Old 10-04-2020, 01:43 AM   #421
Jo0
Drives: '17 CWP Limited w/ PP
Finally got around to installing today. I don't think I've bent the AC condenser line enough. Not sure how to go about it, that process makes me a little nervous. I've wedged a piece of the old radiator foam between the condenser line and the top oil pipe in the mean time.
Another thing that worries me is the possibility of the fittings on the radiator end coming undone on their own. I've tightened them down as much as I was comfortable with prior to putting everything back together, and I'm checking the fittings everytime I get out of the car. I'm guessing that I should try to go back and try to tighten the fittings down tomorrow or sometime soon to make sure they are good to go.
Jo0 is offline   Reply With Quote
Old 10-04-2020, 12:30 PM   #422
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
No no no! Google AN fittings. You wanna get them hand tight and then maybe 1/4 turn with the proper wrench. They will never leak. If you crank them they'll be ruined.
Kestrel is offline   Reply With Quote
The Following User Says Thank You to Kestrel For This Useful Post:
DarkPira7e (10-04-2020)
Old 10-04-2020, 01:31 PM   #423
Jo0
I'm honestly worried about them backing out and/or popping off vs leaking. The root of the concern is the drain back line on my Verus AOS has come off of the check valve into the cam cover once. I'd hate for that to happen on this product since that's going to result in oil actively being pumped out of the system until I get to a stop.
Based on your suggestion and a quick google. I did just that initially and I should be fine. Phew
Old 10-05-2020, 02:37 AM   #424
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Hoping to hear some reviews from your side.
Good luck with the set up.
Thefalls is offline   Reply With Quote
Old 10-09-2020, 01:55 PM   #425
doku
doku's Avatar
Drives: 2017 Subaru BRZ w/ Performance Pack
Can anyone confirm that standard radiator hose kits work with this radiator? I was going to get some silicone ones.
2017 Subaru BRZ Performance Pack - Brembo Brakes - SACHs Dampers - Wedsport TC-105x 18x8.5 - Michelin Pilot Sport 4S 245/35 - STI Short Throw Shifter
doku is offline   Reply With Quote
Old 10-09-2020, 01:56 PM   #426
Kestrel
Kestrel's Avatar
Yes, standard radiator hoses work perfectly.
Old 10-09-2020, 02:42 PM   #427
djezlee
Drives: 2017 BRZ Limited
They work... but i suggest changing them while you are in there.
djezlee is offline   Reply With Quote
Old 05-01-2021, 05:29 AM   #428
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Has anyone tried measuring the oil pressure with this unit and see if the drop is significant?
TheRealBFKR is offline   Reply With Quote
Old 05-01-2021, 11:33 AM   #429
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
My oil pressure and temp sensors are on the filter adapter. My Intellectronix pressure gauge reads up to 99psi. Except at idle, it always read 99. My Element Tuning engine purportedly had mods that increase pressure and volume.
Old 05-01-2021, 03:17 PM   #430
Butterballz
Drives: Black FRS
I used to worry like you but as long as you tighten the fittings right, they will not back out. It's been a while and a couple of track days and none of the fittings even moved since I marked it with a pen.
The fittings are tapered so they shouldn't be tightened as hard as you can. You should also oil the taper area so it doesn't bind while tightening. That might give you a false sense that it is tightened. I hand tight after oiling, then once it stops, I use a wrench and turn like 1/4 or so till it feels like it stopped.
Butterballz is offline   Reply With Quote
Old 05-01-2021, 05:31 PM   #431
TheRealBFKR
Thanks! So you are saying with the Dual and your pressure increasing mods, you are basically always at 99+psi except for idle? What kind of pressure increasing mods are these...
What weight oil do you run?
Old 05-02-2021, 11:15 AM   #432
blsfrs
blsfrs's Avatar
As per Element Tuning's instructions, I run Mobil 1 10w30. Their "mods" are proprietary. You can read what they say about them on their website, elementtuning.com. I might get more information since my engine is currently being torn down because of valve train and timing chain issues.
Old 05-02-2021, 05:26 PM   #433
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
For piece of mind, you can always wrap safety wire on your fitting ends, piece of cake
vintagemxer is offline   Reply With Quote
Old 05-03-2021, 01:35 PM   #434
ninjan00dles
Drives: 2015 FRS
Wouldn't the end fittings need safety wire provisions for that?
ninjan00dles is offline   Reply With Quote
Search this Thread:
Advanced Search
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
