Old 07-02-2012, 01:21 AM   #15
Dimman
Kuruma Otaku
Dimman's Avatar
Ahhhh....nope.
But I still don't understand why this should result in an increase in power.
F/m=a. Decreasing the mass (or inertia) increases the acceleration. Understood but you are not increasing the power. The engne output has not been changed.
As pointed out by others, that has never been said. The dyno measures engine torque that fights through the drivetrain's inertial and frictional losses. So reducing the mass of the wheels makes the path easier, in a manner of speaking. This is why there is a difference between the number a chassis dyno spits out and the number a factory tells us which comes from an engine dyno.
Because titanium.
Old 07-02-2012, 01:25 AM   #16
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Mr. Snooze. Who is it exactly that is claiming that lighter wheels makes more power? I re-read the thread and people are talking about how a reduction in rotational mass changes the readings on a dyno. Nobody is claiming the engine itself is making more power.
Old 07-02-2012, 02:21 AM   #17
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
When I see dyno graphs they usually display power and/or torque. The OP posted a dyno graph. It shows before and after. To me the implication was that if the "numbers" had changed the power had changed. If "a reduction in rotational mass changes the readings on a dyno" what readings are you referring to?
Old 07-02-2012, 02:24 AM   #18
Captain Snooze
Drives: Red Herring
Understood.
Old 07-02-2012, 02:27 AM   #19
Dimman
Kuruma Otaku
Dimman's Avatar
When I see dyno graphs they usually display power and/or torque. To me the implication was that if the "numbers" had changed the power had changed. If "a reduction in rotational mass changes the readings on a dyno" what readings are you referring to?
Just to clarify.
These are chassis dyno figures. They calculate the net torque as measured at the vehicle's drive wheels. This is NOT a representation of power/torque at the flywheel.
Because titanium.
Old 07-02-2012, 02:29 AM   #20
speed3
Walkin' on sunshine
speed3's Avatar
Drives: Ford BA MKII XR6 ute
Take 2 cars
Car 1 stock
produces 200hp from the engine
produces 160 hp at the wheels
Car 2 stock except wheels
produces 162 hp at the wheels
You aren't making any more power just increasing the efficiency of the drivetrain.
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
speed3 is offline   Reply With Quote
Old 07-02-2012, 02:55 AM   #21
Captain Snooze
Drives: Red Herring
OK! I have just been reading about inertia type dynos. Sorry, it has been about 25 years since I have been in a dyno workshop. I was not familiar with such devices.
Old 07-02-2012, 02:56 AM   #22
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
The difference is probably due to the air filter...
Jordo! is offline   Reply With Quote
Old 07-02-2012, 03:52 AM   #23
speed3
Walkin' on sunshine
speed3's Avatar
Or random variation between runs.
Old 07-02-2012, 10:17 AM   #24
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Or lighter wheels.
Type[R]+ is offline   Reply With Quote
Old 07-02-2012, 10:06 PM   #25
DanVIIIVI
DanVIIIVI's Avatar
Drives: 86GTS 6M
So what are the weights of the stock 17" wheels on the fr-s/86?
DanVIIIVI is offline   Reply With Quote
Old 07-02-2012, 11:01 PM   #26
Mitch
form follows function
Drives: RIP '13 BRZ
I think I've seen 20lbs for the tire and 21lbs for the wheel for a grand total of 41lbs.
Mitch is offline   Reply With Quote
Old 07-03-2012, 01:46 AM   #27
DanVIIIVI
DanVIIIVI's Avatar
Drives: 86GTS 6M
Yeah, I found another thread that outlines the weight of all components on the vehicles. The OEM 17" wheels come in at approx 21.4lbs = 9.706 kgs.
Should be very easy to shed some weight there.
Few things I found out on the BRZ - extra cigarette lighter outlet 86design BRZ First-Gen (2012+) -- General Topics 42 04-15-2023 12:56 AM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 06:03 PM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 10:35 AM
Increased media chatter can only mean one thing... sieeegel BRZ First-Gen (2012+) -- General Topics 138 03-16-2012 11:19 AM
