#351 | ||
Drives: Black FRS
Another issue I had is the lower radiator hose touching the bottom of the oil control valve when pressurize. Since the radiator is thicker, it pushes the hose towards the back (I think). The gap is much smaller so when I used the included 1.4bar radiator cap, it pressurized it too much to where the hose touches the bottom of the lower oil control valve. I swapped to the oem radiator cap and pushed the hose attached to the radiator as in as possible. I probably have about a cm of space when pressurized now. Close but no touching now. I've only had it for a month so I can't tell you any long term issue. It worked on the track keeping my temps between under 230F all day. |
| The Following 6 Users Say Thank You to Butterballz For This Useful Post: | CxG (04-08-2019), eastendraceshop (01-24-2019), gkubed (01-23-2019), Harvie1031 (02-13-2019), Rosticles (01-23-2019), weederr33 (01-23-2019) |
#352 |
Drives: 2019 Toyota 86
How does this compare to something like a dedicated Jackson oil cooler and a Mishimoto radiator? I'm not sure if this combination radiator + oil cooler is as effective as having them as separate components.
#353 | |
Drives: WRB BRZ
This combo unit is quite effective for my use-case of tracking a turbocharged car in NJ Fall ambient temperatures of 50-70F (only time of the year I've tracked so far) as well as during warm up of the daily driver after a cold start in sub-freezing NJ winters. My oil temperature on the track was in the sweet spot of 220-230: hot enough to burn off anything that isn't oil but not hot enough to cause problems. My coolant temperatures were more-or-less unchanged from OEM as the OEM radiator is already quite good with a vented hood for improved airflow. If you're tracking in much higher temperatures, you might be better suited with separate dedicated units. |
| The Following User Says Thank You to Fred E For This Useful Post: | CxG (04-08-2019) |
#354 | |
Drives: A Hot Mess
i personally run the dual oil cooler/radiator combo and have had zero issues with overheating with this unit, the stock fans are actually superior to many aftermarket slim fans. the downside... yeah the unit is pricey, but like anything else... you get what you pay for.
one of the first people to ruin the frs.
| The Following 3 Users Say Thank You to staycrushing For This Useful Post: |
#355 |
Drives: 2023 BRZ
I got my dual cooler from CSG recently. While I'd like to reuse the stock foam, I'm concerned it won't come off easily, or get damaged when I take it off, or maybe not adhere well to the new cooler. If I wanted to order foam before taking the car apart, what should I use? I know McMaster Carr is one place to find the stuff, but am unsure specifically which type to get. I don't know anything about thickness, width, adhesives, or fire resistance. Does anyone know precisely which product I should buy? A link would be super helpful. TIA.
Director of Rocky Mountain 86CUP
#356 | |
Weight Weenie
Drives: 15 FR-S
Mine came off without tearing. I would imagine you could just use double sided taper to put it back on. I don't think it does anything other than keeping your engine bay a bit cleaner. It's unlikely it's helping keep temps down or "directing" any airflow. I've recently installed mine and I'm leaving it off. |
#357 | |
| The Following User Says Thank You to fika84 For This Useful Post: | Pat (03-29-2019) |
#358 |
What temps are people seeing with this combo unit who are running FI. Just installed one with my sprintex 210 kit. In 80f temps just driving around town I am seeing after full warmup is 210-215 oil temps and 205 to 212ish coolant temps. This is mix between some decent pulls (lower gears) normal city driving and sitting at lights.
2013 Series 10 FRS #553
#359 | |
#360 |
Drives: 2022 BRZ, Red
Quick question. If I were to install a standalone oil temperature gauge, does it matter which hole is used on the oil cooler adapter for the sensor? (Ie: is there a hot side or cold side on the sensor plug locations and would it effect any readings from the sensor) @Jackson Racing, @CSG Mike
This is one of the darn things where the theory makes sense, but the practical escapes me. Thanks Y'all -Brock Last edited by Brock H.; 06-27-2019 at 01:40 AM. |
#361 | |
#362 |
How accurate is the stock sensor?
#363 |
#364 |
Probably should have prefaced that the gauge installed was the Innovate dual function oil pressure and temp gauge, with the pressure function already being utilized.
I'm using a gauge and not OBDII with an app as I like a dedicated display for that information. I like canaries that allow me to immediately make safe the car if there is an issue. This is mostly for the pressure side of things though. |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 06:35 PM |
| Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 12:26 PM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 03:00 AM |
| Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 12:04 PM |
