#15 |
Drives: FRS
Right on guys thanks for the help! The grooves in the rotors definitely feel scored and dug in grooves. I will go ahead and bleed the brakes with higher quality brake fluid too.
| The Following User Says Thank You to Whooosah For This Useful Post: | bass_114 (04-25-2016) |
#16 |
Don't just bleed them with better fluid, make sure it's a full flush. Count on using about 3/4L of fluid.
| The Following User Says Thank You to wparsons For This Useful Post: | Whooosah (04-26-2016) |
#17 |
3M makes a surfacing kit. It fits in an air grinder and uses small rotary pads (like sanding disks) to remove surface layer buildup. The rotary tool will spin the disk as it removes the build up if held at a slight angle, depending on the dust shield the inside might need the caliper or shield removed.
From this distance I agree it looks like you cooked the pads. As said, get track pads for next time you track and new street pads for every day. Technically the rotors should be "cleaned" (resurfaced) before a change in manufacture or type of pad, as there is a deposit on the surface of the rotor. |
| The Following User Says Thank You to ls1ac For This Useful Post: | Whooosah (04-26-2016) |
#18 |
One other comment about brake fluid, the higher the boiling point the more hydroscopic the fluid. ie. the faster it will absorb water. The best high temp racing fluids are designed to be changed every track weekend. Good synthetics can last a long time. No old fluid should be used at the track as boiling will happen at the worst possible time.
#19 |
Drives: Hyper Blue BRZ
As previously noted, I have used Centric Premium or NAPA premium rotors with Carbotech pads, stainless lines and a high temp brake fluid. I have never had any brake issues on the track. Do not waste money on drilled rotors for the track. DBAs are nice, but pricey. For a long time I tried to find a street/track pad and finally give up. Just buy separate rotors to use with a dedicated track pad. Since I always bleed my brakes before each track event, swapping pads and rotors didn't take much more time.
| The Following User Says Thank You to atlbrz For This Useful Post: | Whooosah (04-26-2016) |
#20 | |
Because compromise ®
Drives: Red Herring
If you are tracking your car you do NOT want drilled rotors. Rotors will always crack from a hole. Get slotted or flat.
| The Following 6 Users Say Thank You to Captain Snooze For This Useful Post: | cdrazic93 (05-03-2016), Mr.ac (04-26-2016), soulreapersteve (04-28-2016), Ultramaroon (04-26-2016), Whooosah (04-26-2016), wparsons (04-26-2016) |
#21 |
Drives: FRS
Thanks for the input everyone. I went ahead and ordered centric premium blank rotors. I am still researching and saving for track pads. Trying to figure out whether I want to run a dedicated track pad and rotor set up along with a daily setup.
I had the carbotech xp10 or ferodo ds2500 in mind running with the centric premium rotors in mind for track use. Any other inputs on pads would be very welcomed. The stock rotor looks like it can be resurfaced and I'll get a set of cheap pads for daily use when I know I'm not going to track the car for a while. The main track I would be at is Portland Int'l Raceway. It has a big braking zone on the front straight from 110-45 into a chicane. A couple of mid speed zones and another high speed 115-60 or 70 or so on the back straight. Thanks again everyone on here for the useful information. I didn't think I would be so into brakes. Would have loved to put the money into suspension, wheels, tires, headers, tune but it looks like it will be a while before I can fund that. Also saving for a jack, stands, and other tools like a torque wrench (been saving up harbor freight coupons...) The track bug has bitten me...what a money pit. Whole lot of fun though. |
#22 |
tip to remember is that track pads work well when hot and street pads work well when cold. that is why track pads are not recommended for street driving and you have found out what happens to street pads at the track. there are some crossover pads but not the best at either extreme.
#23 | |
Drives: Scion FR-S, Ultramarine
| The Following User Says Thank You to Estey For This Useful Post: | Whooosah (04-26-2016) |
#24 | |
Drives: Red Herring
Car weight and speed Track Braking style I had DS2500 on my previous car and they were great on street and track BUT the car weighed 200 kgs less than the BRZ and wasn't as fast. Tracks can be fast or slow or a combination of both. Different drivers use their brakes differently. So while the XP10s are good pads you may need to experiment more to find the optimum pad for you, your car and tracks you visit. Certainly having different street and track pads is optimum. This.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Whooosah (04-27-2016) |
#25 |
Drives: FRS
Sounds great everyone thanks for the input.
#26 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Centric Blanks are a great way to go, that's what I've always run and my car has seen a fair bit of track time. Haven't had a rotor crack on me yet!
Lately I've been running Winmax W5 pads with them and they've been my favorite pads I've used yet. Fantastic bite and feel, stops properly fast and they don't make too much noise to boot. I ran XP10s on the Supra and they weren't the best on track with a little more fade than I liked, and by god they're loud. The Supra is 3400+ lbs though, so that's to be expected. Honestly, the Winmax's have been so good on the BRZ that I don't think I'll be changing brands anytime soon. The Supra is probably getting Winmax's the next go around too.
- The Ancient BRZ Sacrament by Zaku |
#27 | |
Since he wants a dedicated track pad, he should learn on very good pads so that he can gradually work up to the limits of the pad. Its better to do that instead, because you run the risk of overwhelming your brakes when using a less effective pad because the driver may outgrow the pads fairly quickly. Once he figures out his likes and dislikes of a good track pad, he can look for other solutions that will better suit his driving style |
| The Following User Says Thank You to Estey For This Useful Post: | Whooosah (04-27-2016) |
#28 | |
Drives: FRS
This has been discussed a bit before but I've read people run track pads upfront and oem out back. Cost wise I was going to do this but would like to know the cons and possible problems I might run into? I'm guessing it's ideal to be on the same compound all around? Anybody cook their rear oem pads on a track? I don't want to burn out any other parts unnecessarIly that still have useful life in them for my daily street driving. Also with the rears if I go dedicated pad back there should I have a dedicated rotor too? |
| The Following User Says Thank You to Whooosah For This Useful Post: | Guff (04-27-2016) |
| Low car + replacement axles + raising diff advice | JordanWho | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 04-05-2019 09:47 PM |
| DBA Front Rotors | tumbla.jr | Brakes, Suspension, Chassis | 14 | 11-11-2015 11:32 PM |
| Timing Chain Cover Replacement - Need Advice | Gen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-02-2014 01:15 PM |
| [WA] FS: GTS Front AND Rear Rotors | stevo_12v | Australia Classifieds | 0 | 01-04-2013 09:43 AM |
| Replacement Front Rotors | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 40 | 11-27-2012 04:44 PM |
