#16 |
Drives: 15 BRZ, 00 528i sport, 09 colorado
So...yeah I have these plates installed on tarmac IIs. I played with my alignment for a good while and realized a 2.2 degree adjustment range for my setup with the plates (lowered 20mm). I set it up for a max of -1* with it being adjustable with the plates to -3.2*. I'm going to work this sat to see how this "street" to "track" adjustment affects the toe. Sounds like...not a perfect world from reading the above insight. Probably going to compromise "street" toe for 0* "track" toe.
| The Following User Says Thank You to slowandcurious05 For This Useful Post: | Pat (05-04-2016) |
#17 | |
Drives: Silver Coupe with a Boxer
What is your goal for having a street and a track setup? Most people that want less negative camber for the street are doing it out of tire wear concerns, but I would guess that running -1 degree camber with 0.2 degrees toe out will give you more tire wear than -3.2 degrees camber and 0 toe. |
#18 |
Agreed-toe is harder on tires. Car is not a daily in my case. I have to consider the effect the camber change at the track has on toe. I will measure this on Saturday. I will probably have to make a compromise. I don't know what I will settle with yet. What I do know is that I will lean toward a more beneficial track setup. HPDE in my area for my goals might average 300 miles one way. No sense in compromising the tires before I get there. I realize the problem. I guess I'm just taking the opportunity to bitch because it's a little frustrating.
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 02:10 PM |
| Jrz rs1 no camber plate? | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-09-2014 11:16 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 04:40 PM |
