86WORX
Old 12-14-2018, 01:15 PM   #113
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Originally Posted by jflogerzi View Post
Look what came in
Link to that color above that looks really nice.
The pic above your post is original Brembo color. I have no clue where to find it.
My color yellow is spraycan magic. I used VHT High Temp Caliper spray cans Yellow and Orange paint. I sprayed a base coat of yellow and while the base coat was still wet I misted, from about 2 feet away, Orange color paint. It’s not perfect but it got me the DIY result I was looking for. I eventually painted black Brembo logos on top. Finished top coat of VHT High Temp Clear.
turbocat is offline   Reply With Quote
The Following User Says Thank You to turbocat For This Useful Post:
MJones_RB (06-26-2019)
Old 07-03-2019, 12:39 PM   #114
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Has anyone done the math for brake bias with having this BBK on the front and moving stock front rotors and calipers to rear? I read a comment on a youtube video of this conversation where someone said they did this. Not quite sure how it was fabricated to work but yeah. Thought I'd ask.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 07-03-2019, 08:19 PM   #115
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Just bought and installed my set ... Total cost around $1100 ...
Maybe this USED to be $600
Paint ... fluid ... parts ... etc
HAving trouble bleeding the brakes ... brake pedal goes to the floor ... tried bleeding unable to figure it out ... trying gravity bleed ... We'll see how this goes.
Celigts is offline   Reply With Quote
The Following User Says Thank You to Celigts For This Useful Post:
soundman98 (05-17-2020)
Old 07-31-2019, 03:07 PM   #116
blackfireball5
I'm getting ready to go forward with the install of my CTS-V swap. Just painted the calipers the other day.
I ended up purchasing the Brembo GT BBK for the rear. I'm hoping that this will balence the front out a bit. I got a really good deal on the kit.
Trying to source the numbers for this calculator is next to impossible.
http://www.tceperformanceproducts.com/bias-calculator/
Does anyone have these numbers handy or know where to find them?
This is the link to the rear Brembo GT BBK:
https://wheelwell.com/shop/brembo/br...&submodel=Base
Wheelwell Profile
Old 07-31-2019, 03:20 PM   #117
jamal
jamal's Avatar
Drives: Legacy GT
I think the PP rear brembo caliper has 38mm pistons, and would assume those are the same. But I'm not completely sure on that.
The GM 4-pots have 42mm pistons, no staggered bore sizes.
The fsm gives the brembos on the sti a 134mm effective radius, front and rear. That is probably the right ballpark.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
blackfireball5 (08-02-2019)
Old 02-01-2020, 02:56 AM   #118
Jembrmstr
Drives: 2013 10series FR-S
I did this swap and for a couple years now I’ve had the 2017 camaro 50th anniversary Brembo calipers. I want to swap the rear stock calipers to the four pot GM brembos to match. I have searched and even contacted CTSV brake swap to see if there was an option to do this but I’m coming up with no answers, does anyone have any info that might help? I did the front swap with spacers and some clearancing done to fit the stock wheels to keep the 10series look. You can check out my Instagram @stuckstickerco for pics of the swap since I’m not savvy enough to post them here.
Jembrmstr is offline   Reply With Quote
Old 05-08-2020, 05:12 PM   #119
Top Gun
Top Gun's Avatar
Drives: 2013 FRS, 2015 FRS Turbo
What size brembo stickers did you all go with?
Top Gun is offline   Reply With Quote
Old 05-17-2020, 07:12 PM   #120
jflogerzi
jflogerzi's Avatar
Someone mentioned the Evo rears. Also rr racing has a rear bbk but they are wilwood calipers
2013 Series 10 FRS #553
Old 06-07-2020, 02:29 PM   #121
Top Gun
Top Gun's Avatar
Just completed this swap with stoptech drilled and slotted rotors and stoptech SS lines. I know drilled rotors suck but I got the set brand new for $90 off Amazon!
There is a tiny bit of pad overhang but it's minimal and nothing to worry about.
Overall, it looks great and I recommend it if you're already fully modded NA (tune, headers, wheels, coils, etc).
If anyone is interested, I have a 5 brand new ATS brembos with oem brembo pads, clips/pins available along with one bracket kit. These are directly from GM in Detroit. Production has stopped and they're unloading various production parts. I can rattle-can paint them with (2000F primer, VHT 900f Caliper paint and 550f clear coat with the Brembo sticker), or leave it alone for you to paint yourself. All you need to complete the set is the rotors, 14x2mm tap/die and 9/16 drill bit. SS brake lines are not required. PM me
Old 01-20-2021, 12:21 PM   #122
plaight
I looked through the thread but I never found confirmation of anyone trying these with 17x9 +35 RPF1s. Anyone tried it?
plaight is offline   Reply With Quote
Old 01-22-2021, 12:54 PM   #123
HSC
Drives: Whiteout FR-S
Pretty sure it doesn’t fit. Haven’t heard of any BBK that fit that wheel setup.
HSC is offline   Reply With Quote
Old 01-22-2021, 01:06 PM   #124
Tokay444
Anti stance.
Tokay444's Avatar
Don't AP Racing Sprint and Endurance fit that setup?
Old 01-22-2021, 01:38 PM   #125
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't believe they do due to the spoke design on the +35 RPF1's.
Old 01-22-2021, 02:15 PM   #126
cantwell13
Drives: 13 FRS
Just a quick update, I'm in the process of completing this set up over the winter & I have a set of 720form GTF1 in 17x8 +35.
I've read the these wheels do NOT clear the factory BBK, I was prepared to use extended lugs and the correct spacer needed if necessary however now that I have everything bolted up(minus my brake lines) this kit clears both the inner barrel as well as the spoke that was the issue with the factory BBK.
There is over 2mm of clearance between the spoke & the calipers, it's very hard to get a picture of but I was pleasantly surprised to find everything seems to have cleared & worked out.
I've added some crappy pics of dirty parts/wheels that will be cleaned when the car comes out for the spring lol.
Chris
Sent from my Pixel 3 XL using Tapatalk
cantwell13 is offline   Reply With Quote
ats, brakes, brembo
STi Brembos, rotors, and brake lines jwbrocloud Brakes, Suspension, Chassis 5 01-09-2015 10:55 PM
04 STI Brembos, Hawk pads, 5x100 front rotors Philly758 Brakes, Suspension, Chassis 7 12-06-2013 08:55 AM
FS: 2004 STi Gold Brembos(5x100) w/Hawk Pads, Rotors, lines!~~MINTTT~~ nemesisdrift Brakes, Suspension, Chassis 25 11-22-2013 01:25 AM
2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line Jamifra Brakes, Suspension, Chassis 10 10-29-2013 11:31 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
