86WORX
Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 04-08-2016, 02:32 PM   #127
ButeraFRS
Guest
Posts: n/a
You think I am a new driver?
Answer the question, I don't give a shit about your driving history.
Old 04-08-2016, 02:34 PM   #128
ATaraxias
Drives: 1994 Geo Metro Hatchback
Not "over simplifying" anything. It is simple. Cars are built to up and down shift. This whole downshift is bad mentality is just an application of quasi physics with no real world impact at all. Do autos go into neutral when you slow down? No, they downshift. Why the hell would manuals not be the same? Yes, you are correct, they do not make them fool proof and if you fuck up you can damage things that does not mean that you can not do things right without fear of damage.
Some of us put our ATs into neutral while slowing down, because racecar.
ATaraxias is offline   Reply With Quote
The Following 2 Users Say Thank You to ATaraxias For This Useful Post:
Tcoat (04-08-2016), Ultramaroon (04-08-2016)
Old 04-08-2016, 02:45 PM   #129
14 MT cars over 40 years. I have replaced one clutch ever and that was in a 40 year old 58 Ford so I will not take the blame for that.
Last 4 cars (a 91 Talon, 03 Lancer, 08 Lancer and 12 Lancer) all had 300+K on them when traded. Not one clutch issue, ever. Hell the Talon was an AWD TSI with almost 400K on it and the only reason it was retired was the body was rotted so bad. Original clutch still working great.
I have made my stand on downshifting very clear and I think my driving history is very relevant to this topic when you state I will be on my third when you are on your first.
Clutches (specific enough for you?) are meant to be used for up and down shifting. Used right and not abused they will last the life of a car. Downshifting PROPERLY is not abusing them.
extrashaky (04-08-2016), Luftwaffel (04-08-2016), Ultramaroon (04-08-2016)
Old 04-08-2016, 02:47 PM   #130
ButeraFRS
Guest
Posts: n/a
Jesus Christ it's like pulling teeth. Yes or no to the question I posted.
Stop giving me the run around, it's a yes or no question.
Old 04-08-2016, 02:52 PM   #131
No offense but for a guy that accused me of not reading their posts you do not seem to have done much reading yourself.
I will type slow so you can grasp it.
No I do not think that down shifting causes "undue and unnecessary wear on the clutch".
Clear now?
Old 04-08-2016, 02:54 PM   #132
ButeraFRS
Guest
Posts: n/a
Clear now?
That's not the question.
THIS is the question
So let me understand this properly. You truly believe that using rev match downshifting as your MAIN method for slowing the vehicle down, does not cause undue and unnecessary wear on the clutch[ in comparison to the person who only uses the friction material of their clutch, or hell even the throw out bearing, --and thus in turn by definition wears be it slightly or dramatically-- when getting the car to go in first, shifting up and the occasional downshift on a turn (assuming said person is not driving MT improperly) ?
Yes, or no. That's all I want to see in the post. Don't rephrase anything, just a yes or a no.
Old 04-08-2016, 02:59 PM   #133
No I do not think that down shifting as my MAIN method causes "undue and unnecessary wear on the clutch".
Clear now?
Better?
I give up.
Old 04-08-2016, 03:02 PM   #134
ButeraFRS
Guest
Posts: n/a
Better?
I give up.
Thank you. I just wanted it on record for future generations who search this question and end up on this thread to have a good laugh.
have a good rest of the day!
Edit: In retrospect, people searching this question might not know the answer and thus might not get why it's so funny.
Old 04-08-2016, 03:26 PM   #135
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
So let me understand this properly. You truly believe that using rev match downshifting as your MAIN method for slowing the vehicle down, does not cause undue and unnecessary wear on the clutch in comparison to the person who only uses the friction material of their clutch, or hell even the throw out bearing, --and thus in turn by definition wears be it slightly or dramatically-- when getting the car to go in first.
I would argue - NO.
Properly downshifting does not cause any additional wear on the clutch friction material.
If you are lazy or unskilled, then yes.
Does it cause more wear on the throwout bearing? - yes but not as much as those that sit at red lights holding the clutch in.
That is almost the same question as: Does shifting without using the clutch cause friction material wear?
justatroll is offline   Reply With Quote
The Following 3 Users Say Thank You to justatroll For This Useful Post:
Old 04-08-2016, 03:35 PM   #136
ButeraFRS
Guest
Posts: n/a
Originally Posted by justatroll View Post
I would argue - NO.
Just throwing this out there, probably over 8 times out of 10 you are not getting the exact RPM on the rev match you are merely coming close to matching the speed of the transmission to the engine hence why the shift is smooth. Even if you're 100 RPM's over or under, you are still, by definition, wearing the clutch because it will still have to match speeds at the end of the shift. Have you reduced the wear in comparison to the person who just shifts into a lower gear without rev matching. ABSOLUTELY.
Adding a variable of use to an item in a car that is otherwise a consumable, be it a clutch (in some instances), brake pads etc. will wear it down faster than a person who does not add that variable.
It's very easy logic.
Old 04-08-2016, 03:42 PM   #137
Ultramaroon
fabulous
Ultramaroon's Avatar
Dude, you need to back off with the attitude.
Old 04-08-2016, 03:44 PM   #138
justatroll
justatroll's Avatar
And you are way overthinking it.
I downshift, heel toe, bounce off the rev limiter and generally drive my car.
It is a tool to be used, not an infant to be coddled.
I also do not worry about marring the impact surface of my hammer if I hit something "hard".
The Following User Says Thank You to justatroll For This Useful Post:
Tcoat (04-08-2016)
Old 04-08-2016, 03:45 PM   #139
ButeraFRS
Guest
Posts: n/a
You're not even my real dad.
The Following 2 Users Say Thank You to For This Useful Post:
ajaxthebetter (04-08-2016), Ultramaroon (04-08-2016)
Old 04-08-2016, 03:47 PM   #140
Ultramaroon
fabulous
lol... ok, I can roll with that.
Search this Thread:
Advanced Search
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 07:59 AM
[Poll] Preferred method to start stop on hills Koa Scion FR-S / Toyota 86 GT86 General Forum 62 02-20-2015 05:34 PM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 02:00 PM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 10:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 02:20 PM
