Northern California NorCal
Old 04-19-2016, 11:33 PM   #15
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
How long did you wait after hooking up to the other car? Did you hook up the wires and tried starting it?
I might be forgetting something, but look up the owners manual to see if there is a step by step for jump starting push button cars.
If not, Well time to bust out the multi meter. Or take the battery to the auto part store.
Old 04-22-2016, 01:57 AM   #16
lizbrayan
Drives: '15 Scion Frs Steel
Could is maybe that he needs a new igniton coil? Cause that shows the same symptoms of a bad starter.
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 04-28-2016, 05:16 PM   #17
sftateofmind
Evening Primrose
sftateofmind's Avatar
Going to change out the starter this weekend and hope it's not the coils.
sftateofmind is offline   Reply With Quote
Old 04-28-2016, 11:02 PM   #18
humfrz
hmmmmm......... the ignition coils are on the spark plugs ........ which has nothing to do with the starter working. ..... I don't think ....
humfrz
Old 05-01-2016, 02:47 AM   #19
lizbrayan
Isnt the coil where the spark plug sits and what tranforms power from the battery into the oower the spark plugs need?
Old 05-01-2016, 11:12 AM   #20
BRZnut
Drives: BRZ DGM Limited
Here is what I would do..make sure your OEM battery is not low on distilled water. If so, add it to the bottom of the filler plug. Then get a jump but after connection the jumper cables, let the other car run for 3-4 min while connected. Then try to start your car.
The only thing that worries be about your story is the knock you heard when it died. Hopefully not a major engine issues.
Old 05-01-2016, 03:13 PM   #21
Srthizz
Drives: Scion FRS RS 1.0 2015
Check engine light on? If it is check that first to see what it is. I don't think it's your battery since you get power to turn on the acc. on your car. if you can't check for the code, see if you have spark and fuel when cracking the car. Btw don't disconnect the fuel line from the fuel rail to check if you have fuel coming out when cracking. It's high pressurized and dangerous to take it off.
http://86drive.com
Front engine
Rear wheel drive
Supercharged
Srthizz is offline   Reply With Quote
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 10:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
ECU: Where do I start???? chiefshayan Software Tuning 11 07-18-2013 12:42 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) -- General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
