86WORX
Old 05-10-2016, 01:06 PM   #15
freerunner
freerunner's Avatar
Drives: GT86
Originally Posted by Racecomp Engineering View Post
Agreed on the slight rear toe in being helpful.
Damper changes (stiffer front, softer rear) would be helpful on corner entry and exit.
- Andrew
Sorry to disagree. Koni yellows have adjustable _rebound_ damping only.
In this case, a stiffer front setting induces more oversteer on corner exit and a softer rear induces corner entry oversteer.
reason for edit: typo
freerunner is offline   Reply With Quote
Old 05-10-2016, 01:45 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
wait, diff fluid causes oversteer? well I'll be damned
Old 05-10-2016, 11:52 PM   #17
Turdinator
Seņor Member
Turdinator's Avatar
If it's on the track rather than in the diff it might...
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
cdrazic93 (05-11-2016)
Old 05-11-2016, 12:49 AM   #18
ansibe
Drives: White BRZ
Why do drifters lock their axles together? Why do McLaren and lotus resist using mechanical diffs? Why can't forum contributors answer honest questions or just stay out of the thread?
Yes my car was aligned by a professional shop, and I have the final readouts.
OE tires.
I chose FRS rear springs in an attempt to balance the car. Same for the alignment specs. I just have trouble believing the changes I made moved the grip so far forward.
ansibe is offline   Reply With Quote
The Following User Says Thank You to ansibe For This Useful Post:
CSG Mike (05-11-2016)
Old 05-11-2016, 01:32 AM   #19
DarkSunrise
DarkSunrise's Avatar
I count three changes you made that would contribute to more oversteer.
(1) -rear springs swapped to OE FRS (stiffer)
(2) -Aligned to -1.5 camber
(3) -0 toe all around.
Individually they're not drastic changes but done all at once, they would have a pretty noticeable effect. I think people have made useful suggestions.
First try playing with damper settings since it's free. Here's a flow chart for dealing with oversteer (keeping in mind that Koni single adjustables appear to alter rebound only):
If that doesn't solve your issue, try adding slight rear toe-in (and/or more rear camber). Alignments are relatively cheap.
And if that fails, try an adjustable front sway bar.
One thing to keep in mind is that if you change to track tires, your opinion on the car's balance might change as well.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
solidONE (05-11-2016)
Old 05-11-2016, 02:18 AM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I feel like flaming someone , but i dont want a temp ban. So I'll keep my mouth shut.
The Following User Says Thank You to cdrazic93 For This Useful Post:
FRSBRZGT86FAN (05-11-2016)
Old 05-11-2016, 11:32 AM   #21
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I feel like flaming someone, but i dont want a temp ban. So I'll keep my mouth shut.
I seriously don't get the point of this. That you even feel the need to "flame someone" aka be a douche. Do you get internet troll "brownie points" or something? lmao
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
ansibe (05-11-2016)
Old 05-11-2016, 11:38 AM   #22
solidONE
solidONE's Avatar
Originally Posted by ansibe View Post
I made several changes to my BRZ at once, and now I have a slight oversteer problem. Mods:
-dampers changed to Koni Yellow
-Aligned to -1.5 camber and 0 toe all around.
-Diff fluid changed to Amsoil 75w-90 GL-4
-No change to the sways. I'm on OE BRZ
I Think the component changes are pretty conservative, so I'm surprised how much more oversteer I have. It's fun, but I'm not a drifter so I want grip.
Could this be caused by the diff locking early because of the fluid I'm using? I think I should have used GL-5.
I've personally ran BRZ front and FRS rear springs with factory dampers and im a bit surprised you are getting oversteer. My alignment was a bit different though. The result was a bit of understeer at entry. Maybe those Konis along with your alignment has something to do with your resulting oversteer.
My alignment with the set up (apporx with camber bolts and rear lower control arms):
-3 camber 0 toe front
-2.5 camber 1/16" toe rear
Intent > Content
Old 05-11-2016, 12:14 PM   #23
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
No, but pointing out the defense has holes in it about diff fluid from OP...I would have probably chosen less than nice words for stupid questions haha.
Old 05-11-2016, 12:34 PM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
OE tires.
Because drifters care very little about handling, they want both wheels locked together so they spin at the same time and at the same speed. Alternatively they may go for 2 way LSDs
Come on dude, you're pushing it, in what world would the Diff fluid effect over-steer on this car? have you owned other cars that induced over-steer because of the fluid? What led you to that conclusion?
Also your mclaren and lotus examples don't even apply here
McLaren P1: They use frictional balancing with brakes/electric motors so they don't need an LSD system as they can be more precise without it.
Mclaren MP4,670s, 570 etc: Use brakes on the inner wheels at times moments, also the suspension is adjusted on the fly, they also have NO sway bars everything is connected electronically or hydraulically and adjusted in split second intervals (this is in the P1 as well)
For the lotus: A limited slip differential matters more in wider, heavier cars than it does in narrow lightweight cars, FYI, because the different radius paths of travel are smaller, and the distribution of weight left-right during a corner is smaller as well. They are famous for saying it here:
http://www.lotustalk.com/forums/f25/...06/#post552007
Old 05-11-2016, 01:33 PM   #25
ansibe
Drives: White BRZ
This is very helpful, thanks.
I will definitely experiment with the damper settings. I have been adding "stiffness" to the front to get traction at the rear, but now I see I've been going at it backwards!
I'm also due for tires, so I'll try something stickier. The extra roll will get me some camber at the back which should help.
Old 05-11-2016, 01:38 PM   #26
ansibe
Drives: White BRZ
We have almost identical setups. The Koni's seem to have far less compression damping than OE, which may be allowing the front to drop with corner loads.
Your alignment is more aggressive than mine, but you don't seem to be having any trouble. What tires are you running?
Old 05-11-2016, 01:41 PM   #27
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
LOL changes springs and doesn't understand that it will affect handling characteristics.
Your brain fluid needs to be changed.
Look, from the fact that you know the FRS springs are stiffer and you changed them on the rear it should be no surprise to you that it would induce oversteer.
Why would you even think that its related to the fluid ?
irax is offline   Reply With Quote
The Following User Says Thank You to irax For This Useful Post:
Old 05-11-2016, 01:50 PM   #28
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because you made a TON of changes all at once... that's where I would start.
I have no problems with oversteer on my car, and my alignment is
F -3.6 camber, 0 toe
R -2.7 camber, 1/16" toe in
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
cdrazic93 (05-11-2016), strat61caster (05-11-2016)
Search this Thread:
Advanced Search
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 12:52 PM
Heres a tip on replacing diff fluid. Rick0S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 07-27-2015 07:37 PM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 09:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 10:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
