86WORX
Old 07-13-2017, 02:58 PM   #169
Vital
Drives: 2015 BRZ
Originally Posted by weederr33 View Post
Very nice. Wish I could get a hold of their catted/ resonated front pipe without having to buy the header as well. :/
Get it from here?
http://www.ft86speedfactory.com/hks-...-pipe-666.html
Vital is offline   Reply With Quote
Old 07-13-2017, 03:07 PM   #170
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Vital View Post
Not that one. I was referring to the front pipe that comes with this package:
http://www.ft86speedfactory.com/hks-...l#.WWe2sogrKUk
MS, CSCS, TSAC-F, CPT
Old 07-13-2017, 03:17 PM   #171
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Typical HKS welds. All their stuff pretty much looks like that as far as I recall.
Has there been any issues of there welds not holding up. I should've done more research but I assumed a real company like HKS would be a little better. Could've got a Chinese knockoff for half price for the same welds
SuperTom is offline   Reply With Quote
Old 07-13-2017, 03:19 PM   #172
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
As a matter of fact, yes, the first batch of the Hi Power Spec L (the dual cannon catback) had issues with the welds near the resonator section breaking/cracking and needing to be repaired.
I believe the issue was corrected with future revisions/releases.
Originally Posted by humfrz
I'm old and lazy
Old 07-15-2017, 08:44 PM   #173
SuperTom
SuperTom's Avatar
Started off this morning removing and weighting the stock parts
Front pipe: 12.1lbs
Midpipe: 12.5lbs
Axleback : 26.75lbs
So Final weight Tally
HKS vs Stock Frontpipe: 8.25 vs 12.1
Midpipe: 13.25 vs 12.75
axleback: 24.75 vs 26.75
Total loss with HKS setup: 46.25 vs 51.6 = -5.35lbs
Spent some time with a harborfrieght die grinder to grind down the inside of the welds smooth
Easy Job used my tar stuff again on the gaskets and bolted everything on. Just match the direction of the flanges exact and everything fit perfect first time! Fitment gets A+
Cat Strikes again photobombing me
Nice tips fill the hole
Sound: again I wish I could set something up for clips that will come later
Its very Jeckly/Hyde in a good way. Obviously cold start is loud. While cruising the exhaust is very quiet close to stock. Put you foot into and WHAM the sound volume jump up quickly. Not too low bassy, no drone, more on the higher pitched scale but without the rasp. So flooring its pretty loud enough for me but no annoying sounds just a straight wail.
The Following User Says Thank You to SuperTom For This Useful Post:
Clipdat (07-17-2017)
Old 07-17-2017, 11:51 AM   #174
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
A few people asked for an exhaust clip when I posted pics of the HKS Legamax Quad-tip cat-back a few weeks ago. Finally got around to doing it. Video shows start up, then a pause at every 1k RPM. Finishes off with a few blips from idle to redline.
Sorry bout the wind noise, makes it hard to even hear the exhaust under 3k RPM.
No other exhaust mods on my car.
PandaSPUR is offline   Reply With Quote
Old 07-20-2017, 02:55 AM   #175
Sam.Vera
Detective John Kimble
Sam.Vera's Avatar
Drives: 2016 FR-S
The Legamax Sports (quad-tip) becomes EXTREMELY loud if you don't have any catalytic converters. I started off originally with just the Legamax (with the secondary cat deleted) and it sounded much better than the factory exhaust. Far more sporty and sweet to the ears. I decided to get an even-length catless header (MXP 4 to 1) and it completely changed the way the exhaust sounds.
As you can see in the video, it is extremely loud and raspy (which, luckily, I like). On the highway at cruising speeds it's quite reasonable. No droning whatsoever.
Here's a quick highway pull video. I'll post another video later taken from the side of the road.
[ame="https://www.youtube.com/watch?v=xlYolEVZGDM"]https://www.youtube.com/watch?v=xlYolEVZGDM[/ame]
Sam.Vera is offline   Reply With Quote
The Following 3 Users Say Thank You to Sam.Vera For This Useful Post:
JDM4E (07-20-2017), PandaSPUR (07-20-2017), weederr33 (07-20-2017)
Old 07-20-2017, 03:55 AM   #176
Sam.Vera
Sam.Vera's Avatar
Drives: 2016 FR-S
The Following 2 Users Say Thank You to Sam.Vera For This Useful Post:
Old 07-20-2017, 08:08 AM   #177
SuperTom
SuperTom's Avatar
Originally Posted by Sam.Vera View Post
Sounds good high pitched without the rasp
Old 07-20-2017, 02:22 PM   #178
weederr33
weederr33's Avatar
Wow that sounds pretty good! I had nameless performance headers on my FR-S with my legamax sport and it sounded amazing. I'm thinking this time I'm going to go with the JDL EL headers and leave the stock front pipe though.
Old 07-20-2017, 02:56 PM   #179
Clipdat
Proud of BOXER
Clipdat's Avatar
Those are some impressively fast shifts!
I'm old and lazy
Sam.Vera (07-21-2017)
Old 07-20-2017, 03:20 PM   #180
PandaSPUR
PandaSPUR's Avatar
Jesus that is louder than I wouldve expected from this cat-back.
Bit too loud and high pitched for me though. I'll probably end up keeping at least one cat when I finally upgrade.
Old 07-20-2017, 03:26 PM   #181
Ashikabi
Ashikabi's Avatar
Probably only loud because he is accelerating hard. Mine (legamax premium) is quiet while cruising but loud when accelerating hard
Old 07-20-2017, 04:44 PM   #182
SuperTom
SuperTom's Avatar
Yeah my Legamax premium came out higher pitched than I thought. Of course I have no cats just resonators taking place of them. Was thinking of having a high flow cat added in between the 2 resonators of the hks front pipe.
Or could go outside the box and have a cherry bomb welded in somewhere. That would give it a deep tone. But the louvers inside cause turbulence. My setup is 60mm piping all the way front to back for high velocity and no turbulence. ARRRRRRRHHHHHHHHHHHH! Looks like we cant have our cake with these cars
exhaust, header, hi-power, hks, legamax
exhaust choices FloridaBRZ Engine, Exhaust, Transmission 4 01-26-2015 09:32 AM
UPGRADE-what are my exhaust choices cbennybrz Engine, Exhaust, Transmission 6 01-01-2015 08:45 PM
Exhaust Choices for FI rixter145 Engine, Exhaust, Transmission 4 09-11-2014 02:15 PM
Exhaust choices KonTheory Engine, Exhaust, Transmission 6 01-30-2014 04:28 AM
Help with Lug choices. feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-24-2012 09:19 PM
