#183 | |
#184 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
That's possible although I thought internal muffler design had the most to do with it. just read this article http://www.gomog.com/allmorgan/exhaustbackpressure.html Down-turned tips, particularly those that force the exhaust underneath the car, can deepen the exhaust note by bouncing sound off the ground and using the undercarriage as a resonator. The ground will absorb much of the annoying high-frequency sound from smaller displacement or more restricted engines. So the legamax tips are slightly pointed up which doesn't help
#185 |
Also read this deals specifically with Subaru engines. Basically saying a chamber style muffler will take highs off
https://www.physicsforums.com/thread...t-tone.723376/
#186 | |
#187 |
Detective John Kimble
Drives: 2016 FR-S
#188 | |
Drives: 2017 86
Sent from my SM-G935V using Tapatalk |
#189 | |
Yeah adding the Stock FP back in would take icing off the cake with the piping very small in some areas. I have enough room on the HKS FPS to put a small cat in between the resonators. It looks like 60mm cats would have to come from overseas. Overnight parts from Japan!
#190 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Curious if anyone here has the HKS catless EL manifold or the "super exhaust" linked below. I wonder how it performs compared to other equal length headers. It is neat how the super exhaust includes a front pipe.
https://www.hks-power.co.jp/en/produ...haust/db/15165
#191 | |
If money was no issue that would be a good path as that front pipe comes with a cat. Not sure why they don't sell that front pipe separate. The dual resonated FP has a good sound but you still get some unpleasant smell. After driving a few thousand miles + a tune the sound has gotten deeper and that initial off the line high pitch is gone. Setup Gruppe-S UEL + Overpipe, HKS DUAL resonated FP, HKS Legamax Premium Catback.
| The Following User Says Thank You to SuperTom For This Useful Post: | weederr33 (08-09-2017) |
#192 | |
#193 | |
The JDL ultra quiet front pipe is probably the quietest with a cat and resonator. I think mine is second with the 2 resonators. Also saw Hooker has a front pipe with a cat & and Helmholtz pipe which could work as well. It sounds like the FP's with just a cat and no resonator are still very loud and raspy. |
#194 | |
#195 |
I've heard exhaust doesn't make much for gains on the FRS(not counting headers) obviously forced induction could change that
#196 |
Let me rephrase that. I meant could the exhaust support the flow from a supercharger. I ask since it's only 60mm vs 63.5mm. Though I am very tempted to get it considering the ACE header is super expensive.
| Tags |
| exhaust, header, hi-power, hks, legamax |
| exhaust choices | FloridaBRZ | Engine, Exhaust, Transmission | 4 | 01-26-2015 09:32 AM |
| UPGRADE-what are my exhaust choices | cbennybrz | Engine, Exhaust, Transmission | 6 | 01-01-2015 08:45 PM |
| Exhaust Choices for FI | rixter145 | Engine, Exhaust, Transmission | 4 | 09-11-2014 02:15 PM |
| Exhaust choices | KonTheory | Engine, Exhaust, Transmission | 6 | 01-30-2014 04:28 AM |
| Help with Lug choices. | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-24-2012 09:19 PM |
