#43 | |
Drives: '13 FRS
I am hoping I can go back to using them now though because swapping pads for the track is a pain and I look forward to not having it do it anymore.
#44 |
Drives: '13 FRS
Also, I was putting my pads on tonight and as promised before I measured from the center of the hub to the edge of the caliper. For those trying to determine if they will fit your wheels. It measures roughly 6 3/4 inches, maybe a little less (This isn't too precise because I am just feeling for the center of the hub).
![]() Here is a closeup showing the gap on my 18" tsws (with normal pads, not the odd Camaro ss pads with their weights).
| The Following User Says Thank You to etc For This Useful Post: | Trac Toy (05-13-2016) |
#45 |
Drives: Scion FR-S Black
Thanks everyone for the info. I'm ready to pull the trigger if my stock wheels will clear the calipers. I have 20mm spacers on the front also. So my question is, is the problem (if any) with clearing the inside rounded part of the stock wheels or the inside face of the wheel. My 20mm spacers might save me if the issue is clearing the inside face. I have been following this thread
http://forums.nasioc.com/forums/showthread.php?t=2773522&page=9 and people have been showing successful fitting with SOME 17" aftermarket rims. Those who don't fit, the problem is usually not clearing the inside face of the wheel. But like I said, I have 20mm spacers so this may not be an issue. What are people's thoughts? I'm thinking, if my stock rims can fit over 6pot wilwoods, then this kit surely can work: Last edited by Felix7007; 05-16-2016 at 02:45 PM. |
#46 |
Can someone please check if this kit will clear stock rims. My finger is shaking over the buy button, I can't hold out much longer.
#47 |
Drives: '13 Turbo BRZ-L 6MT
| The Following 3 Users Say Thank You to Brzerrk For This Useful Post: |
#48 |
Drives: 2013 Firestorm FRS
#49 | |
Vtec Jesus
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
#50 |
I know right! If I did, this whole project goes from $800 to about $2,500 if I get the wheels I want. On the other side, I can just cut the difference and get a BBK from Wileood or Brembo that fits stock wheels for about $1,200.
Thats why its so important to know if this kit clears stock wheels. If you have to upgrade wheels to do it, might as well get an official BBK. Then again, is saving $300-$400 really worth jerry rigging this up in the end.... |
#51 | |
Time Traveller
http://www.ft86club.com/forums/showthread.php?t=90379 http://www.rr-racing.com/category-s/130.htm |
| The Following User Says Thank You to DAEMANO For This Useful Post: | SkAsphalt (09-28-2017) |
#52 | |
That will be perfect for the rear. From a visual standpoint, they look a little small for the front imo. |
#53 | |
The way I see it, the RR Racing Sport Performance kit is the same price as the kit initially posted in this thread and is better mostly because there is no jerry rigging required (Drilling and tapping). Thank you for showing me this. I might do the 6pot Stage 1 kit for about $200 more because racecar. |
| The Following User Says Thank You to Felix7007 For This Useful Post: | DAEMANO (05-23-2016) |
#54 |
So, to close out my 2 cents on this.... I just purchased the RR-Racing Stage 1 kit with BP20 pads. $1050.05 total, $47 shipping. I figure I plan on never upgrading my calipers again and the $179 to get 6pot over 4pot is insurance to make sure I'm satisfied now and in the future when I go FI. I still recommend the performance kit over the cadillac conversion.
#55 |
StreetKart
Drives: 2014 Scion FR-S Monogram
I'm waiting on my brackets to show up myself... I'm on 17x9 +42 Rota RT5 and supposedly i need a 3mm spacer to clear an STi caliper. I'm hoping the contoured bottom edge of the caliper makes that a non issue. i dont want to have to get effin extended studs if i dont have to.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#56 |
Anti stance.
3mm isn't enough to warrant extended studs.
| Tags |
| ats, brakes, brembo |
| STi Brembos, rotors, and brake lines | jwbrocloud | Brakes, Suspension, Chassis | 5 | 01-09-2015 10:55 PM |
| 04 STI Brembos, Hawk pads, 5x100 front rotors | Philly758 | Brakes, Suspension, Chassis | 7 | 12-06-2013 08:55 AM |
| FS: 2004 STi Gold Brembos(5x100) w/Hawk Pads, Rotors, lines!~~MINTTT~~ | nemesisdrift | Brakes, Suspension, Chassis | 25 | 11-22-2013 01:25 AM |
| 2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line | Jamifra | Brakes, Suspension, Chassis | 10 | 10-29-2013 11:31 AM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
