Old 06-15-2016, 10:35 AM   #57
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Get a multi meter. $10. Can use it anywhere. AAA C 9V useful.
You are right instead of being lazy I ended up just getting a Ctek charger and busted out my old Fluke 77 multimeter. Couldn't be happier.
krayzie is offline   Reply With Quote
The Following 3 Users Say Thank You to krayzie For This Useful Post:
p1l0t (09-03-2016), Tcoat (06-15-2016), Ultramaroon (06-15-2016)
Old 09-03-2016, 02:31 PM   #58
JD001
JD001's Avatar
Drives: Subaru BRZ
The inevitable has happened, I managed to kill my battery, just 4500 miles under its terminals! Subaru has exchanged it under warranty. The replacement is a Varta sealed unit.. I have also invested in a quick terminal release widget as I don't use the car much, planning to disconnect the battery in such cases.
Update, left my car for 5 weeks, no battery tender and was expecting a dead battery! Not only the car remotely unlocked it also started!!
The Following User Says Thank You to JD001 For This Useful Post:
p1l0t (09-03-2016)
Old 09-03-2016, 03:14 PM   #59
UK may very well have a different battery.
JD001 (09-03-2016)
Old 09-03-2016, 03:23 PM   #60
Ultramaroon
fabulous
Ultramaroon's Avatar
Panasonic?
Old 09-03-2016, 03:29 PM   #61
JD001
JD001's Avatar
Drives: Subaru BRZ
Panasonic?
Varta sealed unit.
Old 09-03-2016, 03:38 PM   #62
Panasonic?
Varta sealed unit.
Well there we go then.
Canadian ones are unfortunately Panasconic.
Old 09-03-2016, 03:43 PM   #63
JD001
JD001's Avatar
Drives: Subaru BRZ
I can't remember the make of the original battery. Varta is my Subaru warranty replacement.
Ultramaroon (09-03-2016)
Old 09-03-2016, 05:30 PM   #64
Ultramaroon
fabulous
Mine's tip top.
Old 09-03-2016, 05:31 PM   #65
Ultramaroon
fabulous
Were you staying on top of electrolyte levels?
Old 09-03-2016, 07:18 PM   #66
Varta sealed unit.
Sealed
Mine is fine so far as well.
Old 09-03-2016, 07:33 PM   #67
Ultramaroon
fabulous
I failed to specify that I was asking about OP's original battery.
Old 09-03-2016, 07:40 PM   #68
gramicci101
Off Topic
I finally had to replace my battery. Keeping up with the distilled water wasn't working too well, so I used Gatorade because it has electrolytes.
Just kidding. Two years in excessive heat will kill any battery. My new battery has a three year full replacement warranty, which means two years from now when this one shits the bed I can get a new one for free.
Old 09-04-2016, 03:21 AM   #69
JD001
JD001's Avatar
Drives: Subaru BRZ
Yes, the battery levels were good however I wasn't driving the car enough therefore the battery was always low on the charge front.
Old 09-04-2016, 03:35 AM   #70
Ultramaroon
fabulous
Ah, yes. Makes sense.
Search this Thread:
Advanced Search
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 11:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
