Old 04-24-2016, 12:31 PM   #1
Saviorself
Saviorself's Avatar
Drives: 13' BRZ
Unhappy Turbo rattle?
Hey how's it going everybody? I'm fairly new here hoping to get some feedback.
I took my wife out to the beach yesterday which was an hour way drive. On our way back I started to hear a light rattling noise coming from the turbo area, it progressed and it kind of sounds obnoxious. Happens on low rpm accelerations and fades off around 4000's as well as and when you're cruising and lightly step on the gas you hear it rattle. You can hear it on normal idle now as well. Still has boost pressure, no smell or smoke detected. Anybody have an opinion ? Any help would be greatly appreciated.
Saviorself is offline   Reply With Quote
Old 04-24-2016, 12:37 PM   #2
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Stock turbo failure...common
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
EAGLE5 (04-25-2016)
Old 04-24-2016, 12:46 PM   #3
Saviorself
Saviorself's Avatar
Drives: 13' BRZ
It has a gt3076R
Old 04-24-2016, 12:51 PM   #4
Whodunit
Drives: White
Did you check for play in the bearing
Whodunit is offline   Reply With Quote
Old 04-24-2016, 11:01 PM   #5
retoocs
Stuck wastegate?
retoocs is offline   Reply With Quote
Old 04-25-2016, 12:36 AM   #6
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Is the intake side all clear? Does the turbine spin freely without any friction?
Instagram: stimson
Old 04-25-2016, 09:21 AM   #7
Are you sure it is even the turbo? Could it be a loose heat shield or exhaust? I ask because many of the low RPM rattles brought up here end up being loose shields.
fumanchu1 (05-09-2016), mixtape (04-25-2016), SkAsphalt (05-09-2016), themadscientist (05-09-2016)
Old 04-25-2016, 09:23 AM   #8
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
The crickets have evolved!
rookie is offline   Reply With Quote
The Following 2 Users Say Thank You to rookie For This Useful Post:
MGPAX (04-25-2016), taiguy (05-16-2016)
Old 04-25-2016, 03:54 PM   #9
ryoma
ryoma's Avatar
the turbo accelerates the growth of the crickets every time you hit boost
Old 04-25-2016, 04:38 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Saviorself View Post
It has a gt3076R
so... what exactly is your setup?
None of us know what you have, and without knowing what kit you have it's impossible to say what problem you are experiencing and the solution for it...
Old 04-25-2016, 05:45 PM   #11
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
pictures with arrows showing us where the sound appears to be coming from would be good too. but if its a rattle i agree with tcoat, probably something like a heat shield or something resting on another part.
driftartist is offline   Reply With Quote
Old 04-25-2016, 05:46 PM   #12
gled21
gled21's Avatar
Drives: White brz 2015 / 93' s13
might just be an exhaust/shield rattle, i know my headers rattle a bit against the shield. (Ft86 - catted UEL)
gled21 is offline   Reply With Quote
Old 05-08-2016, 10:53 PM   #13
Saviorself
Saviorself's Avatar
Drives: 13' BRZ
What's up guys, took the car to Ptuning in VA. They found the recirculating dump tube (2)
To have cracks. And was just throwing gas into the sensor.
Was about 365 for parts and 277 in labor. Runs better than before for sure . Such a significant improvement. Now time to save up for a flex fuel kit��
Old 05-09-2016, 04:30 PM   #14
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
how did your dump tube crack? was it not shielded ? placement? etc.
I ask because if it's due to something like placement of the tube then it may very well crack again in a short time
fumanchu1 is offline   Reply With Quote
Interior rattle frsinpa Issues | Warranty | Recalls / TSB 132 03-23-2015 04:09 PM
Anyone else's 6MT a rattle box at low RPM? Silver Ignition Scion FR-S / Toyota 86 GT86 General Forum 81 05-29-2014 11:56 PM
Rattle above 5k rpm trippinbillies40 Issues | Warranty | Recalls / TSB 1 05-28-2014 02:55 PM
AC Rattle AVodka14 Issues | Warranty | Recalls / TSB 8 05-21-2014 12:08 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
