Old 03-26-2018, 02:02 PM   #99
jamal
jamal's Avatar
Drives: Legacy GT
The funny thing about the RPF1 is that the 8" wide +35 offset wheel has less brake clearance than the +45 version. It's because on the higher offset version the spokes kind of curve around and back in to the rim surface where they are more concave on the lower offset wheels.
The 18x8 +45 RPF1 I think will fit those brakes but I'm not positive.
jamal is offline   Reply With Quote
Old 03-26-2018, 03:49 PM   #100
poolboy54
Drives: Scion FRS. Silver with black badges
That's weird haha. Thanks I'll look into it
Sent from my SM-G955U using Tapatalk
poolboy54 is offline   Reply With Quote
Old 03-31-2018, 06:29 AM   #101
benzz280
Drives: Toyota 86
Looks like there is pad overhang issue from one of the install video on youtube. Any of u experiencing it and if it will pose a problem in the long run particularly safety?
benzz280 is offline   Reply With Quote
Old 05-12-2018, 10:31 AM   #102
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I been trying to grab those calipers for a while but they're always out of stock. Apparently there are new part numbers now.
https://m.facebook.com/ctsvbrakeswap...98882210394953
https://www.facebook.com/ctsvbrakesw...98882210394953
NEW PART NUMBERS:
Driver Caliper- AC Delco- 172-2777
GM- 84089034
Passenger Caliper- AC Delco- 172-2768
GM- 84089035
OLD PART NUMBERS:
Driver Caliper- AC Delco- 172-2586
GM- 22760030
Passenger Caliper- AC Delco- 172-2587
GM- 22760031
Alltezza is offline   Reply With Quote
The Following User Says Thank You to Alltezza For This Useful Post:
Teseo (12-13-2018)
Old 12-03-2018, 07:10 PM   #103
Victorscp
Drives: 2018 BRZ premium
sorry for the bump but are these different then say these???
https://www.amazon.com/dp/B0010G0HP6
https://www.amazon.com/dp/B000S2OR86
Victorscp is offline   Reply With Quote
Old 12-03-2018, 08:04 PM   #104
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Yes, those look different. They are probably for a newer model
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
Old 12-04-2018, 09:53 AM   #105
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by turbocat View Post
Finally installed my ATS Brembos and also changed the rear calipers to WRX 2pot calipers.
I used DBA front rotors for my new bigger Front rotors.
Also used StopTech Street Performance pads all around.
Wheels are Apex Racing ARC-8 17x9 42mm offset.
I used a grinder on both top and bottom of the calipers outer edges. I wanted the most room for wheel barrel clearance.
Calipers are rattle can VHT caliper paint Yellow and Orange with a top coat of Clear.
I misted the Orange onto the Yellow while the paint was still wet to get the darker shade of Yellow.
I plan on doing black painted Brembo logos on the fronts soon.
Next time try out Humbrol Metallic Shade 54, you will not be disappointed.
Trueweltall is offline   Reply With Quote
Old 12-13-2018, 02:40 AM   #106
jflogerzi
jflogerzi's Avatar
Can someone confirm these are pins and brackets that will work with this kit?
ACDelco 18K1971X Professional Front Disc Brake Caliper Hardware Kit with Clips and Pins
Link
Also what Brake lines are needed? Do i need lines made for these brakes or can I get Steel braided lines made for the FRS/BRZ?
2013 Series 10 FRS #553
Old 12-13-2018, 02:54 AM   #107
Raven86Project
Link
You can find all you need to know here:
[ame]https://www.youtube.com/watch?v=0Ofn9qgdFsU[/ame]
He also links all the products in his video description.
IG: raven86project
Build Thread HERE
The Following User Says Thank You to Raven86Project For This Useful Post:
jflogerzi (12-13-2018)
Old 12-13-2018, 03:01 AM   #108
Raven86Project
BTW, I have them in my car as well
IG: raven86project
Build Thread HERE
The Following 2 Users Say Thank You to Raven86Project For This Useful Post:
MJones_RB (06-26-2019), sroby (08-19-2019)
Old 12-13-2018, 03:23 AM   #109
jflogerzi
jflogerzi's Avatar
Humm Your looking at 700$ with new Front Brake lines and thats without pads... at current prices.
Old 12-13-2018, 03:30 AM   #110
jflogerzi
jflogerzi's Avatar
Well shit I hate you guys. You are bad examples!! All parts ordered but pads and new brake fluid.
I picked up some EBC yellow. Seems to be a very good street and light track pad for a decent saving on Amazon. I don't plan to change rear calipers but I will do new pads. What would everyone recommend for rear pads to help with the more forward brake basis with this kit? Should I just go with Yellows all around and match same compound?
Old 12-13-2018, 09:37 PM   #111
turbocat
turbocat's Avatar
Drives: 13 BRZ SSM
Thanks for the tip. Isn’t that metallic gold? I was going for similar to Brembo yellow.
turbocat is offline   Reply With Quote
Old 12-13-2018, 11:20 PM   #112
jflogerzi
jflogerzi's Avatar
Look what came in
Link to that color above that looks really nice
The Following User Says Thank You to jflogerzi For This Useful Post:
turbocat (12-14-2018)
ats, brakes, brembo
STi Brembos, rotors, and brake lines jwbrocloud Brakes, Suspension, Chassis 5 01-09-2015 10:55 PM
04 STI Brembos, Hawk pads, 5x100 front rotors Philly758 Brakes, Suspension, Chassis 7 12-06-2013 08:55 AM
FS: 2004 STi Gold Brembos(5x100) w/Hawk Pads, Rotors, lines!~~MINTTT~~ nemesisdrift Brakes, Suspension, Chassis 25 11-22-2013 01:25 AM
2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line Jamifra Brakes, Suspension, Chassis 10 10-29-2013 11:31 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
