#183 | |
Drives: 2013 Subaru BRZ
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
| The Following 3 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post: |
#184 |
Drives: FR-S 10 #103 AT
There is nothing about that video that gives any sensation of an improvement in any capacity. Without knowing that it was a V8 swap, it was just another loud car.
The angle was such that I didn't really pay attention. Thank you (sincerely) for pointing that out.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#185 | |
Done
Drives: WRB BRZ
The car belongs to Brady @ Pure Automotive Performance in Maryland. http://instagram.com/p/snaF2PjIuz/?modal=true 0 fucks given about what trolls think |
| The Following 5 Users Say Thank You to ftc~brz For This Useful Post: | @Art_Mighty (11-01-2014), cf6mech (10-31-2014), Fast_Freddy (10-31-2014), Lawnik (03-25-2015), Lonewolf (02-07-2015) |
#186 |
Drives: stock
shows what a great car this is when you have all tose maerican muscle fanboys buying subru. Sure to win the girls when thy notice your sporty car is more sporty only with the hood up. how is that a practical place to mount it? id rather see it behind the driver
Advice On Proper Fundamentals of Japanese Motor Vehicle |
#187 | |
Drives: no
Do the seals, the thing's ready for another 100,000 miles. The iron-block truck versions are plentiful and therefore cheap, only 65 # heavier than aluminum-block, and 4.8L versions are going for $300, 5.3L are around $500, and 6.0L starts at $800. '07-up have better heads and beefier rods, but most are 58x rather than 24x (crank reluctor) But don't use pre-'01. In fact, every one of mine have been '01s. The early 4.8s are good to 7500 RPM with appropriate valvetrain upgrades. All are safe past 6500 RPM. Try to get #799 or #243 heads if getting a later 5.3, and the later 6.0L heads may have the rectangular-port (intake) heads that flow better but reduce off-idle torque. That's the way to go for cost-effective NA power. Combining LSx power with 4-cylinder gearing is a fail, plan on a T56, or a T5-WC from an '88-'92 Camaro V8 if NA 4.8L, ( TBI was 0.63:1 fifth, TPI was o.73:1, but 0.59:1 and HD 0.80:1 both exist) and for differential gearing, if your Toy / Sub diff doesn't offer a ratio around 3.5:1, then plan on an aluminum Ford 8.8" from a mid-'00s Shelby Mustang Cobra. You'll never break that. Ratios range from 2.47:1 well into the 5s. And more different types of traction diffs than anyone could want. Any pure-stock LSx can happily pull a 1500 RPM cruise at 65 MPH in these cars, and the T56 offers a 0.5:1 sixth to help. You can combine that with either a 2.66:1 or 2.97:1 first, try for a combined first gear in the 9.00:1 - 10.00:1 range, for rear tires around 26" overall. If you're closer to 25", then calculate accordingly. Bigger cams will need more RPM at cruise, even after a good dyno-tune. That's part of why I like the '01-'06, they use the #0411 PCM that was figured out long ago, so tuning is cheap and easy, but it can do anything and everything you really need. Last edited by Suprastar; 04-06-2015 at 11:04 AM. |
| The Following 13 Users Say Thank You to Suprastar For This Useful Post: | @Art_Mighty (11-19-2016), Accurate Race Shop (11-06-2015), Bonburner (04-28-2015), cf6mech (04-27-2015), civicdrivr (04-13-2015), Dadhawk (04-06-2015), everythingsablur (09-15-2016), GotBRZ1691 (05-18-2015), Jesse36m3 (04-08-2015), juliog (05-17-2015), misooscar (04-05-2015), mkivalex (04-08-2015), Valentino (05-14-2015) |
#188 | |
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Great post! |
#189 |
Drives: 2015 Series Blue BRZ WRB
Sub
#190 |
Drives: 2013 Raven Black FRS
Another victim...
#191 |
Drives: BRZ Limited
#192 |
Drives: v8 BRZ
Looks like an octupus is hiding in your engine bay!
#193 |
Ontario's FT86
Drives: 2016 Lexus GS-F
Wouldn't the header melt all the plastic stuff beside it?
2016 Lexus GS-F PPE EL Headers, Apexi Resonated Mid Pipe, Apexi Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2020 Volvo V60 Cross Country Polestar Tuned. |
#194 |
@Jesse@JDLAutodesign any more info on that build?
#196 | |
Automotive Connoisseur
Drives: too many cars
Really it all depends on your budget and goals as far as recommendations go.
LSx Powered 86/ASE Master Certified Automotive Technician
| Engine Swap: Which Would You Choose!?? | EvoFanatic | Engine Swaps | 157 | 08-08-2017 04:34 AM |
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 02:08 PM |
| 4U-GSE: the new engine swap for old Toyotas | no_name | Engine Swaps | 17 | 12-19-2011 10:50 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
