#155 | |
#156 | |
Spec L Titanium tip is out of stock, and HKS USA is even clueless when they're going to be available stateside. |
| The Following User Says Thank You to Mackizzle86 For This Useful Post: | chaoskaze (07-12-2017) |
#157 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
yeah that's true. If I go with a brake change its going to be the old WRX Wilwood kit that knocks a whopping 32lbs off the front of the car. I know that its only slightly better than stock performance but should have no problem stopping a car significantly lighter
#158 | |
Also still not sure if I want a cannon style need more research into the aerodynamic part. I can see removing the muffler from the stock area would leave a big area to act as a parachute. For now going to just order the HKS dual resonated front pipe.
#159 |
Drives: 2014 GT86
SuperTom: just install some diffuser to not just "fix" parachuting effect but decrease drag/increase downforce in general.
#160 | |
#161 | ||
Have considered that option but adding in a diffuser would add 7lbs back in negating the purpose of lighter exhaust plus add in $$$$. Though A simple aluminum lightweight coverplate may do the trick Most likely going to go with a stock style exhaust. HKS Legamax Premium has my eye for this but cant believe its 51LBS! That's 13lbs heavier than stock with basically the same design! There website has not weight info for it https://www.hks-power.co.jp/en/produ...ffler/db/13671 . I'm trying to read through threads to see if anyone else who has this weighted this one. Having a hard time believing HKS would make the thing out of lead. Also open to any other 60mm piping exhausts (stock style) which seem to be mostly Japanese makes for that size standard. |
#162 | |
#163 |
Drives: GTS 86
I cannot believe this thread became so long! Go with the exhaust that fits! There is your answer. Oh and look for something that you like the sound of, however any change (header, front pipe, etc) will affect the sound significantly!
As for weight...ffs there is a difference of 2kg between one or the other. Power to weight ratio? the car weighs about 1290kg/200 hp = 6.45/kg. take two kg and you get 0.4 of hp /kg. Nothing you will feel. Unless, you really go all out (strip the interior, carbon fiber panels, etc) the 2 kg will do FA nothing in the whole scheme of things. We are talking here about a cheap as car, with low power with good handling not LFA level car! Performance wise, the catback adds no power...maybe 2 hp if that! In the whole scheme of things and the real life fluctuations in temperature, etc, will mean nothing. Once again, get something you like the sound of! |
#164 | |
Well I went with the Legamax premium the whole midpipe & Rear for ~$700 shipped. I think they were charging $1300 when they first came out. And the dual resonated front pipe for ~$300 shipped. I will post up pictures when I get home for work. Not much weight loss maybe 1lbs less for the whole Legamax. Midpipe is ~13lbs, axleback is ~24lbs big muffler and nice 5" tips. Disappointing in that sense but the sound clips I heard with that setup + UEL catless headers sounds deep and clean. Had to put my weight loss psychosis aside for a sane daily driver. The good thing is that it looks like a stock pipe routing with the ability to take off the axleback. If its too quiet can always change it too a straight pipe or just drop it for track days.
| The Following User Says Thank You to SuperTom For This Useful Post: | Clipdat (07-12-2017) |
#165 | |
Proud of BOXER
Drives: Subaru Boxer
Kinda lame that Torry at HKS USA has completely abandoned this thread and the forums.
Last Activity: 02-17-2017 09:36 AM
#166 | |
Agree its lame we as consumers have to do all the research work on parts. I will be installing this weekend but here are some preliminary pics. BIG box ![]() Packaging was great as to not get hurt in transport. ![]() Hard to see from the pic but the outsite diameter is 60mm claimed. Measured inside diameter is 56mm consistent all the front pipe and rear exhaust. Was hoping it would be exact match to the end of my overpipe which is 58mm inside diameter. Again at least its consistent all the way through to keep velocity high. ![]() Here are the weights (my cat likes to be in every damn picture) : Dual resonated Front Pipe - 8.25lbs ![]() Midpipe - 13.25 lbs ![]() axleback - 24.75 ![]() So the front should be about 2lbs lighter than stock and the total catback about the same as stock Nicely polished really like the big tips on this ![]() ![]() CON: I'm going to say this but the welds do not look clean especially compared to my no name(gruppe-s/ gent5) Uel headers. They are thick and lumpy but hopefully should hold up well. You can see where they burn through to the inner pipe on a few and will need to be grinded smooth ![]() ![]() ![]() Explains why the price is nearly cut in half, A nice system if you don't look at the welds. But overall I'm very excited to hear this car roar with this setup. Stay tuned
| The Following User Says Thank You to SuperTom For This Useful Post: | Clipdat (07-13-2017) |
#167 | |
Proud of BOXER
Typical HKS welds. All their stuff pretty much looks like that as far as I recall.
#168 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Very nice. Wish I could get a hold of their catted/ resonated front pipe without having to buy the header as well. :/
| Tags |
| exhaust, header, hi-power, hks, legamax |
| exhaust choices | FloridaBRZ | Engine, Exhaust, Transmission | 4 | 01-26-2015 09:32 AM |
| UPGRADE-what are my exhaust choices | cbennybrz | Engine, Exhaust, Transmission | 6 | 01-01-2015 08:45 PM |
| Exhaust Choices for FI | rixter145 | Engine, Exhaust, Transmission | 4 | 09-11-2014 02:15 PM |
| Exhaust choices | KonTheory | Engine, Exhaust, Transmission | 6 | 01-30-2014 04:28 AM |
| Help with Lug choices. | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-24-2012 09:19 PM |
