Drives: 2014 Toyota 86 Hi A/T
BRZ vs 86 radio
Hey guys
New here and just want to make sure about something. This may be a very dumb question, but is the BRZ and the 86's radio's identical? I am looking at getting this headunit once I buy the car, but need to know it will work in the BRZ as well: http://www.kenwood.com/au/car/visual...ion/ddx715wbt/ Thanks in advance |
Drives: 2013 Grey Toyota 86 High 6MT
As far as I can see and tell, they're identical.
Same hilux radio I had. |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Yep - pic above same as my Toyota.
I like driving!
Drives: Toyota 86 - Charcoal Grey
The cars will all have the same Toyota harnesses, only with different radios fitted from the factory.
"He who shall be last, shall be sideways and smiling."
#6 | ||||
This isn't entirely true, the BR-Z navigation head unit not only has a subaru gps antenna which is easy to get. The FR-S/GT86/86 HU sends power to the car's antenna booster amplifier via the separate single-conductor wire on the AM/FM antenna connector. The BRZ HU sends the 12V power antenna signal out via pin #8 on the 10-pin power/speaker harness. You'll need to rig up an adapter harness (or at least, add a jumper wire from the vacant slot on your car's 10-pin plug to the factory pin/wire on your car's AM/FM antenna plug. This has been proven in other threads, that's why it's not worth transplanting one of the twins head units into each other unless they can be had for super cheap.
#7 | |
Sent from my D6603 using Tapatalk |
#8 | |
You may need to get a qualified installer to do it, there's another issue with our cars, the door speakers have a separate amplifier, and most head units aren't pinned to turn that amplifier on therefore the door speakers don't work but all others do. The result is the sound is low quality. http://www.ft86club.com/forums/showthread.php?t=87247 http://www.ft86club.com/forums/showp...8&postcount=20 Those threads may help
#9 | |
#10 |
Super useful info, thanks for helping us Africans out @
![]() I opted to not pay extra for the built in navigation. My experience with any "built-in" software vs a dedicated solution has usually ... left much to be desired. Is it possible to a) enable this without the dealership or b) just pay $$ to have it activated? Does anyone have the GPS running on their 86 and is it worth it? |
#11 | |
I like driving!
#12 | |
#13 |
I don't like head unit navigation. I have a Kenwood DDX715WBTM so I mirror my phone's Google Maps for navigation and realtime traffic.
#14 | |
I also use Google Maps, but the amount of battery drain is insane. |
| App Radio 2 | Guaruja | Electronics | Audio | NAV | Infotainment | 11 | 11-28-2013 06:49 PM |
| Noticeably low and sharp volume with AM radio stations with stock BRZ radio | tracerit | Electronics | Audio | NAV | Infotainment | 0 | 07-24-2013 03:38 AM |
| aha radio | mechaghost | BRZ First-Gen (2012+) -- General Topics | 1 | 08-13-2012 12:08 AM |
| Radio, Iphone?? Radio cuts out when surfing the web | Fugazi | Electronics | Audio | NAV | Infotainment | 5 | 07-30-2012 12:24 PM |
| BRZ HD Radio on/off | ashtray | Electronics | Audio | NAV | Infotainment | 0 | 06-07-2012 01:42 AM |
