#127 | |
Drives: 2013 FRS / 2013 427 Vert
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#128 |
Drives: Hydra EMS Powered FRS Raven Black
I don't think the width transaxle would fit between the OEM saddle tanks so you would have to add a fuel cell.
#129 | |
Drives: AE86, 2x GT86, TE27
I'd like to know more about using the can bus method. Every one over here is saying its years away.
#130 | |
So the Hydra has a CAN chip that is capable of communication with the OEM Can system. Each manufacturer has unique CAN systems so you have to have the equipment and more importantly an engineer to reverse engineer it. Once you find all the adresses, the data, and how the oem uses it, you can then get your computer to keep it happy or to make improvements and changes. We've actually made a number of improvements that prevent the stability control while racing from tuning back on even after its been disabled. As far as I know the Hydra EMS is the only plug and play replacement ECU that is OEM CAN compatible along with being fully direct and port injection capable. CAN systems are much too advanced to not utlize them in your stand-alone engine management. Thanks, Phil Grabow |
#131 | |
Boosted
Drives: Not a supra....yet
I think some testing has been done and the m1 is running with di not sure it's released to the public thou
#132 |
Drives: 86
I 99% of the time hate American cars, engines, parts, etc. but when they've done something right, they've done something right. and that goes for the LS engine. the cons are paled in comparison to the pros vs FA20.
#133 |
I dream of BRZ
Drives: Prospective BRZ owner.
#134 |
Not going to lie an LS swap is something I've been contemplating. Just need the cash to do it so it'll be a while. Here's to hoping the kits become more affordable...
BeastCoast.US feature http://beastcoast.us/2013/11/28/all-the-right-moves/
Build Thread http://www.ft86club.com/forums/showthread.php?t=8204 ![]() |
#135 |
It will never be affortable, it will be for the guys that have the $$$ and feel its worth it to be different. Now If you happen to have a Z06 motor laying around it wouldn't be too expensive then
Ha haNow building an FA20, fitting a turbo kit, and building up the fuel system isn't cheap either and this is where it might not be much more to do the motor swap vs. a build/turbo. |
#136 |
Drives: 2013 raven black fr-s
I think it all depends on the amount of fabrication you can do yourself.
#137 |
There is a company in Atlanta, Electron Speed, who did the Motec for the Stout Racing FRS which controls both DI and PI, but that's not really plug and play.
#138 | |
Boosted
Motec are actually developing a plug and play system ( on their site) for the 86's Motec.. YUMMM
#139 |
...and have you looked at how much Motec wants for their other M1 plug and play CAN bus application, without direct injection and simultaneously port injection? Only $7500 eek!!!!! I would stick to the Motec exhaust
![]() FRS and BRZ owners complain about spending $1200 on tuning their car. |
#140 |
86DESU
Drives: 86 GTS, S13, CB9
I'm just going to go header and catback with an E85 tune, lightweight flywheel and pulleys and lightweight brakes (uprated, natch) and light wheels for more performance. More honing what's already there than replacing or repurposing.
However, horses for courses. There will absolutely, definitely be a difference in angular moment and CoG if you change to a V8 but if you're going to do it, an LS is about the best choice you could make. Just keep the plastic inlet manifold to save weight and go with tubular headers for the same reason. Consider eliminating A/C, too, and relocate the battery, and you save a lot of the weight difference. Another option is a supercharger, lots of people making 300whp with just a supercharger, headers and a tune and at a the end of the day that comes out about the same price as an LS swap if you do it right, or use a new engine-- But, the LS has more scope for further modification. Personally I wouldn't want more than 350hp crank in this chassis, but, that's me-- Do as you please, I won't call you names.
Careful. It's contagious!
| Engine Swap: Which Would You Choose!?? | EvoFanatic | Engine Swaps | 157 | 08-08-2017 04:34 AM |
| Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 04:58 AM |
| Engine swap question | koyv90 | Engine, Exhaust, Transmission | 4 | 03-22-2012 02:08 PM |
| 4U-GSE: the new engine swap for old Toyotas | no_name | Engine Swaps | 17 | 12-19-2011 10:50 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
