Drives: 15 BRZ
Will 18X9.5 with 45 offset fit on brz?
I'm deciding to get new wheels and am looking at the enkei tenjin 18X9.5 with the 45 offset. Anyone know if these will fit on all four corners of a brz?
Drives: '13 SWP ZC6 R
There are literally hundreds of posts about this, and all of them say "it depends."
Drives: 15 BRZ
Depens on what tho. camber? I've got about 2 degrees of it, if needed i can get a camber plate or something. Im just looking for yes or no answer.
Drives: Whiteout FRS
If you are on springs, you will def rub, even with camber. If you are on coilovers, you are getting awfully close to rubbing
| The Following 2 Users Say Thank You to Bach415 For This Useful Post: | LANWarlordII (04-17-2016), MisterSheep (04-20-2016) |
Drives: 2013 White-Out FRS
Depends on camber
Tire size Springs vs coils (coils are smaller in diameter) And overall height. 90% of the time it'll rub.
I live my life one quarter-pounder at a time.
| The Following User Says Thank You to HachiRo For This Useful Post: | LANWarlordII (04-17-2016) |
#6 | |
Drives: 2015 WRB Limited BRZ
I run 18x9.5 +40 and I have a good 5-10mm roughly of clearance between the wheel and spring. This is OEM suspension, I have no rubbing whatsoever at full lock and have had these on for a good 1-2k miles. |
Drives: 2015 BRZ CWP
I'm on 18x9.5 +45 w/ 255/35 on KW V3's and have room from the wheel/tire to the spring. -2.4 camber up front.
Kurenai Samurai
Drives: Red and manual
as sdemo said about the many posts about the wheel fitment, now would be a terrific time to do your detective work and read those posts....just like i did when i bought my wheels! happy hunting!
not all the answers will come to you, sometimes you gotta go to the answer. |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
Weddsport SA10 18X9.5+45
Lowered ~3inches ![]() -1.5deg camber front ![]() -2.9deg rear
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#10 |
1337
Drives: 2013 BRZ WRB S/C
Needs coilovers for sure.
#11 |
Drives: 15 BRZ
Yea I'm on ST coils so I should have more room vs the stock suspension. Are you running square set up on your wheels?
#12 | |
Amazing Member
Drives: 2014 Whiteout FR-S
![]() Har Har Har
#13 |
run it square, with coilovers. 255 is your max width tire due to fender liner rubbing. don't use camber bolts, instead adjust camber with top hats.
3mm spacer will fix rubbing issues and may allow you to run some extra camber with bolts. if any of the above is confusing, SEARCH
#14 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Here's an article about mine by my wheel supplier with 18x9.5" +45
http://www.prosportauto.co.nz/blog/p...SA10R-Fitment/ With +45 offset you will need coilovers. I found no fender rub with 255/35 or 265/35 tires but chassis rail rub at full lock. I put steering stops in so full lock was a little less angle preventing the rub. I'm lowered about 20mm.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
| zedd sl5 18x9.5 35 offset | diggy_digz86 | Wheels and Tires | 2 | 01-22-2015 05:14 AM |
| M7 18x9.5 5x100 UNKNOWN OFFSET | JamesBond000 | Wheels and Tires | 1 | 01-06-2015 12:38 AM |
| 18x9.5" (45) offset up front, anyone? | OICU812 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 12-11-2013 08:46 PM |
| FS: XXR 531's (18x9.5" +35 offset) - $700 OBO | husker741 | Wheels and Tires | 2 | 09-05-2013 12:07 AM |
| Lowest possible offset for 18x9.5? and 255's? | Cheeseballs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 04-22-2013 11:04 AM |
