#99 |
Drives: 2006 STi
[ame="http://www.youtube.com/watch?v=oLP-HCcX9as"]The 450 HP Crawford Performance Turbo BRZ - TUNED - YouTube[/ame]
high faith in these fa20s, but a LS swap is pretty cool
#100 |
Drives: stock
DOHC on the left, LS1 on the right. Which one is really bigger?
The 4.0 is out of a Lexus, the LS1 is in 29 different GM vehicles worldwide. Both engines were part of the " top 10 best engines " in 1998&1999
#101 | |
Drives: 72 240z
The Corvette has been and will always be one of the best performance bang for your buck. The pushrod technology may be old in design, but it is a tried and true method for delivering high displacement power in a relatively small unit. LSX series are no slouch engines, and if you've ever truly driven an LSX car you'd know that. I will also go out on a limb and guess that the LSX power train weighs in very closely to our beloved fa20's. Shitty posts like this make me really hate this forum. I love my FRS, but there is so much pseudo-tuning science and japanese **** riding here.
1.)1992 240sx SE A/T bone stock: The Daily
2.)1972 240z SBC355 5spd: Ratrod Project 3.) .....[undecided]....: Weekend Warrior |
#102 | |
My turbo fr-s on 6psi barely tuned is more entertaining than the corvette with it's 350ci of inefficient suck. 350ci to lay down a whopping 290whp. Yeah, pushrods are awesome, go team a'murika. No wonder Ferrari, Lamborghini, f1 teams all still use pushrods... Oh wait, they don't. Let me guess, the mustang has a solid rear axle because its awesome too, right? |
| The Following User Says Thank You to jamesm For This Useful Post: | Flasher (06-22-2013) |
#103 | |
Drives: 2013 Subaru BRZ
#104 | |
86DESU
Drives: 86 GTS, S13, CB9
300lb over stock isn't bad for a racecar level of power/weight, though. You could always vee/rear mount the radiator, too, as well as adding a fuel cell and rear-battery conversion, for better weight distribution. It won't ever be the same animal (you're losing the CoG, angular moment will be higher too) but I can see a lot worse things to do. Like a 1UZ, which has all its valvetrain weight up high, sorry to say. The FA20 wins because its valvetrain weight is lower than even Corvette's. But the LS motors excel at keeping their weight both down and down low, for a vee configuration engine, with half the valvetrain weight underneath. EDIT; Worth noting that engine was out of the following; LandCruiser, Lexus "Safari" (whatever the lexus landies were called in your market) Lexus SC400, Lexus LS400, Celsior (not quite an LS400), Soarer (Jap market SC400), and I'm pretty sure one or two others-- they're quite common.
Careful. It's contagious!
#105 |
Drives: Raven FR-S MT
Guys, I want to buy a second FR-S/BRZ/86 just to do silly stuff to it now. I got the FR-S for the boxer and the fun, balanced drive, but the appeal of a stupidly powerful variant... oh my.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT 1978 Triumph Spitfire 1500 ---------------------------------------------- ![]() |
#106 | |
Member of the year - 2016
Drives: Scion FRS
I mean this as in no info is really shared, we know there are a few cars running 2JZ's that are running a bunch of horsepower, but these are basically drift cars/drag ponies. But what about those building track monsters? Some even argue that more then 300HP will ruin the car. Perhaps the balance of a heavy LS engine tips it off too much? That's what i'm waiting for, proof of what the limits of this car are. That will really prove how extensively engineering and well made the chassis is.
#107 | |
Edit: also wanted to add that the 2jz is A LOT heavier than an ls |
#108 | |
86DESU
#109 | |
#110 |
Ls1 is a 346ci. Completely different motor than the 350ci. Nothing is interchangeable. I'll give you that, I don't like base c5's. I would only get a c5z06. They are not too expensive these days. Mid 20's. the ls6 is pretty close to the ls1 though. Just different heads, cam, and intake manifold/tb are the major differences. Same bottom end
#111 | |
#112 |
Drives: 2013 Firestorm FRS
weapons grade performance did the swap into a BRZ and the weight difference between the fa20 and the ls motor they used was 60 lbs. Thats not going to disrupt your precious balance some of you keep whining about.
| The Following 2 Users Say Thank You to fa5tco For This Useful Post: | CK_Bladesmith (09-08-2013), Shoebox (09-08-2013) |
| Engine Swap: Which Would You Choose!?? | EvoFanatic | Engine Swaps | 157 | 08-08-2017 04:34 AM |
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 02:08 PM |
| 4U-GSE: the new engine swap for old Toyotas | no_name | Engine Swaps | 17 | 12-19-2011 10:50 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
