Old 04-20-2016, 01:20 AM   #1
NZ86
Drives: GT86, 83 RX7
Cusco RS LSD Break-In and Oil Change Interval Recommendations
I have a Cusco RS plate type LSD with 4.56 ring and pinion which I am going to swap for the standard unit shortly.
Does anyone know the brake in procedure and oil change intervals for this?
Any help is appreciated - Thanks
NZ86 is offline   Reply With Quote
Old 04-20-2016, 06:18 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You'll need to ask whoever is installing to check the documentation for it, it'll probably involve tight full lock figure 8 driving for 20-30 minutes or alternatively driving normally with gradual acceleration for the first 500 miles. Regardless after 500 miles its best to change the fluid, then go by the normal intervals.
Also expect it to do that classic clacky noise during the break in.
Old 04-21-2016, 10:23 PM   #3
NZ86
Thanks for that. I have done some further research and most people say to do slow figure 8s for 20-30 minutes then to change the oil after, which is probably what I will do.
Does anybody know if the oil change interval is any different to the standard diff, Toyota says to change every 45000 kms.
New Oil Change Interval for 2015s? tomkozski Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 02-12-2018 02:13 AM
Oil Change Interval BunnyRZed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-01-2018 10:58 PM
10K oil change interval on 2015's? torqdork Scion FR-S / Toyota 86 GT86 General Forum 29 08-13-2015 02:01 AM
2015 BRZ Service Interval Change FRSupra Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 10-03-2014 07:26 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
