), strat61caster (05-11-2016) |
#34 | |
And found the solution you wanted faster than you were able to type responses to trolls, which is to be expected given the noob nature of the thread title. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | cdrazic93 (05-11-2016) |
#35 | |
This is the type of person I wouldn't want modding the car, does everything all at once and then blames the wrong thing for oversteer.
#36 |
Junior
Drives: a car
Not nessecarily blaming, but just misinformed. Then draws conclusions based off of, well I dont know. The way he worded the OP was a matter of fact kind of statement rather than conceding that he may be wrong in his assumptions. Regardless, I was there at one point but I also googled and googled when I was younger. I only asked questions when I was 100% confused and had exhausted my research capabilities, which does extend to the search function on this forum (not to say this topic has already been covered, but theres a whole heap of topics that have).
| The Following User Says Thank You to cdrazic93 For This Useful Post: | FRSBRZGT86FAN (05-11-2016) |
#37 |
Drives: Strangely.
You seem convinced, and I'm not saying you're wrong. change the fluid back and see if it corrects the oversteer.
My FR-S has a build thread!
(It's mostly full of Nissans) |
#38 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#39 |
Drives: 2015 Subaru BRZ WRB
Even though the shock is still from your brz, you put in a stiffer spring. This is what changed your handling characteristics. What did you think was going to happen ? What was your planned outcome from this ?
#40 | |
#41 |
What do you mean? I'm not talking about electronic brakeforce distribution or traction control, it's literally just brakes the inner wheel, it was in their press docket, they use frictional balancing with brake.
#42 | |
I need more details on how and when you are oversteering, to give you guideance on how to possibly eliminate it. Corner entry? Mid corner? Exit? On-throttle? Off-throttle? On i ncreased throttle? On decreased throttle? On lift? There are many variables, none of which I've seen anyone commenting on this thread really thoroughly examine. Everyone is examining a piece of the puzzle, that they've had experience with. Instead, lets look at the whole picture. |
| Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 12:52 PM |
| Heres a tip on replacing diff fluid. | Rick0S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 07-27-2015 07:37 PM |
| Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 09:02 AM |
| Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 10:04 PM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
