#239 |
Drives: 2013 FRS Whiteout
| The Following 2 Users Say Thank You to Pure Automotive For This Useful Post: | Draco_PR23 (02-14-2017), Sportsguy83 (02-14-2017) |
#240 |
The Cloudmaker
Drives: GT86, G37S
I have a few quick questions about the Motec kit:
1. Is it possible to use a jdm vvti 2jz ? 2. Can I use an AT GT86 as a base for this swap ? As far as I know, the ECU wiring is different in AT and MT cars. 3. Do I need any fuel system upgrades if I keep stock twin turbos ?
#241 | |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
| The Following User Says Thank You to R2RO For This Useful Post: | Apex-Apex (03-01-2017) |
#242 | |
Drives: 2JZ FRS
for fuel, a stock in tank pump may run stock twins at stock 2j boost level, but every car we have done has a single turbo and 400+ whp so its hard to say 100%. will the car run, of course. it just may run out of fuel when trying to make power. any drop in fuel pump will work since the motec controls the oem fuel pump controller, just like factory. as for the ecu and wiring, everything the car needs to work the abs, cluster, fuel pump, steering, etc is in the bulkhead harness at the ecu. the auto trans related wiring will just go to nothing on the motec end of the jumper
| The Following 2 Users Say Thank You to spitfire481 For This Useful Post: | Pure Automotive (03-06-2017), R2RO (03-02-2017) |
#243 |
[ame]http://youtu.be/kcIUkmbJMsU[/ame]
| The Following 2 Users Say Thank You to Pure Automotive For This Useful Post: | Sportsguy83 (04-09-2017), turtlefeeder (07-25-2017) |
#244 |
Due to popular demand, we are adding VVTi 2JZGTE To our catalog! Our Plug and Play Setup can now be ordered for use with VVTi motors. We have also added VVTi friendly mounts to our website!
www.pureautomotiveperformance.com/shop I would LOVE it if someone decided to drop a car off at the shop for a full VVTi swap in the near future so we can do a build thread and show off the compatibility
| The Following 7 Users Say Thank You to Pure Automotive For This Useful Post: | Draco_PR23 (04-11-2017), DustinS (04-12-2017), ILLSMOQ (04-12-2017), maxjedi (04-15-2017), pooch (04-11-2017), R2RO (04-14-2017), Sportsguy83 (04-11-2017) |
#245 |
Hi
#246 |
#247 |
#248 |
Damn I would have dropped off mine if I actually trusted shipping companies. My other FR-S just sits anyways.
#249 |
Drives: 2JZ FRS
Our first overseas swap package is up and running without issue! Starts right up with all functions working. We have another one heading to the UAE as well. This customer has been struggling for months trying to get the car running before going with our solution.
| The Following 5 Users Say Thank You to spitfire481 For This Useful Post: | aslanteye (04-26-2017), ft86xtc (04-27-2017), ILLSMOQ (04-26-2017), Pure Automotive (04-26-2017), Sportsguy83 (04-26-2017) |
#250 | |
Drives: 2013 WHITEOUT FR-S
#251 |
Only because we already test fitted these and know that they fit. We've used Xcessive for Non VVti and they worked. I'm sure the Xcessive ones probably work, I just won't sell anything I haven't personally test fitted yet.
| The Following 2 Users Say Thank You to Pure Automotive For This Useful Post: | jbravo373 (04-27-2017), Sportsguy83 (04-26-2017) |
#252 | |
Boosted
Drives: Not a supra....yet
| The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post: | Pure Automotive (04-27-2017), Sportsguy83 (04-27-2017) |
| Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 09:53 AM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| WTB A/T BRZ/FR-S CA Budget 21k | Euan | Want-To-Buy Requests | 4 | 07-21-2015 12:50 AM |
| $2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 12:23 PM |
| There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 09:14 AM |
