#15 | |
Drives: BRZ DGM Limited
I'll have to recheck those voltage readings from the radar dectector. The new red top is on its way from Amazon. I'll report back if it corrects the flicker. (needed a new battery anyway) |
#16 |
Drives: Whiteout frs
Its completly normal... Well at least in my case...i have creed led drls
it
#17 | |
Your kidding right? For once the default search emoticon doesn't apply here, also its not the same the BR-Z DRL is led factory not some retrofit bulb.
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | clayrush (05-06-2016) |
#18 |
Ya, and they never flickered before at idle. This is something new. My red top arrives today. Will install when I have time this weekend and see if it makes a difference.
#19 |
Drives: 15 BRZ LTD, 05 FXT
Very interesting, the battery seems to make sense to me, I'm curious to see if this resolves your issue.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#20 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Just in case the battery idea doesn't work, I traced my DRL flicker to the handbrake. The same circuit that lights handbrake on warning light in the instrument cluster switches the DRLs on and off. In my case a very slight movement of the hand brake lever would trip the switch. A small bump, my elbow hitting the lever, any shake at all in the idle and I'd be flashing people like Pee Wee Herman.
Slow is smooth, and smooth is fast
#21 |
#22 |
Have fun with crap light output from some cree LEDs
#23 |
The CREE and Phillips are probably the best out there. The end user not choosing the correct Lumens is usually the issue not the LED.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#24 |
New red top battery is in.........update to follow!
#25 |
FIXED! The stock LED DRL on my BRZ no longer flicker at idle. Seems it was the OEM battery getting weaker (3.5 years). Not sure why the new battery fixed it , but it did. Some other observations:
Car as expected now starts quicker and you can hear the difference in the sound of the starter. When driving, voltage readings on my radar detector use to swing between 14.2 to 14.8 (AC is off). Now when driving its a steady 14.6. When the car was off and I had the accessory on (with heater blowing) the voltage would drop quickly to 11.9-12.0. Now it stays at 12.6. For those that are interested, got this red top here and it came in 3 days. I did use the tray they provide under the battery to make it the same height of the OEM battery: [ame="http://www.amazon.com/Optima-Batteries-8020-164-Starting-Battery/dp/B000MS9VZK/ref=sr_1_1?ie=UTF8&qid=1462629143&sr=8-1&keywords=red+top+8020-164+35"]Amazon.com: Optima Batteries 8020-164 35 RedTop Starting Battery: Automotive[/ame] |
| The Following User Says Thank You to BRZnut For This Useful Post: | FRSBRZGT86FAN (05-07-2016) |
#26 | |
#27 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#28 |
Interesting..same as mine now with the new battery.
I guess those with the LED DRL can use the flicker sign as an indicator that it is time to replace the battery, before they get stranded. The flicker was very noticeable pulling up against a wall, or you can just look directly at them to see it. (but for those with auto, car needs to be in N for the DRL to stay on) |
| Interior Lights Flickering | Skorov | Electronics | Audio | NAV | Infotainment | 14 | 05-01-2016 03:54 PM |
| Did anyone notice? | FRSNewb | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2014 03:59 PM |
| Sidemarker LEDs flickering | CreinCrein | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-12-2014 09:53 PM |
| HID BULB FLICKERING HELP!! | ijuliusx | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 05-24-2013 04:18 AM |
| Anyone else notice... | Linseal | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-04-2012 12:18 AM |
